Re: Van will start but not stay running 97 chevy venture
If it starts for 5 seconds out less, and you notice a security light on the dash, go to this link for answers. Gm are notorious for failing antitheft systems
http://vatspasslockpasskeysecurityhelp.yolasite.com/
1st u must clean the engine of all grease and dirt, then run it until u can see the source of the oil leak, based on what is leaking will determine the difficulty of repair at home.
No it's not, if your van is running fine, fuel pump is good, just the fuel gauge sending unit is bad, to repair, the gas tank will have to come off, the sending unit sit on the same hanger the fuel pump is on.
most any sensor going bad can cause the check engine light to come on,try disconnecting the posative battery cable for 15 seconds ,then put it back on,will reset the codes, or take it to auto zone,they will test your computer for codes at no charge to you.i had a venture van my was ox. sensor. thanks robert b.
4th clutch hub splines are stripped off. GM didn't harden the splines until 2004 or so so the early model gradually wear to the point where they are so thin they strip off - and then, no 4th gear
2000 chevy venture run good but my lights flickers and have to jump. After I jump the van and put my meeter on the battery its reading 14.volts at idle. I can drive around to store cut the van off come out it starts fine leave it overnite and it don't started.
