Error code HO2 appears after inserting dvd panosonic NV-VP30EB
  • mrdrp Sep 20, 2008
    Hi, tried the first option no joy will try 2nd option in due course. appreciate your help,
    regards
    mrdrp
    Brigadier General:
  • 6,966 Answers
To my knowledge, most H02 errors on a Panasonic DVD player would indicate a spindle error, that is the central motor that spins the disc. Normally, this would require an in-shop repair as electronics is involved, however, you could still try:
  • close the tray with no disc inside;
  • press on the back skip, pause, and play buttons simultaneously and hold for about 4 seconds;
  • when the screen blanks and then "initializing" appears, release the buttons.
Alternately, you can try:
  • remove the top cover;
  • clean the spindle motor with compressed air;
  • manually turn the spindle counter clockwise and then clockwise numerous times to exercise the motor;
  • power on the player, insert a disc and manually assist the disc to start turning.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 20, 2008
The errow ho2 appears n the disc don't spin
hi, check the disc motor it may worn out which need replacement.
Mar 22, 2012 | Televison & Video
Hi, I need a Panasonic NV-VP30EB User Manual in English, can anyone help? Thanks, Mike.
Hello
Get into this link by Google. You can download your device's manual in English. If you feel any difficulty in downloading the same, send your email address to me by Fixya. I've the manual and I'll send a copy of it to you by return mail. OK.
www.puxaki.com.br/pdf/.../panasonic-Operating-Instructions-DVD-VCR- Combo-NV-VP30EB-EBL-4337.pdf
Jun 04, 2011 | Televison & Video
Have HO2 error on panasonic VCR - can anyone help? Model is NV HS900
You have a K-Mech model and HO2 means that the tape did not withdraw when unloading. The cause of this is either the Capstan motor, the timing of the mechanism, and most likely (if you ask me) the mode switch.
Quote K-Mech for parts etc, you can also find service information for this model on the web.
Dec 17, 2009 | Panasonic Televison & Video
After i insert DVD it reads then say HO2 then STOP= how do i fix this
You will need to get a can of the compressed air or use an air compressor if you have one. Then remove the housing cover if you can and use the compressed air to blow out any dust and debris inside the unit. Also blow air into the inside of the dvd tray. This has been the common fix for the HO2 error on your DVD player. You could also use a DVD lens cleaning kit.
Nov 02, 2009 | Panasonic DVD-RV31 DVD Player
DVD player is unable to read any disk to initialize play
Laser is probebly goin bad and can't read. try putting a music Cd in. If it can play the music CD but not the DVD it's the laser.
Apr 10, 2009 | Panasonic DVD-RV26 DVD Player
Dvd wont play ...each time you insert a DVD it shows DVD HO2...
I had the same Problem, player was only 13months old when the error HO2 appeared (typical huh?) anyway 2 years of this thing getting shifted from cupboard,wardrobe,attic, (did'n't want to throw it out cause it cost me £700), finally it came to fix it or bin it time. scoured the net to no avail, lost the rag and half dismantled it..then during all of this ( oops I'm going on a bit LOL)
you can hear a sound as though the disc is trying to be read, after 100's of attempts to get it to work, I finally noticed the disc had not changed position. (disc was not spinning) pointed to the Motor??
what I did to fix this was unplug from main's, remove top cover until you can see the top of the dvd disc, got hold of a pencil with a rubber on one end, plug back in, switch power on, and gently pushed top of disc ( clockwise ) and it kick started it off
that was over 3 years ago and the player is still going strong
I know its a bit rough, but nothing ventured nothing gained ;)
Feb 17, 2009 | Technics SC-DV290 System
Setting a new Panosonic TV
If it has no freesat tuner then you can only record what the TV is viewing/tuned to as an output from the TV.
Mar 21, 2017 | Panasonic CT-27SF36 27" TV
HO2 Error in VCR
I guess either the tape head is dirty and needs cleaning or you should email Panasonic with that question after reading the instruction guide's troubleshooting section.
Oct 17, 2008 | Panasonic DVD-RP56 DVD Player
CODE: HO2
i think the problem is an accumulation of dust. try cleaning it out with a can of compressed air, or if you dont have that, by blowing on the lens gently.
Aug 20, 2008 | Panasonic DVD-LS50 Portable DVD Player
Error Code:DVD HO2
try to clean it first bring cleaner cd from radio shack. put your cleaning disk in and let it run-remove cleaning disk and put your disk and try,
Nov 03, 2007 | Panasonic SC-HT75 System
Televison & Video Logo
656 people viewed this question
Top Televison & Video Experts
