Question about OWC Mercury DVR-105 (OWCMRFWD105) DVD-RW Burner
Lost power cord
I need a replacement power cord for the dvd burner. 5-prong cord supplies power. Where can I buy one that works?
  • bradrobbins1 Nov 10, 2008
    I have the same problem - looking for a 5 prong 12v/5v power cord replacement for a Philips DVD Writer SPD3100CC
I need a power cord, any advice? Thanks! -Chuck
Now please bear with me. From what I can tell on their site and assuming that they use the same power cables for all their equipment (which would be the most efficient thing to do) they use a non standard 3 prong plug. You should be able to see one here and tell for yourself (seeing as you have the equipment). Best of luck.
Mar 24, 2011 | PDE Technology ZipSpin DVD CD Master...
The cord that plugs in the outlet...3 prongs is on it the one on top came out is my lappy still safe too use with one of these prongs gone
HI there,
The top prong is the grounding prong. To continue to use the power cord without it opens the possibility for a situation where your laptop is more susceptible to a surge that could seriously damage the motherboard or components attached to it.
I highly recommend you replace the cord which you should be able to get easily at Best Buy, Fry's or another retailer that keeps common laptop replacement parts like that in stock.
Sep 18, 2010 | MSI (L250-510-620) (S930401010L05) Power...
I lost my power supply cord when I moved. Where can I find another for a model USB 1930-52?
Hello,you can buy one AC to DC voltage converter (usually 1000mA) - which comes with multiple output tips and you manual setting the Volt that are required by your burner(check behind of your burner near the socket that you plug the power it should right ..Volt and the mA or AMP) and adjust the converter
Jan 20, 2010 | Pacific Digital X-treme CD-RW Burner
Need to replace lost power cord fpr back pack bantam 181100
the factory power transformer is 5V 1 A model TRX-022A input is AC100-240V 50/60 Hz 0.15A output DC5V 1A
Mar 09, 2008 | Micro Solutions Backpack Bantam Triple...
Re:power a/c cord for pacific digital
if you have the power supply aka the brick and just need the cord from the brick to the wall, a PS2 power cord works just fine! I found that out by accident, but since PS2 is very popular chances are you can find one at any store or on ebay. from the brick to the round post on the back of the device, I don't know about that one...but if you just lost the one piece..the PS2 works fine
Mar 01, 2008 | Pacific Digital (U30274) DVD±RW...
Won't Recognize Blank Maxell DVD+R Disks that I Try to Burn!
sounds like your loose 4 prong may have shorted the burner drive on a power on- it may just be that simple- it died...
Jan 15, 2008 | Lite On Lite-On LH-20A1L-06 SuperAllwrite...
Lost power cord for Polaroid PDM-1058 portable DVD player
I've looked for the same thing and the only place I can find it is eBay for about $25
Nov 08, 2007 | Polaroid PDM-1058 Portable DVD Player
OWC Mercury DVR-105 (OWCMRFWD105) DVD-RW Burner Logo
29 people viewed this question
Top OWC Mercury Computers & Internet Experts
David Payne
David Payne
Are you an OWC Mercury Computer and Internet Expert? Answer questions, earn points and help others
