Question about Toshiba 65HX93 65 in. Rear Projection HDTV Television
Panasonic TU-HDT104A Hello I have a Panasonic TU-HDT104 and i have lost the Menu and Program Info Plates they will not show up when you change the channel and basically no OSD any ideas guys Thanks
"SET 1" Displayed and remote not working.
You have a Panasonic, they have a feature, in case you have two or three Panasonic units you can program the remote either be used on one, two, three. So if the display lights set one that means the remote control would control set one. There are several ways to change a setting one is in the player menu, I believe you can change the remote. Check your manual, this is not a big deal.
Oct 18, 2014 | Panasonic Televison & Video
I have a panasonic CT-3263W and i need the code to program the remote i have is a universal DT008
hola tu el de la panasonic como estan espero ke bien solo keria saver si me puedes aser un favor por que yo tambien tengo una tv panasonic como la ke tu tienes y quisiera saver si me puedes pasar la configuracion de los colores de brillo nitides contraste y eso por que ala mi a le movierron los colores y se mira mui fea la calidad asi que si me puedes desir como van acomodados muchisimas gracias de ante mano saludosss a todos
Jul 01, 2011 | Jensen TS2050J 20" TV
Have just bought a panasonic tv and every ten minutes an information notice comes on the screen about hdmi info etc how can I get rid of this?
Go into ur tv menu.Goto OPTION.Go down to Program Display Title.Pick option No.Will have no more Info..ect. display anymore.
Nov 08, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
DVD-S35 Panasonic - bandwidth information OSD
I have upgraded the firmware on my player and the problem disappeared. There is a "bitrate display" option in the Settings menu, but it didn't change anything when I tried it (before the upgrade). Now it isn't necessary.
Jul 17, 2009 | Panasonic DVD-S35 DVD Player
I have rca remote ,i want it to work with tv thanks
sorry you need the correct panasonic remote to be able to program a "learnable" remote
Jun 01, 2009 | Panasonic PV-M1348 13 in. Combo
Panasonic vcr
what is the model of the vcr ?
Mar 23, 2008 | Panasonic PV-4601 VHS VCR
Cannot Find Aux On Kenwood KDC W3037A
You have to ENABLE to AUX source thru the settings menu.
Users manual is HERE.
Best of Luck.
Please RATE my solution BELOW.
Nov 22, 2007 | Car Audio & Video
Panasonic dmr-es15
Pan. DMR-ES15 I WILL NOT RECOGNIZE ANY DISC I PUT IN. WILL NOT PLAY A COMMERCIAL DVD MOVIE. SEEMS TO HAVE STARTED WHEN IT COULDN'T FINALIZE A RECORDED DISC. HOW TO RESET?
Oct 28, 2007 | Panasonic DMR-ES10 DVD Recorder
Toshiba 65HX93 65 in. Rear Projection HDTV Television Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
