SOURCE: Craftsman rotary tool doesn't lock down on the bits.
the collet is either the wrong size for the shaft on the attachment or is missing alltogether
SOURCE: Broken Dremmel tool spindle stop turning but motor runs
I called Dremmel tech support FOR FREE and they told me what was broken - flex coupling between shaft and spindle. Only Dremmel model 395 type 2 and 3 have these couplings. Mailed out repair kit yesterday.
SOURCE: I Need a new lock
I cant see where Dremel has a parts listing for this tool and checked another site with no luck, BUT I have a number for Dremel that you can call to see if they do offer this part, it is 1-800-437-3635.
Adjustment
Removal & Installation
NOTE
The following procedure may be used to remove shoes on either side of the vehicle.
Fig. View of the actuator (1), support (2), adjuster spring (3), return spring (4), caliper adapter (5), shoes (6), hold-down clips and pins (7) and adjuster (8)
Adjustment
This vehicle is equipped with permanently sealed rear wheel bearings. There is no periodic lubrication or maintenance recommended for these units.
Fig. Hub assembly
Fig. Rear hub and bearing mounting bolts
