Question about Toshiba Satellite 5105-S501 Notebook
Thanks for responding
Pulled out hard drive, started up but same thing happened, pressed esc. to enter cmos, it said press F1 to enter default settings, wouldnt go to cmos. Thats as far as ive gone. Oh also i have a hard drive from another computer with windows ME on it, i put that one in and it started up, reinstalled alot of drivers, but not all (ME is a bit old) but it will start up with that hard drive and run, somewhat. Ill keep ya posted and thanks for taking the time to assist me.   Dan
Try starting it again hitting F12. That will get you to the first menu. Use your arrow keys to navigate. Try it. You will figure it out. Email me bill@lmnop-za.com and I'll help ya.
Posted on Feb 08, 2009
Will only run on safe mode
Restart your computer
During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys
F10
Acer: - Ctrl +Alt +Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate
load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Jul 08, 2013 | Compaq Evo D500 PC Desktop
How to exit safe mode
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
if this fails you might try some of these Acer: - Ctrl+Alt+Esc
Apr 30, 2013 | E-Machines Computers & Internet
My desktop 4210 is in paused mode how do i fix it
Step 1:
Restart your computer During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys Acer: - Ctrl +Alt +Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc) Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Mar 12, 2013 | Computers & Internet
There are several possible jumper configurations on my mobo ash1 ash2 intri cmos and obr my acer aspire desktop m3100 won't boot at all I just installed a new psu & cpu
If you mean the plastic plug jumpers located on the hard drive to set master . master/slave ........
single or master :::::
master with slave ::'::
slave :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
The jumpers should be printed on top of the hard drive.
If its not booting at all it might be the ram or leads from motherboard to hard drive.
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart This will set the boot order If this fails you might try some of these Acer: - Ctrl+Alt+Esc
Feb 26, 2013 | Acer Aspire M3100-U3401A Refurbished...
Compaq stuck in utility mode
Feb 14, 2013 | Compaq Armada 1750 Notebook
My toshiba c850 is in flight mode, how do i get out of this?
Feb 04, 2013 | Toshiba Satellite Computers & Internet
CD Drive will not allow boot
Change the boot order
Feb 03, 2013 | Computers & Internet
Booting problem
have a close look at the screen it will be quick you will see which key to press to enter bios
hope this helps
others you might try
Sep 27, 2012 | Sun Blade 2500 PC Desktop
How to enter cmos setup?
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
Aug 04, 2009 | Toshiba Satellite 5005-S504 Notebook
Unable to get to CMOS using any of the 3 methods
This machine is one of the first "legacy free" models which means there are no BIOS options to change. All settings and resources must be assigned by the OS.
For details, please check the "legacy free" FAQ on MS Knowledge base.
If you are trying to access the BIOS to change boot order so that you can boot from a CD, hold down the 'c' key during POST/boot. This will case your laptop to boot from CD-ROM.
Apr 09, 2008 | Toshiba Satellite 5005-S504 Notebook
Toshiba Satellite 5105-S501 Notebook Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
