After inserting DVD the TV screen says reading, the window on the DVD player says HO2 & then changes to stop
    Brigadier General:
  • 6,966 Answers
Hi again,
it would seem that you posted twice. Pls see your other post.
Cheers.
Posted on Sep 20, 2008
Can you tell me how to decode a grunkel dvd player to all regions?
Model 20-NT
1. Using the remote control, key in the following: Setup, Stop, Skip Backwards, Skip Forwards.
2. You should then be able to change region and remove MacroVision.
Turn on the DVD player without DVD inserted. Then, using the remote control, press this buttons: Setup, Stop, Skip Backwards, Skip Forwards.
Model 22NG
Turn on your player
Open the tray
Press 8 4 2 1 on the remote control --> "Region 2" appears on the TV screen
Press SELECT until 9 for region free & MacroVision free
Model 32S
Press Setup
press Volume +
Press Volume -
Press the right arrow until the screen on the player reads 255
Press setup to exit and all done
Nov 17, 2009 | Televison & Video
My DVD player won't play i'm getting a code HO2 on the display screen. ModeL # DVD-RV31
this is what i got from Josh Smith Online, this work-around requires opening the appliance, so before you start and follow this, please check on the warranty status of the unit.
error HO2 which more or less means the unit is shot. The problem centers round a spindle issue that is a known design flaw. Basically what happens is that the spindle gets warm, expands, and is then pushing on the top of the player .
You can see the tray which rotates with the DVD in. To fix this HO2 error I first had to start the spin by pushing the dvd counterclockwise gently. After that the DVD player would work but only without the cover on. This is the solution for now, though I plan to modify the case some in order to use the cover again. For now the DVD player slides into our entertainment stand and hides the fact that the cover is missing.
Aug 11, 2008 | Panasonic Televison & Video
After i insert DVD it reads then say HO2 then STOP= how do i fix this
You will need to get a can of the compressed air or use an air compressor if you have one. Then remove the housing cover if you can and use the compressed air to blow out any dust and debris inside the unit. Also blow air into the inside of the dvd tray. This has been the common fix for the HO2 error on your DVD player. You could also use a DVD lens cleaning kit.
Nov 02, 2009 | Panasonic DVD-RV31 DVD Player
DVD player is unable to read any disk to initialize play
Laser is probebly goin bad and can't read. try putting a music Cd in. If it can play the music CD but not the DVD it's the laser.
Apr 10, 2009 | Panasonic DVD-RV26 DVD Player
Dvd wont play ...each time you insert a DVD it shows DVD HO2...
I had the same Problem, player was only 13months old when the error HO2 appeared (typical huh?) anyway 2 years of this thing getting shifted from cupboard,wardrobe,attic, (did'n't want to throw it out cause it cost me £700), finally it came to fix it or bin it time. scoured the net to no avail, lost the rag and half dismantled it..then during all of this ( oops I'm going on a bit LOL)
you can hear a sound as though the disc is trying to be read, after 100's of attempts to get it to work, I finally noticed the disc had not changed position. (disc was not spinning) pointed to the Motor??
what I did to fix this was unplug from main's, remove top cover until you can see the top of the dvd disc, got hold of a pencil with a rubber on one end, plug back in, switch power on, and gently pushed top of disc ( clockwise ) and it kick started it off
that was over 3 years ago and the player is still going strong
I know its a bit rough, but nothing ventured nothing gained ;)
Feb 17, 2009 | Technics SC-DV290 System
CODE: HO2
i think the problem is an accumulation of dust. try cleaning it out with a can of compressed air, or if you dont have that, by blowing on the lens gently.
Aug 20, 2008 | Panasonic DVD-LS50 Portable DVD Player
Error message HO2 shows on vhs display
the player begins to read dvd. display will read 00---READ and it repeats this process a few times and the error then is displayed next.
Jul 10, 2008 | Panasonic Televison & Video
HO2 Error???
The problem with your unit is the "Spindle Motor", this motor is the one that spins the disc so the laser can read it. I sugest you to take your player to a shop, or back for service if the unit still under manufacturer warranty.
Apr 14, 2008 | Panasonic DVD-RP56 DVD Player
DVD S1000 video player
A new Laser pick up will fix your problem expencsive repair
Dec 12, 2006 | Fisher DVDS1100
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
