RCA DLP television lamp problems
I was told to take the lamp out and shake it alittle, I have taken it out, but not sure if taking it out and handling it would be the definition of shaking it alittle, what would be the purpose for shaking it, to see if its bad?, or to shake it into submission, please explain for me.
    Genius:
  • 2,920 Answers
Yhere is no reason to shake the tube...either they are good or bad and it sounds like what you are dealing with is a bad tube
Posted on Sep 20, 2008
DLP television picture not clear (blurry) and dark.
Hello
If picture is dark in DLP TVs, its lamp should be taken care of. In some lamps, the reflecting side coating of lamp will be bubbled, preventing sufficiant light to fall on DLP chip. Replace the lamp if necessary. Check it first, taking it ouside. OK.
Apr 15, 2011 | Mitsubishi Televison & Video
I have an RCA DLP tv model HP50LPW52. the sound was there with no picture. since it is 5 years old I replaced the lamp for the first time. got it all hooked up, turned it on and the tv slowly came on....
That is your Color Wheel that is bad. I wish you would have posted the problem before buying a lamp. I would have told you to treat yourself to a new set instead of putting good money into a DLP set that is 5 years old.
Feb 10, 2011 | RCA Televison & Video
The picture is not bright in a light-filled room. Will a change of DLP lamp help? Are there different lamps that will improve picture quality?
Yes.Depend how old is ur DLP tv,the Projection Lamp only a light source,mostly depended on the Light projection Engine itself.Get the original RCA DLP lamp or same lamp model now inside the tv,will help and work best for ur tv.Just don't get generic DLP tvs lamp,it cheaper poorer quality.
Dec 17, 2010 | RCA HD61LPW167 61" HDTV
RCA HD50LPW42 dlp, does not turn on
If capacitors are swollen,vented or puffed up on top replace them .You may just need to replace your Lamp.CK all fans make sure they are running. Mats Electronics has Best Price for Lamps 1-800-628-1118
Let me know if you need more help.
Mar 23, 2010 | RCA HD50LPW42 50" Rear Projection HDTV
My 50 inch rca dlp tv will not turn on... the power light comes on but no sound nor picture. we had the bulb replaced about 6 mnths ago and and i know its not that. any suggestions?
Dont be to sure about LAMP,I have seen where NEW lamps can take nose dive, But try Ballast board that fires up Lamp,if it is Bad Lamp will not fire.
Aug 19, 2009 | RCA Televison & Video
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Hi I have a RCA DLP rear projection television and I think the bulb was jarred by me moving the tv from one room to the other. I tried tightening the screws but it still does not work. The tv turns on and...
Good Day;
You may have a bad lamp not a loose one, take lamp out of TV and shake it a little and reinstall. If no fixya get new lamp and possible ballast. Good Luck, big IRISH.
Sep 20, 2008 | Televison & Video
RCA 50" dlp lamp dead?
There are many different problems with RCA televisions. One could be a color wheel. Another could be a bad ballast. www.Lamp-Replacement.com has a guide and solutions for your RCA lamp 265866 or 270414. The problem is most likely a bad ballast, which is supposed to pre-charge your lamp and ignite it. If you aren't even getting to that stage, you can trace the problem to another component or power supply.
Sep 01, 2007 | Televison & Video
You will need to have it diagnosed if you do not have the service manual, or the knowledge of how these circuits work. I can tell you to replace this or that but it would be a guess! You need to start measuring the voltages on the ballast circuit, as I have seen door switches, fan sensors, heat sensors cause all of your symptoms as well. Good Luck
Jul 24, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
