Samsung HT-THQ25 Video & Audio Problems
I have the above Home Cinema system and it worked fine up until this weekend, now when I switch it on it loads up the disc thats in the tray and then the sound goes and the picture becomes corrupt with all coloured lines horizontally, it just stays like that until I power off and power back on. This happens regardless of disc or no disc in drive, also when the unit is on AUX input the sound cuts out after 20 mins...!
Can anyone help?
Thanks
  • 10 Answers
SOURCE: 3 year old samsung audio/video 5 disc player keeps
your a ********, the cd player is rooted
Posted on Jan 07, 2010
  • 29 Answers
SOURCE: NO SOUND From JVC TH-S5 Home cinema system
First, make sure it didn't get muted, or the remote's volume got turned way down. Next, it might be time to involve a technician who can check all the power supply voltages. Many of today's electronics have multiple voltage power supplys, 5 volts for logic, 12 volts for motors, and amplifiers usually have the biggest- maybe plus and minus 30 volts for a total of 60. There are hazardous voltages in there too, a switching power supply starts with over 300 volts. So don't lick it and see if your tongue tingles, that's only for 9 volt batteries.
Posted on Jan 29, 2008
SOURCE: Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
Posted on Nov 26, 2008
  • 7 Answers
SOURCE: no sound through my lg home cinema system when watching tiv
fiirst of all you should buy a converter..........which has a multiple use
Posted on Mar 04, 2009
ginko
  • 19396 Answers
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Samsung dvd player switches itself onto protect!
hi,i can't connect my audio tv to cinema theater dvd
Apr 02, 2010 | Televison & Video
Hi, Ive tried to set up my samsung blue ray
It seems as though the HT works fine, so to get the TV itself to play through the HT setup, take the audio out from the TV and hook it up to a separate channel on the HT receiver. Turn on TV and receiver and put the receiver on the respective channel of the receiver. I hope this helps.
Oct 26, 2009 | Samsung Audio Players & Recorders
Need to enter a remote control code on a Panasonic TX-P42V10B remote control unit to operate a Samsung HT-THQ25 home cinema. cannot find any codes that are listed to work
Samsu ng 0 0 6 0 ,0 0 3 0 ,0 1 7 8 ,0 0 5 6 ,0 0 1 9 ,0 0 3 2
Hope one of thyese work for you as these are the only ones listed for Samsung Home Cinemas
Please rate our help to keep the free service onlime++++Thanks for using FIXYA
Sep 22, 2009 | Televison & Video
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Mar 18, 2009 | Samsung HT-A100T Theater System
Samsung HT-A100 Home Cinema system remote interferes with tv!
Some remotes have facility for changing frequency to avoid conflict. Check yours out for this feature.
Aug 29, 2017 | Samsung HT-A100T Theater System
Home Cinema Samsung HT Z310R- Speakers not working with TV
You need just one cable that goes from your TV to your HT system.
On your TV you should see an RCA jack for "AUDIO OUT" and you need to plug that into your AUXILLARY "AUDIO IN" on your HT system
When you are watching TV and you want the sound to come through the HT system, just set the HT system to "AUX" mode. Most Samsung systems will have 3 'AUX' modes, set the remote on 'AUX 1' then wait a few seconds, if no sound comes through then set it on "AUX 2" wait a few seconds and if it doean't work try AUX 3.
Hope that helps.
Gary
Feb 11, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Feb 02, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
No sound through my lg home cinema system when watching tiv
Oct 30, 2007 | Samsung HT-X40 System
225 people viewed this question
 Grubhead
Grubhead
