Question about Rosieres Washing Machines
Washing machine door wont open
I have waited the allotted time after a cycle has finished on my rosieres washing machine but the door wont open and when i push the button to do this there is no resistance were there is normally. Can you help
  • 3,230 Answers
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Posted on May 19, 2009
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
My machine has stopped half way through the cycle, hasn't rinsed or had it's final spin and says DOOR on the display. The door is properly closed and now wont go on ant other program or fill up with...
Try a reset of the washers' operating sytem by unplugging it, waiting a few minutes and then plugging it back in. It may restart the cycle all over or it may do nothing and allow you toopen the door. If you do finish the cycle and/or get the door open, check the seal thouroughly to make sure there is no debris and/or coins in the seal. It would be a good time to clean the seal as well with hot water and a soft cloth if you have not done so recently.
Let me know if this works. If it does not , please let us know the make and model of your machine.
Dec 19, 2010 | Washing Machines
When washer starts it usually makes a clicking noise know it is humming and nothing happens the door is locked and wont open
your main belt is broken or loose i would suspect the latter,the reason the door will not open is the machine has started a wash cycle and because the belt is not able to finish the cycle the door wont open so the progam is not finished,switch the machine of at the mains and the door will open after 10 mins.But the problem remains the belt.please rate this answer thanks.adrian,,,,,,,,,
Aug 23, 2010 | General Electric WCVH6800J Front Load...
When the remaining time is one minute but wait for long time but can not open the door
The door locks need to 'cool down' after the end of the cycle. So with one minute remaining you will have to wait for the cycle to finish this minute and a further 2 minuter approx for the door to release. Thats how the machine is designed to work unless there is a seperate door release feature.
If there is you should find the instructuions in the hand book
Cheers
T
Aug 07, 2010 | Washing Machines
Kenmore washer, model c45092
in all cycle with seven min left washer, m-c45092 stop and door open no spin cycle. pete.
Apr 19, 2010 | Kenmore 45081 Front Load Washer / Dryer
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
I can't open the door of my washing machine it is a front loader lg intellowasher 7 kg wd8013c please help asap
FOR ANY REASON THE WASHER MACHINE DIDNT FINISH ITS CYCLE!!! AND IT IS A SAFETY THAT IF DOESNT FINISH ITS CYCLE THE DOOR WONT OPEN!!!!
I HAD ONE LIKE THAT AND I BROKE IT APART!! AND I SAW THE WATER PUMP WAS THE PROBLEM SO I CHANGED IT AND PUT IT BACK TOGETHER AND LET FINISH ITS CYCLE AND OPEN THE DOOR!!! AND STILLS RUNNING!!!
Oct 05, 2009 | Washing Machines
Can not open the door after cycle is finished
i think you are talking about a front loading machine, have you waited for at least 3 mins before opening the door?
these types of washing machines locks the door in order to run. but after a cycle is finished, the door would not open right away, there is a delay on opening the door.
let me know what happened,
tnx 4 using fixya,
drcool
Sep 19, 2008 | Washing Machines
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
279 people viewed this question
Top Rosieres Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Rosieres Washing Machine Expert? Answer questions, earn points and help others
