My compaq won't boot up, this is all that happens*read*
I have a compaq, an the compaq screen pops up as i turn it on, the fan's kick in for a bit but the keyboard is not getting power it seems, no lights come on, then after a while SOMETIMES it goes to an all black screen with a little white underscore flashing at the top left, then one light comes on but no other lights come on if i press it, an no buttons work, it was working fine just before, all i did was just turn it off for the night
2 Suggested Answers
acdr
  • 1913 Answers
SOURCE: "Disc Boot Failure" upon powering up the compaq
your harddisk is not detected.
open your cpu case.
then reattch the power code and datacode to hard disk.
Posted on Nov 03, 2008
Laptop won't boot - Compaq
Do you see anything on the screen? Does the HDD LED blink? You can start by removing the HDD and testing it or have it tested.
Jun 06, 2013 | Compaq Computers & Internet
No screen
Hi ,
This seems to leave us with the Hard Disc .
Regards .
Apr 13, 2013 | HP Compaq Presario CQ61-420US 15.6-Inch...
Compaq Presario SR1610NX won't turn off, and won't
The problem could be a hardware problem.
You can try removing the ram to see if it's faulty otherwise I am afraid you are unlucky because could be a motheroard problem so the only solution is to bring your laptop to repair service.
Feb 05, 2013 | Computers & Internet
How to fix a blank screen on a compaq sr5000 desk top?
Try rebooting to see if that clears up the issue. Should. Does not mean it will not happen again if you repeat the operation that caused the BSOD. There is an issue with your OS and you might want to attempt a repair operation if possible
Sep 03, 2017 | Compaq Computers & Internet
Screen on presario 2500 is black blank and won't change
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 19, 2012 | HP Compaq Business Notebook NX9010
Windows won't start at bootup. Instead the fan turns on.
It sounds like your operating system has failed. Your best bet would be to use a working computer to burn a new install disc / backup disc / repair disc and then reinstall your operating system, or if possible repair it.
Have you tried plugging the VGA output into an external monitor and turning it on? Maybe your screen has just failed, if it does output to an external monitor.
You can get it into external mode if you boot it up with an external monitor connected, a USB mouse connected, and a USB keyboard. Boot up the machine (plugged in!) and close the lid right away, and it should automatically kick over. If not, try windows key and P at the same time, once the machine is "running"
Aug 14, 2011 | HP Compaq 2530p (KS094UA) PC Notebook
My laptop (Compaq Presario v2000) won't seem to boot up
Remove the battery. Plug power cord in. Turn on machine. Does it boot? Replace battery.
gurutim
Mar 17, 2009 | HP Compaq Presario V2000 Notebook
open your cpu case.
Nov 03, 2008 | Compaq Presario S6300NX PC Desktop
Black screen, won't boot up, fan kicks on for a few seconds only, then powers down
check the display on the external monitor through the vga port, if the display is fine , then its the problem of your laptop screen, some time this is due to the cable that gives display to the screen, take it to the technician and checks there
how do you like the solution rate it please
Oct 17, 2008 | Toshiba Satellite M35X-S109 Notebook
Frozen during boot-up, keyboard still works
Sounds like the PC is running into a hardware failure and the Compaq splash screen is probably hiding some additional information. It?s been a long time since I've owned a Compaq, however, what you need to do first is eliminate the Compaq screen to show us whatever boot details it may be hiding. I seem to recall on my old Compaq (and most Dells) I had to disable the Compaq screen in the BIOS settings. Hitting the F10 key as soon as the Compaq screen appears I believe will get you into the BIOS program, however, be warned if you change anything in there by accident you will be causing yourself a world of trouble. After you get into there you want to look for the Boot selection of the menu. In there somewhere will be a setting referring to something similar to ?reveal boot details? or hide splash or Compaq screen?. If it isn?t obvious let me know, I?ll have access to an older Compaq with a similar BIOS and can give you more details. If you are able to disable the splash screen reboot the PC and watch for errors. Based on the age of the machine and past history I suspect you?ll find a boot disk or read error.
Nov 28, 2006 | Compaq Presario 5716 PC Desktop
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
