Looking for AIWA CR-LD121 Radio Reciever. If anyone has one for sale or where I can buy one!!
  • teedoff1980 Sep 30, 2008
jackiaria
  • 350 Answers
SOURCE: Aiwa CR-LD120 AM/FM Radio?
This is a common problem when disconnecting power!
Try buying an ac adapter at your local pharmacy or radio shack and plug it in before changing batteries
Posted on Feb 08, 2009
I dont know my car radio code
Take It Out And Look On The Back Of It..DONE!
Jun 14, 2013 | Audio Players & Recorders
No Sound
It seems to be that the antenna is at fault. If you can take it apart, you should resolder the antenna.
Nov 10, 2007 | Aiwa CR-LD120 AM/FM Radio
My Sangean ATS 808 AM/FM/SW Radio reciever shows a flashing E on startup and won't operate. Any answers on resetting or other solution?
Hello, I assume that this only happens when you are using it on batteries and the unit works when plugged into the mains. If this is the case it most likely is a faulty or dirty connection in the main battery chamber. Clean all contacts reload new batteries and try again.
Oct 17, 2010 | Sangean ATS 808A AM/FM/SW Radio
How to: Aiwa CRDL101 am/fm stereo (2x4 handheld unit) no manual
Sony bought Aiwa in 2002. You can download the manual from Sony's web site at
http://www.docs.sony.com/release/CRLD101.pdf
Jun 24, 2010 | Aiwa CR-LD101 AM/FM Radio
Aiwa CR-LD120 AM/FM Radio?i program my radio stations, but when i have to change batteries i lose all the stations and have to reprogram them
Feb 08, 2009 | Aiwa CR-LD120 AM/FM Radio
No sound in one ear
Have the volume control to be repaired, they a cellphone repair shop. If they can't... suggest to bypass the volume controls to its maximum control and buy an earphone that has volume control on it.
Jan 02, 2007 | Aiwa CR-LD120 AM/FM Radio
162 people viewed this question
 Grubhead
Grubhead
