Question about 3Com OfficeConnect Wireless Router
3Com Wireless 3CRWE52196
Hi, h r u, hope u fine, pls help to setup my 3Com Wireless 3CRWE52196 rounter, if i had been forgoter my username and password. TQ!
  • kbagroup2020 Sep 24, 2008
    Hi, I would like to inquiry, how to setting a password on my 3Com 3CRWE52196 (Office Connect Wireless Cable/DSL Gateway) to prevent other people sharing internet with me. TQ!
  • 19,396 Answers
If you lost your Internet user ID and password you need to call your Internet Service provider technical support number and follow the step-by-step instruction provided by the operator.
The procedure require interaction and information on your specific account, that is the reason why you need to call ISP.
If you do not know ISP number, post details your location and internet company (EG: I live in Mexico, I have AT & T internet), possibly on a new request on Fixya, as sometimes follow ups on old questions go unnoticed.
Posted on Sep 20, 2008
I forgot my paswordhow do i reset it
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
Apr 19, 2012 | Linksys WRT54G2 Wireless-G Broadband...
Forgot my wireless internet password
You have to login to router ,for wireless password
following is the way to login to router
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. If WPA is selected in Security mode, then check the Password that show up in the passphrase box.
Hope it can resolved your issue
please rate the service if issue resolved
Thanks for using Fixya
Apr 04, 2010 | NetGear WGR614 Wireless Router
Hi I have a 3Com NBX V3000 and i forgot the password what I can d
You must make sure to use the correct username. The only username that can be used for administrator is administrator (ALL LOWER CASE). It is case sensative and can not be capitalized. You typically have to open a case with 3Com to get the current password. There is no "backdoor" way to gain access or change the password but if you have console access to the system you can enter the nbxDb command and get an encrypted password. If the system is running a software version 4.0 and older then the password is unencrypted and you are done. I can get the encrypted password decrypted if needed.
Feb 10, 2010 | 3Com NBX® V3000 (3C10600BUS)
Need to know how to install rounter with out start
following are steps for manualy setup of router
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
regards
prakash
Dec 23, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
I forgot my password, I have 2 reimaged computers and no software
Are you running wireless or wired. If you are runniong wired there should be no software required. If you re running wireless you are going to need to reset the router. There is a small button on the back press and hold for 15 seconds. This will reture the router to default settings. The default for your rounter is Username=do not input anything in this field. Password=admin. Once there you should beable to reset everything.
Sep 24, 2009 | Linksys Wireless-N WRT150N Router
3012 3com router
Just find the "reset" button that can be pressed by paperslip and this will reset router back to factory settings
Sep 14, 2009 | 3Com RTR 3012 Router (3c13612-us)
3Com OfficeConnect Wireless 11G password
Press reset button on the rear of the unit for 5 secconds, then by connecting your moden in to yor laptop go to the following web page: http://www.3com.com/products/en_US/detail.jsp?tab=support&sku=3CRWE454G72&pathtype=purchase and there you will find the software and manual for your AP (access point) the software will let you setup the device from scratch. the default password is admin. hope this helps.
May 23, 2009 | 3Com OfficeConnect Wireless 11g Cable/DSL...
I forgot the username of dlink wbr-1310 wireless router
As an initial info try to do a hard reset on the unit, this process will restore the system into a original settings. you can find the reset switch on either on the left of right sight of your router.
or
you may visit this SITE to recover again your current password without erasing or removing the current settings made.
Reset Password.
Hope this idea helps you.
Thank you for using fixya.
Nov 20, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Passphrase
Since you forgot the security ket for the wireless network you need to access the router setup page using the a computer that is working fine with the router,
On the internet exploreer address bar of the working computer type in 192.168.1.1 , then that should be asking you for a username and password, just leave the username blank and password is admin. If tha admin password didn't work try typing your commonly use password.
If you're already on the setup page of the router, Just go to wireless tab then there's a wireless security sub tab there where you can find the security key that you need...
Hope that helps...........
Sep 07, 2008 | Linksys Wireless-G Broadband Router
3Com OfficeConnect Wireless Router Logo
366 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
