Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
How to repair Dr watson
Hi my name is umesh,my Dr Watson postmortem & explorer.exe file are corrupted & my pc going to restart.please tell me what is the solution to repair it.
  • 97 Answers
Hello umesh,
We need to backup first the data before we do some action.
Questions:
1. First installation you remember.
- Did you set the System Restore?
Answer:
- If yes, goto {Start} Menu - Programs - Accessories - System Tools - System Restore
- Note Pls. read carefully and follow the instruction on how to restore settings.
- After finishing restore automatic performed restart your computer.
- if Not, you need to reformat and install again the Windows O.S.
All so check your PC have a Dust in the Processing Unit also check the CPU Fan.
- if they have many dust in your CPU and also the fun is not working they can cause Hang-up
and Restart your PC or Turn it off automatically.
Posted on Sep 22, 2008
Tip
Disable Dr. Watson Watson is a debugging tool in windows , which...
Disable Dr. Watson
Watson is a debugging tool in windows , which sometimes becomes quite irritating when ever it pops up suddenly .
Here is a method to disable it , if it bugs you :
Dr. Watson can be disabled using the registry editor:
  1. Start the registry editor (Start >> Run >> type "regedit.exe" >> Hit enter )
  2. Navigate to HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ AeDebug
  3. Click on AeDebug and click Del
Alternativly just set HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ AeDebug \ AUTO to 0
To re-enable Dr. Watson type "drwtsn32 -i" in run window.
on Jan 26, 2010 | Computers & Internet
Laptop gives error.
To troubleshoot this problem, you must determine which of these processes failed and why.
To determine which process failed, register Dr. Watson as the default system debugger (if it is not already the default debugger). Dr. Watson for Windows NT logs diagnostic information about process failures to a log file (Drwtsn32.log). Also, you can configure this program to produce memory dump files of failed processes that you can analyze in a debugger to determine why a process fails.
To set up Dr. Watson to trap user-mode program errors, follow these steps:
  1. At a command prompt, type System Root\System32\Drwtsn32.exe -I, and then press ENTER.
    This command configures Dr. Watson as the default system debugger.
  2. At a command prompt, type System Root\System32\Drwtsn32.exe, and then select the following options:Append to existing log file
    Create crash dump
    Visual Notification
  3. After the computer restarts from the STOP 0xC000021A error, run Dr. Watson (Drwtsn32.exe).
  4. View the Dr. Watson log to determine what user mode process may be causing the problem.
  5. If the Dr. Watson log does not contain sufficient information to determine the cause of the problem, analyze the User.dmp file to determine the cause of the STOP 0xC000021A error.
    If Dr. Watson did not create a User.dmp file for either Winlogon.exe or Csrss.exe, you may have to use a different tool to generate a memory dump file of the process that fails. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 241215 How to use the Userdump.exe tool to create a dump file
    Note Follow the instructions in the Knowledge Base article to troubleshoot a process that shuts down with an exception. While you follow these instructions, monitor the following processes to troubleshoot the STOP 0xC000021A error:
    • Winlogon.exe
    • Csrss.exe
    Note Most STOP 0xC000021A errors occur because Winlogon.exe fails. This typically occurs because of a faulty third-party Graphical Identification and Authentication (GINA) DLL. The GINA is a replaceable DLL component that Winlogon.exe loads. The GINA implements the authentication policy of the interactive logon model. The GINA performs all identification and authentication user interactions.
It is very common for certain types of remote control software to replace the default Windows GINA DLL (Msgina.dll). Therefore, a good first step is to examine the system to see if it has a third-party GINA DLL. To do this, locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Value = GinaDLL REG_SZ
  • If the Gina DLL value is present and if it is anything other than Msgina.dll, it probably means that a third-party product has changed this value.
  • If this value is not present, the system uses Msgina.dll as the default GINA DLL.
If this error first occurred after the installation of a new or updated device driver, system service, or third-party program, the new software should be removed or disabled. Contact the manufacturer of the software to see if an update is available. For more information about hardware and software vendor contact information, visit the following Microsoft Web site: - http://support.microsoft.com/gp/vendors
Last known good configuration If the previous steps in this article do not resolve the problem, start the computer by using the last known good configuration. To start the computer by using the last known good configuration, follow these steps:Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
  1. Click Start, and then click Shut Down.
  2. Click Restart, and then click OK.
  3. Press F8 at the indicated time:
    • For an x86-based computer: When a screen of text appears and then disappears , press F8. (The screen of text may include a memory test, lines about the BIOS, and other lines.) There may also be a prompt that tells you when to press F8.
    • For an Itanium architecture-based computer: After you make your selection from the boot menu, press F8. There may be a prompt that tells you when to press F8.
  4. Use the arrow keys to select Last Known Good Configuration, and then press ENTER.
    NUM LOCK must be off before the arrow keys on the numeric keypad will function.
  5. Use the arrow keys to highlight an operating system, and then press ENTER.
Notes
  • Choosing the Last Known Good Configuration startup option provides a way to recover from problems such as a newly added driver that may be incorrect for your hardware. However, it does not solve problems that are caused by corrupted or missing drivers or files.
  • When you choose the Last Known Good Configuration option, only the information in registry key HKLM\System\CurrentControlSet is restored. Any changes you have made in other registry keys remain.
  • I hope this info from Microsoft helps.
Dec 09, 2013 | Computers & Internet
When turning on it will only go to a blue screen says go to safe mode or get tech support but even in safe mode it will only go back to blue screen. Can't download anything or do anything. At the...
Try uninstalling a few unnecessary programs
Just run fewer programs or buy additional RAM click start right click on my computer select properties you will see all imformation about your computer including installed ram
or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly
click start right click on my computer,properties advanced scroll down to system and recovery open settings write and debugging information the drop down button select none
ideally, it should already be the default debugger for your system.
The Dr. Watson debugger program logs all information related to failed processes to the Drwtsn32.log file. In addition to this, the debugger program can be configured to create memory dump files related to the failed processes. You can refer these dump files to analyze the reason behind a process failure.
Perform the following steps to configure Dr. Watson as the default debugger program to record user-mode program errors:
  1. Open Start menu, select Run, type Drwtsn32.exe -I and then press Enter. This command sets Dr. Watson as the default debugger.
  2. Next, run the Drwtsn32.exe command.
  3. In the Dr. Watson for Windows dialog box, select the following check boxes:
    • Append to Existing Log File
    • Visual Notification
    • Create Crash Dump File
  4. Now, when your computer restarts after the STOP 0xC000021A error is generated, run the Dr. Watson command.
  5. Here, view the paths to the Dr. Watson and User.dmp logs.
  6. Open Windows Explorer, navigate to the log files and then open them.
  7. Here, check the cause behind the STOP 0xC000021A error.
also you might download and use this registry cleaner it is 100%totally free to use
http://download.cnet.com/ccleaner/
hope this helps you
Jul 24, 2011 | Computers & Internet
Stop : c000021a error. with blue screen I don't know what to do. I can't turn on my computer. as song as I try to turn on my laptop this error came up. my laptop is dell 1546. Peals help me
That is a memory block error. If you have the operating system disk, run a repair on the OS with the disk. If the repair fails, you will have to reformat and reinstall.
Jun 02, 2011 | Computers & Internet
My touch pad constantly freezes and is inhibiting my work flow due to restarting the notebook all the time. please help
The first cause can be fixed rather easily. Simply run fewer programs or buy additional RAM or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly...!..
also you might download and use this registry cleaner it is totally free to use
hope this helps
don
Feb 23, 2011 | Computers & Internet
Keep getting a memory dump error
this problem only can fix by reinstall your computer operating system (windows)
Feb 22, 2011 | ASUS G51JXA1 PC Notebook
When i try to shut down my computer a blue screen appears with an error report : stop:c000021a {fatal system error}
This is the cause:
The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
If possible contact a local technician to the do the below,if you are not sure of this process.
and also ask him to take a backup of your registry keys and create a system restore point without fail.
  2. At a command prompt, type System Root\System32\Drwtsn32.exe, and then select the following options: Append to existing log file
    Create crash dump
    Visual Notification
    If Dr. Watson did not create a User.dmp file for either Winlogon.exe or Csrss.exe, you may have to use a different tool to generate a memory dump file of the process that fails. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 241215 (http://support.microsoft.com/kb/241215/ ) How to use the Userdump.exe tool to create a dump file Note Follow the instructions in the Knowledge Base article to troubleshoot a process that shuts down with an exception. While you follow these instructions, monitor the following processes to troubleshoot the STOP 0xC000021A error:
    • Winlogon.exe
    • Csrss.exe
If this error first occurred after the installation of a new or updated device driver, system service, or third-party program, the new software should be removed or disabled. Contact the manufacturer of the software to see if an update is available. For more information about hardware and software vendor contact information, visit the following Microsoft Web site: - http://support.microsoft.com/gp/vendors (http://support.microsoft.com/gp/vendors) Last known good configuration If the previous steps in this article do not resolve the problem, start the computer by using the last known good configuration. To start the computer by using the last known good configuration, follow these steps:Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
Dec 23, 2010 | Computers & Internet
After shutdown my computer i see blue screen saying: stop c000021a fatal system error, please solved this problem.
Most of the time, this error occurs due to the failure of the Winlogon.exe process. This usually happens if a faulty third-party Graphical Identification and Authentication (GINA) DLL exists on your system. GINA is a replaceable DLL component that is used to perform the following tasks:
  • Implement the authentication policy of the interactive logon model.
  • Perform user interactions, such as authentication and identification.
At times, a remote control software may replace the default GINA DLL file, msgina.dll, on your computer and you may face the stop error. This is the reason why it is a good idea to first check if you have a third-party msgina.dll on your computer. To do this, run the regedit command to open the Registry Editor tool. Here, navigate to the following registry key:
Here, check if the value GinaDLL REG_SZ is on the right pane. If the value is there and its value is different from msgina.dll then it means that a third-party software has changed this value. In case this value is not there, it implies that that your system uses msgina.dll as the default DLL file for GINA.
If this error follows a new driver, service or third-party software installation, you must try to uninstall this new software to repair the error. To do this, you may use a good third-party program uninstaller tool, such as Perfect Uninstaller to ensure complete removal. You may also try to install an update for the software, if it is available.
You may also try to boot your computer with Last known good configuration information to see if the error goes. If nothing works, you may have to perform and in-place upgrade of your operating system to resolve the error.
utmx_section("bottomad") Additional Recommendations...
Driver Update: Many errors are related to driver problems such as obsolete, outdated or incompatible drivers. A driver update tool is recommended to scan your system for corrupted and outdated drivers and to ensure that all your drivers stay up-to-date.
hope this helps
Nov 17, 2010 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
526 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
