Question about Technics SL-1210 Turntable
Sound i can only seem to get the left speaker and the left side of my headphones to have any sound. i have tried two different amps and the have the same problem so it seems a bit unlikely that its the amp. i have tried wiring the decks straight thourgh the amp and the same problem occours so i know its not the mixer. im sure this is a very trivial problem. please can someone help? im playing a party tonight!
  • Anonymous Oct 05, 2008
    the right channel is not working only on my turntable
It seems like u need ur audio leads and earth re-doin mate take it to a decent dj shop will cost u about 20 pound 4 both of them to be sorted
Posted on Nov 02, 2008
Sound coming through right headphone, but not through left. Sound also not coming through left speaker. Help?
are you adjusting sound through the windows controller or the application you're playing music through? there are a few things that could affect that, there's also the actual sound setup where you can change your setup i.e. surround sound, single speaker, headphones etc
Oct 02, 2013 | Toshiba Satellite Computers & Internet
No sound out of Behringer BXL3000 speaker
Suspected Faulty PC board Dead Capacitor Or Mod Pot I would suggest returning it for an exchange the problem is your speaker will work on a regular stereo because a stereo powers the sound internally causing the magnets in the speaker to vibrate Headphone jacks are designed to pick up off a seperate circuit board with a different connection to the main board hence the no sound from the speaker.
May 04, 2012 | Behringer Ultrabass Bxl3000
Sound through headphones only.
Try the speakers on another computer, to see if they work at all. If they do, then the problem is the audio-interface on your computer (or DVD-player, or home-stereo system).
Apr 05, 2010 | M-Audio Studiophile DX4 Computer Speakers
My speakers are both working fine, but I am only getting sound from my left headphone
Ok..,then try the headphones on another system to see if the problem is a loose wire or the driver on the right side. of those headphones.. If the problem is in the headphone amp section of whatever you are using{hi fi amp/mixer or computer interface],it could be a simple dry solder joint[which anyone with basic electronic and soldering skill can attempt]  Try a different pair of headphones on that system or the above and find out who is to blame first...Hope this helps ...
Mar 15, 2010 | Samson G-TRACK USB RECORDING MICROPHONE...
I can hear only from the left side of the headphones
1) unplug the headphones and check if sound is ok with laptop speakers
2) try different headphones
Dec 15, 2009 | Toshiba Satellite A60 Notebook
Little sound out of left satellite in Logitech S200 2.1-system.
Try plugging in some headphones to the right satellite, unplugging them and turning the speakers off and on. This worked for me, and is probably the switch getting stuck between headphones & normal speakers.
Mar 30, 2009 | Logitech Audio Players & Recorders
Only hearing sound out of left side of headphones
i think the problem is in the jack of your sound blaster. since you have already tried different headphones and the problem still persist, and when you use speakers it works fine. i conclude it is the jack of your sound blaster card.
Dec 22, 2008 | Creative Labs Sound Blaster Live! 5.1...
Low volume on left channel of Sony STR-GX4ES
The headphone is tapped before the final stage of the amp, so knowing that those work properly helps to isolate the problem. I think that this model uses an IC for the voltage amp section prior to the final amp stage. That being said, the IC is probably an UPC2598 (if memory serves). I'll confirm tonight. Try resoldering any connections that appear to be grainy or have rings. Let me know what you find.
Dan
May 08, 2008 | Audio Players & Recorders
Less sound on one ear than the other
Yeah, based on all of your problems, i would safely say that you have a blown speaker. Call up Bose at 1-800-999-2673. If the headphones are under warranty (1 year) they will replace them for free. If now, they will charge you $100 for a replacement pair, which is quite a deal considering that the headphones cost $300.
Jul 05, 2007 | Bose QuietComfort 2 Consumer Headphones
Technics SL-1210 Turntable Logo
100 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
