Question about Samsung Cameras
Lens is stuck and wont recede back into camera for the L200 series
  • bbeilmann Dec 25, 2008
    just got the darn thing picture is blurry and lens wont retract on power down have to power up and down strange seems like its junk Samsung should fix or give up the camera industry frustrated@@@@@@
Thats what happening with mine but mine is a ixus75 ? HELP
Posted on Sep 20, 2008
The lens on my L200 wont go back in.
lens unit is defective,get it serviced.
Mar 27, 2010 | Samsung L200 Digital Camera
My samsung L200 digital camera fell down on the lens part and now its stuck what can i do?
Try all of the below methods only if your camera is out of warranty. If it is still under warranty, DO NOT pull on your lens while turning the camera on, whatever you do; you will destroy it, guaranteed.
Be especially careful when dismantling a camera to avoid an electric shock.all the circuitry boards contain cmos technology components, that will fail if not operated on in a esp safe enviroment,
do not remove the covers in any case. even if you would manage to free the lensblock you will do damage to the circuitry board just by exposing it to static electricity.
  1. First, make sure your camera has fresh batteries and it is in recording mode.
  2. Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
  3. Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
  4. Another method is to tap the padded USB cover part on a hard surface, for example, a desk. Sounds simple, but it works.
  5. Try forcing the camera lens. Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended. Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a click as it pops back into place. If the lens is stuck at an angle, put the edge of the lens not the flat front, on the edge of a table and press the lens back towards the center. It will either click back in place and work or it will break off one of the three pins that ride in the grooves of the lens barrel. Try powering the camera back on.
  6. If the lens doesn't extend at all or it extends and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a click as it pops back in place. Power the camera on.
  7. Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a click. If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
  8. If none of the methods work, you can dismantle the camera and try to clean the lens. .
Oct 11, 2009 | Samsung L200 Digital Camera
My lens seems to be stuck
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u rate me!!!
Jul 10, 2009 | Samsung L200 Digital Camera
My l200 camara lens is stuck
huSh now :( I remember my former camera.. XD
Lens errors are fairly common. Usually it's sand or grit interferingwith the lens extension mechanism. Or the camera's been dropped withthe lens extended. Or the camera has been powered on, but the lens hadbeen blocked preventing its extension. Or the battery ran down with thelens extended ...
Here's some things that you can do to try to correct it. They only seemto work for less than 50% of the lens errors, but if the camera is outof warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12...
hope this will help ya out
Jun 06, 2009 | Samsung L200 Digital Camera
Camera Lens Stuck Closed
I am having the same problem. Were you ever able to resolve yours? Thanks!
May 02, 2009 | Samsung L200 Digital Camera
How to fix my lens from my coolpix s200
Sent it for repair - pricey
or buy the next camera
Cameras like computer parts and other small electronics are considered 'Disposable' usually
Oct 12, 2007 | Nikon COOLPIX S200 Digital Camera
Cameras Logo
88 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
