I have an existing washing machine which is both hot and cold water fed. Ihave since purchased a new one which is cold fill only. How do I cap or close the unwanted hot water pipe connection? Many thanks, SImon
Put a cork in it
Posted on Sep 30, 2008
Can my creda excel 1200 be converted to fill with hot water instead of cold water
Unfortunately it will need cold water for the rinses. Also it controls the temperature of the (hot) water itself which it would not be able to do if fed with water that was too hot- for delicates for instance ;-0(
To use your hot water would require a hot AND cold fill washer, sorry!
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 09, 2011 | Creda Washing Machines
When connecting the machine to the taps, do you need to connect the machine to hot from the geyser or the washing machine makes the water to be hot
I think you will find that all washers are able to heat water. If they are hot and cold fill, they use the heater if the hot water supplied is not hot enough for the particular wash. If they are cold fill only then they need the heater for all non-cold washes.
If you purchase the washer you are thinking of and it is cold fill only, it will have only one inlet hose, the cold water one and it is a straight forward installation- hose from washer screw into cold supply tap.
If it is hot and cold fill you have a choice- either go to the expense of plumbing hot water to it OR purchase a 'Y' 'tap' adapter. The adapter screws onto the cold supply (by the 'bottom' of the Y) and the hot and cold hoses which go to the washer are screwed into the (top) 2 ends of the 'Y'. The washer opens its hot valve, gets the only water supply which is cold through what it thinks is the hot hose and heats it up accordingly. When it wants cold it opens its cold valve and gets the cold water through what it thinks is its cold hose- which it is!
I hope this clarifies the situation for you and if it has please consider a 4 thumbs up for the rating.
John C
Jun 17, 2011 | Washing Machines
I am about to buy this model machine but before i do i need to know-does this machine heat up the water itself? or do i have to have a supply of hot water going into the machine in order for it to be hot...
John C
Apr 18, 2011 | Washing Machines
My speed quueen modle number ha 3000 w takes about 45 min. to fill the tank
No speed there, then ;-0)
Sorry, I do not know whether your machine is cold fill only or hot and cold.
If it's both is it just on the wash cycle- when hot water is being fed in or on rinses when cold water is fed in? If it's on both wash and rinse I would have to assume that it is cold fill only.
I would first check that the water supplied to the washer is OK. Turn the tap(s) off and take the hose(s) off. Have a bucket handy (or sink if it is close enough) and turn each tap on in turn to make sure the water flow IS plentiful. If it is, and whilst the hoses are disconnected, check the little filters just inside the washer inlets in case one or other is blocked up.
If all the previous are OK the next suspect is the inlet water control valve (singular- depending again on whether it is just cold fill only) which is malfunctioning and will require a service engineer's visit, sorry ;-0(
Hope I haven't confused you!
Good luck,
John C
Mar 15, 2011 | Speed Queen Washing Machines
Will not fill with hot or cold water and is connected
You need good water pressure on hot for these machines to work, gravity fed systems may not be enough. I had to attach a pump to mine to improve the hot water pressure (UK)
Switch over the inlet pipes ie hot to cold and cold to hot and try filling the machine when switched to fill with hot water, (machine will fill will cold). proving the valve is opening and it is a pressure issue on you hot water.
Nov 29, 2010 | Admiral AW22 Top Load Washer
I have an Indesit Widl 126 which is about 5 years old. We have just moved house and there is no hot water connection for the machine in the kitchen, there is just a cold. The machine has hot and cold...
Asuming the water is in the washer, then it sounds like the element could be faulty, to be certain, you would need to test it with a meter, and don't forget it is filling with cold water, so will take a lot longer to get hot.
Mar 03, 2010 | Washing Machines
Have been given Hoover HC6-110 (fitted with hot
This machine does not have a heater. You could use a Y connector or just cap off the hot and only use the cold settings.
Feb 24, 2010 | Hoover HC6 110M Front Load Washer
Hotpoint aquarius wf 640
You cant seal off the inlet, but you can get a Y adapter, its a hose that splits into 2 outlets. They are most often used to hook up steam dryers but will work for wha you need, this will allow you to use it but it will not get the best cleaning results
Jul 19, 2009 | Hotpoint Aquarius WD640 Front Load...
FP Hot water used when cold selected
YOU NEED TO CHECK THE WATER TEMPERATURE AFTER THE TUB IS FILLED WITH WATER WHEN COLD IS SELECTED. NEW MACHINES WILL USE BOTH THE HOT AND COLD WATER VALVES TO FILL THE MACHINE. THEY DO NOT WANT YOU WASHING WITH STRICTLY COLD WATER AS THE DETERGENT WILL NOT PROPERLY DISOLVE. COLD WASH TEMP SHOULD AVERAGE 65-70 DEGREES.
Mar 30, 2009 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
