Question about Samsung CLP 300 Laser Printer
Printer is making a loud noise when printing.
  • steve shroder May 11, 2010
    you seriously can't expect to get help with no information can you?
    Problem Solver:
  • 10 Answers
1. Make sure nothing is jammed in the paper feed.
2. Remove and reinsert the toner block, checking for obstructions while it is removed. ( the thing with the green pull lever. First thing you see when you flip open the front cover. Can't miss it)
3. Open the very top door flap, see if anything is jammed in there.
Those are general tips, but with the vaguity of your problem description, there is very little else anyone can do.
Please be more specific if none of these general techniques fix your problem, otherwise your problem will never be solved.
Posted on Oct 02, 2008
flopez
  • 161 Answers
SOURCE: Oki C9500 makes VERY LOUD clunking noises but prints fine...
The sound is most probably from one (or more) of the drum units. You can check by taking them out and trying to run the visible gears by hand. If you have spare drums, change them one at a time until you find the defective one.
Posted on Sep 26, 2007
myob247
  • 1342 Answers
SOURCE: makes noise
Click HERE for HP troubleshooting for your printer.
Posted on Jun 07, 2008
  • 4 Answers
SOURCE: samsung 3160fn all in one
Here's what I posted in regards to my CLP 300 which had the same problem. Might be the same thing??...
Mine did this after I replaced a toner cartridge (the round ones). Here's what causes the loud clicking:
Some (most?) replacement ink cartridges have a little square chip -- like a mini circuit board -- on them which gives the printer information about how full they are. This is located on the insertion end, right next to the round black thing with the little gears on it.
For the cartridge to go in all the way, and allow the gears to properly "seat," the square "circuit board" needs to "float" just a little on the spongy thing it's attached to. So when you push the cartridge in FIRMLY, the gears seat, and the "circuit board" will end up getting pushed in about 1/16 of an inch.
I think what happens in some cases (at least with mine) is some cheap replacement cartridges don't let the "circuit board" push in at all, which means the gears don't quite seat properly, and, as they are trying to connect on the printer's gear receivers, they are constantly connecting and disconnecting, causing that loud clicking noise.
On one cartridge just pushing in the "circuit board" really hard freed it up and allowed it to "float" (be pushed in little when the cartridge was then inserted). In another case, I ended up getting a butterknife and prying off the circuit board (breaking the plastic or glue seal that was holding it) then setting back in, on top of the little spongy sticky thing it's supposed to float on.
In both cases, the cartridges were then able to go in all the way, and the clicking noise stopped.
Hope this helps!
Posted on Aug 06, 2008
  • 30 Answers
SOURCE: VERY LOUD NOISE WHEN PRINTING WITH MY SAMSUNG CLP-300
You all say that the toner cartridge is okay, so it could be the hole OPC Image Drum or the ITB which is the tranfer Belt.
The Tranfer Belt is behind the Image Unit.
Posted on May 28, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Printer making a loud clicking noise when printing.
the feed roller gear is stripping; remove the cover and, adjust the gear retainer before it completely fails. (it should be easy to see the gear once the printer cover is removed.
Posted on Mar 30, 2010
Why is ricoh 6330n making a loud noise while it is printing?
Check the transfer roller (the sponge roller) there will be a gear on that roller. Lubricate is with some spray on lube.
Aug 11, 2014 | Ricoh SP 6330N AllInOne Laser Printer
Lexmark c772 when printing it make load Laud noise
Please power off the printer. Remove all the toner cartridges. And then put them back in. Make sure you install the toner cartridges properly. After that power on the printer. Try printing again.
Jul 20, 2012 | Lexmark C772dn Laser Printer
I have HP laserjet 1018 printer and it makes noisy sound when it prints. But it prints fine though. What causes making this noise?
The noise is probably due to the print heads aligning and clicking. To try to make this noise a little quieter, clean and align the print heads.
Mar 23, 2011 | HP LaserJet 1018 Printer
Mar 30, 2010 | Dell 1700n Laser Printer
When printing, the printer makes a loud sound
I first guess that it is the drum going out. If you have changed the drum......it is more than likely your fuser. Have you ran a supply check to get the status on your supplies?
Feb 18, 2009 | HP LaserJet 2840 Printer
Dec 19, 2008 | Samsung CLP 300 Laser Printer
Makes noise
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Sep 04, 2007 | OKI C9500dxn Led Printer
Samsung CLP 300 Laser Printer Logo
284 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
