Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Ok, hopefully someone can help me. I own a 2006 Vento Phantera 150 CC bike. It only has 930 miles on it. Over the last few days I have noticed it sounds pretty loud. Normally I would think that adjusting the carb would help. Except it is Fuel Injected & has no Carb. Anyone have any suggestions?
  • tmb8193 Oct 16, 2008
    Thanks. That was exactly it. The bolts had actually fallen off. Thanks.
  • 216 Answers
Dont know a thing about that model... but, I'd check the exhaust pipes and see if any bolts are loose
Posted on Sep 21, 2008
Why is my dtf 150 not shifting
it may or may not be likely but some other bike brands maybe compatible with your bike's parts with in the same CC range...but im only hopeful that it does work out for you best of luck pal
Apr 17, 2017 | 2006 UM DTF 150
HI WHERE CAN I BUY PARTS FOR THE 2006 VENTO V THUNDER ?
Hello Jr, Vento parts are getting harder to find. Here are a couple of links for suppliers that still carries a few Vento parts. Also, check ebay for parts.
http://www.genuinemotorcycleparts.com/
http://www.scooterpartsexpress.com/index.php?route=product/product&product_id=278
Depending on what country you are in, you can try contacting Vento.
I hope this information is helpful.
Oct 09, 2011 | 2006 Vento V Thunder XL
My engine just stopped running. There is no fuel pressure. I took the fuel pump apart and the diaphragms appear to be good. There is a line that goes to the fuel pump marked "P" . It comes from...
Hi, Wiley the following is a systematic procedure for diagnosing fuel pump issues designed to keep "DRACHMA" to a minimum. If you need parts check with Amazon and eBay first to keep costs down.
1. If your pump does not turn on check the pump fuse and relay and all wiring including connectors for corroded, broken, or loose pins/sockets.
1. Normal fuel pump pressure is 3-5 PSI.
2. Check any rubber or plastic tubing for age-related pinholes by removing and plugging the ends that connect to the fuel valve and then turn on the ignition switch and watch for fuel streams exiting the pinholes, if any exist, replace tubing as necessary.
3. Check for a clogged a primary fuel filter that comes off the bottom of the pump to screen out big rocks and clean as necessary.
4. Check for a clogged secondary fuel filter that's outside if applicable by removing it from the system and replace it with a short splicing tube turn on the ignition switch and recheck fuel pressure if pressure increases to normal pressure you need a new secondary filter.
5. If all the above check out OK and the pump is not functioning properly then you need a new fuel pump.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2007 Vento Phantera fuel pump not working Google Search
Vento Phantom R4i Service Maintenance Manual
Scooter Parts for Chinese Scooters Atvs
Vento Phantera 2007
https://en.wikipedia.org/wiki/Vento_(motorcycle_manufacturer)
Apr 26, 2017 | 2007 Vento Phantera
I have a 2006 vento 150 cc scooter 48 miles on it and hasn't been started in 3 years Q - DOES IT A SPARK PLUG TO CHANGE Q- SHOULD I DRAIN THE FUEL OUT AND IS IT USEABLE IN THE MOWER OR WEED EATER
hi.
if it has not been started in 3 years then a new spark plug would probably be a good idea, but not essential if the old one is cleaned.
3 year old fuel should be drained and is pretty much no use for anything. you may be able to start a bonfire with it, but i would not even try to run a machine on it after 3 years.
it would also be a good idea to change the oil and clean the air filter. the battery will almost certainly need changing as well.
there should not be any major problems though.
hope this helps
Jul 17, 2011 | Vento Agility City 50 Motorcycles
2006 CBF 600 S ABS: Found patch of oil about 2.5cm diameter directly b...
this might just be oil from when you lubed the chain..dont worry! feedback would be appreciated.
May 06, 2010 | 2006 Honda CBF 600 S ABS
I need The Vento V-Thunder 250cc motorcycle batery
Vento vthunder battery and all other parts are at www.scrappydogscooters.com
May 01, 2010 | 2006 Vento V Thunder XL
Intermittent not starting Vento motor scooter...
You have what thay call a GY6 Motor it'sa honda knock off clone Chances are you eather need a CDI box Or Coil both prety cheep you have no points or condsider on this bike i have the same motor go to www.scootdawg.com form for for all the info you need including how to test them. one other thing check you valcume hoses and fule filter as well
Dec 29, 2009 | 2006 Vento V Thunder XL
2001 nomad, has power commander, vance and hinse exhaust and hyper charger. Bike starts but miss fires. Bike seems to run better uphill then down hill. It started on day on a ride when the bike just died...
DRAIN CARBS FROM PETCOCK AT BOTTOM OF EACH CARB MAKE SURE FUEL DRAINS COMPLETELY THEN TURN FUEL BACK ON, IF THIS IS AN INJECTED MODEL DRAIN TANK AND FLUSH THEN RUN IT HARD FOR 20 MILES OR SO, MAKE SURE YOUR OIL LEVEL IS OK
Oct 04, 2009 | 2001 kawasaki VN 1500 Vulcan Classic...
2006 F-150 Bad Brakes
I had a simailar problem with my 2006 F-150 Brakes and this was after bringing it in for the recall mentioned above ( Recall 08505) The brakes were good until I had about 34K miles and then one day
the brakes started to grind and screach when applying brakes at low speed. As the above reader had stated, No warning! I do not understand in a day of high technology that ford does not have a senson that indicated your brake pads have worn out. This truck has been a pain in the 2 years of ownership, it has been in the service department for a transmisssion problem ( 4x4 Transfer motor replaced)
power stearing pump replaced and the recall, now the brake issue. Now I know why more guys are going to Toyota or Nissan Full Size Trucks. This is my last Ford Truck!
Jun 19, 2008 | 2006 Ford F-150
Lands Phones Logo
37 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
