Waste Toner Light won't go off?
Getting an "error Message" saying to replace waste toner. Ordered a new one, but it hasn't arrived & printer won't allow me to print anything. Vendor suggested I "Empty the waste toner" I did that & replaced the waste toner & the light is still on, although it's completely empty. I am not able to activate any of the front panel buttons, escape won't work, nothing does, even shutting the printer off does nothing, like keeps appearing. What can I do? i am very upset regarding this used toner bottle full message appearing on my ricoh aficio 2045e copier...i cant copy documents. i tried cleaning the machine. emptythe waste toner bottle but still the error message kept on blinking? i think i need to reset the machine, but i do not know how...please help me as soon as possible...got a lot of books to copy....it will be taken on monday....
  • bing27 Sep 21, 2008
    I can do it...please assist me please.
  • Fujimoto Jan 14, 2009
    Where do I find the Waste Toner Bottle to empty? We cannot find it...
Just clean out the transfer belt
Posted on Jul 25, 2011
  • 162 Answers
Some times some of cables of the sensor of waste toner these is cut are generally in the later part of the right cover with a red connector. And this causes the fault by more cleaning than it is the transference unit, verify that they are well and if is not thus corrects the problem this restores the problem.
Posted on Oct 21, 2009
  • 1,326 Answers
If I am correct this Ricoh and others re-use the waste toner from the drum unit. I remember this same problem. The Waste Toner that it want's you to empty out is acturally in the Transfer bealt area. The waste toner is the waste from the transfer bealt unit. It is inside the middle of the unit. You are going to have to take it apart or call for a service tech to do it. Let me know if you think you can do it....
Posted on Sep 21, 2008
  • Chris Coughlin
    Chris Coughlin Sep 22, 2008
    When you open the right side door you will see the trans fer bealt "Redish Brown", There is a grey plastic handle towards the front of the door next two the transfer unit. Lift the lever up and the transfer unit will lift out, push the top of the unit to the left and remove it from the door. Once it is out, there is one screw on each side of th unit and two spings, remove them and the fold the up the gear side of the unit and the bealt should be loose, remove the bealt and you will see a cleaning blade and a cover with six screws and remover the cover. Be very carefull, there is alot of toner in that box and it is packed in there, either use a vaccum or dump it in to a plastic bag, you don't have to get all of it, but try too. Put the unit back togather the same way you took it a part. You should be all set once it is back togather and turned back ON. There is a sensor inside that unit, that shows that it is full and it must be emptied to reset the code, there is not a counter to reset.... Good Luck
A printer,s ink pad is at the end of its service life
This means the waste ink collection sponge is full. This counter can be reset but it is strongly recommended to replace the ink pad as you will end up with a large amount of ink spilt on your desk if you continue to use the printer after the pads lifespan. It can be quite a large job to change depending on the model. If the printer is not an expensive model it may be more cost effective and less messy to simply replace it with a similar model.
Jan 14, 2017 | The Office Equipment & Supplies
I replaced the K cartridge and i get this caution. I-Unit End Replace K
If "[Color name] Toner Empty. Replace with a new toner cartridge." is displayed and printing stops, replace with a new toner cartridge.
([Color name] indicates one of the following: C or Cyan, M or Magenta, Y or Yellow, K or Black.)
Jan 10, 2017 | The Office Equipment & Supplies
My sharp color copier Mx 3100n is indicating F2-73 after using 88-1 how do I restore it
Hello Tijjani,
The error code that you are experiencing is as follows;
F2 73 IMPROPER TONER CARTRIDGE DETECTION (YELLOW)
You need to replace the yellow cartridge with the proper part # Item Number: MX 31NTYA, MX31NTYA.
Good Luck!
Rich Lilja
Jan 08, 2017 | SHARP MX-3100N
Bizhub C250 using to much toner. Images are very dark. Ink can even be rubbed off pages. How do you adjust?
Check that the fuser is not in enevople mode. two green handle up not down. check the files
Oct 28, 2016 | Konica Minolta bizhub C250 All-In-One...
How do i solve an error e000-0000 canon ir 2202 please
Dear
Its related to the fixing temp. do the error clear on service mode. then check the fixing film assy. heater circuit contact points for corrosion. Replace it.
Thanks.
Dec 12, 2014 | Canon Office Equipment & Supplies
Colour cyan not printing
Did all of the packaging come off the toner successfullywhen first installing. Can you see cyan toner on the transfer roller? (Black roller on actusl cartridge)?
Dec 08, 2013 | Office Equipment & Supplies
Hello i have problem with old samsung...
considering the cost of new up to date printers I would consider junking it and get something under warranty that there are driver up dates for.
Sep 20, 2013 | Office Equipment & Supplies
Laser printer makes light clicking noise when idle
When idle is potentially the fuser unit, after heating and cooling. However the print quality issue associated with the clicking sound could indicate an electrical issue. The HVPS maybe faulty causing the print quality issue (due to dependant parts) and the electrical click. In any case I would recommend calling Brother and finding the nearest authorised service agent.
Oct 20, 2012 | Brother Mfc-9840cdw All-in-one Laser...
652 people viewed this question
k24674
