Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Dr watson postmortem
Hi my name is umesh.how to repair dr watson postmortem debugger. please send me solution
  • 1 more comment
  • umeshjoshi20 Sep 23, 2008
    my Dr. Watson postmortem is corrupted.please give solution to repair it
  • Apocalypto 524
    Apocalypto 524 Mar 03, 2009
    A SUDDEN POPUP WINDOW APPEARS AND SHOWS DR.WATSON PROBLEM ENCOUNTERED ... PLZ HELP
  • hami1227 Mar 18, 2009
    dr watson postmortem debugger window appearing when i turn on the system my system gets strukd by dis wat 2 do?
  • 97 Answers
What happen to your Dr. Watson?
Posted on Sep 22, 2008
    New Friend:
Lopityreww
Posted on May 17, 2016
Install SP3 .... Simplest solution .... i have tried everything else .. but only instaling SP3 cud help me solve it 100 % .. cheers !!
Posted on Mar 07, 2009
When turning on it will only go to a blue screen says go to safe mode or get tech support but even in safe mode it will only go back to blue screen. Can't download anything or do anything. At the...
Try uninstalling a few unnecessary programs
Just run fewer programs or buy additional RAM click start right click on my computer select properties you will see all imformation about your computer including installed ram
or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly
click start right click on my computer,properties advanced scroll down to system and recovery open settings write and debugging information the drop down button select none
ideally, it should already be the default debugger for your system.
The Dr. Watson debugger program logs all information related to failed processes to the Drwtsn32.log file. In addition to this, the debugger program can be configured to create memory dump files related to the failed processes. You can refer these dump files to analyze the reason behind a process failure.
Perform the following steps to configure Dr. Watson as the default debugger program to record user-mode program errors:
  1. Open Start menu, select Run, type Drwtsn32.exe -I and then press Enter. This command sets Dr. Watson as the default debugger.
  2. Next, run the Drwtsn32.exe command.
  3. In the Dr. Watson for Windows dialog box, select the following check boxes:
    • Append to Existing Log File
    • Visual Notification
    • Create Crash Dump File
  4. Now, when your computer restarts after the STOP 0xC000021A error is generated, run the Dr. Watson command.
  5. Here, view the paths to the Dr. Watson and User.dmp logs.
  6. Open Windows Explorer, navigate to the log files and then open them.
  7. Here, check the cause behind the STOP 0xC000021A error.
also you might download and use this registry cleaner it is 100%totally free to use
http://download.cnet.com/ccleaner/
hope this helps you
Jul 24, 2011 | Computers & Internet
Menu keep on poping up when tried to exit it goes back on the screen over and over.
The first cause can be fixed rather easily. Simply run fewer programs or buy additional RAM click start right click on my computer select properties you will see all imformation about your computer including installed ram
or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly...!..
also you might download and use this registry cleaner it is totally free to use
another one of the possibile reaons is
a bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to finish its cycle and have an end so any faulty leads will end up with a computer error
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
hope this helps
Apr 04, 2011 | Computers & Internet
Invalid parameter problem keeps rebooting my computer
The first cause can be fixed rather easily. Simply run fewer programs or buy additional RAM or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly...!..
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Feb 24, 2011 | Computers & Internet
My touch pad constantly freezes and is inhibiting my work flow due to restarting the notebook all the time. please help
hope this helps
don
Feb 23, 2011 | Computers & Internet
Keep getting a memory dump error
this problem only can fix by reinstall your computer operating system (windows)
Feb 22, 2011 | ASUS G51JXA1 PC Notebook
I can't use Word...I keep getting a box indicating that "watson client has stopped working"...what can I do?
  2. hope this helps
Jan 22, 2011 | Fujitsu Computers & Internet
How to repair Dr watson
Hello umesh,
We need to backup first the data before we do some action.
Questions:
1. First installation you remember.
- Did you set the System Restore?
Answer:
- If yes, goto {Start} Menu - Programs - Accessories - System Tools - System Restore
- Note Pls. read carefully and follow the instruction on how to restore settings.
- After finishing restore automatic performed restart your computer.
- if Not, you need to reformat and install again the Windows O.S.
All so check your PC have a Dust in the Processing Unit also check the CPU Fan.
- if they have many dust in your CPU and also the fun is not working they can cause Hang-up
and Restart your PC or Turn it off automatically.
Sep 20, 2008 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
413 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
