Question about Accutek AOJ-1601 Stand (Pedestal) Fan
Accutek Mod. NAJ-0611PX Stop Working
I had an Accutek fan before for quite a while. The axle began ceasing up and then stopped working. I assumed the it ceased up while blowing in the night and burn up the motor.
I then went a bought a new fan. Same Accutek but model NAJ-0611PX thinking that it would serve as long as the other. I turned it off this morning. When I came home and turned it on. I didnt even budge. No sound no nothing. The fan just stop working. Tried a couple of other sockets and nothing. What could have cause this. The room is dry so I couldnt say it got wet.
Can anyone help me out.
3 Suggested Answers
The Machine
  • 788 Answers
SOURCE: accutek aoj-1601 stand fan problem
An electric motor shop may be able to rebuild the motor for you, or you may be able to find a motor with the same ratings. Chances are this would be pricier than a new fan though.
Posted on Jun 23, 2008
  • 374 Answers
SOURCE: Accutek AOJ 1601R fan wouldn't start
hi there,
it always can fix,there are several factror to check,you should have a multi tester to use to check the might be on the switch,
cable or on the motor.
open the control box of the fan,there are set screw loosen this and you will see the connection of electrical connection of cable supply and the swicth.
set tester on rx1 check continuity of the cable plug supply,red rod of tester on plug take one wire,black test rod on the other end of cable plug.this other end of wire is on control box.see if pointer of tester move on to no.10 or 20ohms if move its good.try also on the other side of wire.if does not move replaced the wire.
if you can see a fuse check this,by tester
on rx1 attached red test rod on one end of fuse black rod on the other end,if move the pointer its good but if not,replace fuse,actually all fan motor have thermistor fuse inside the motor,it was mounted on the inner side of winding of
motor it look like a resistor or sometime a form of small square resistor has two terminals,to test this, red test rod on one terminal and black test rod on the other terminal if pointer of tester does not move replace thermistor.
to get the termistor fuse you should open
the motor,this is not easy job.but small pc. of motor will give you knowledge how to fix your small appliances.,on motor there are four lock in bolt,before you can pull out the motor disconnect the wiring from the switch cut this
by cutter plier leave a small color lead of wire
when you cut,allow you to remember the connection when putting back.when you dismantle the motor,loosen the four lock in bolt and pull out the winding on motor case
on winding cut the plastic strip,find the thermistor fuse,this was insulated,careful to cut small wire this are all terminal of motor
replace the thermistor if busted.
put back and try to run your fan again.
unplug your fan before doing this this should be done by technician,have anice day rate my fix thanks a lot.
Posted on Jun 13, 2009
I have an Accutek fan that is not working. Where can I have it fixed in Cape Town? I would like someone to look at it to see if it can be repaired before I incurr costs?
I also have the same problem with my Accutek fan. I think it is the bearing that is going as it is making a noise .It is like running and then jamming as something is restricting it. I also live in Cape Town and looking for someone to fix it.
Jan 24, 2014 | Accutek Dryers
Fan not working
have you checked the fuse?
what make is it?
dose it have other things not working if its a multi fan?
will need to know more before can help
Oct 19, 2013 | Accutek Dryers
I have a A0X-1202 Accutek fan, it wouldn't start. It worked fine before but today it just won't start. Can it be fixed? What possibly could be the problem?
1st, remove the poer cord from your fan and determine if you have any breaks in the line by checking the voltage ( 120 volts) coming from the bare wires when it's plugged in. If nothing registers on your volt-multimeter, you can easily repair the cord or just replace it. Check to see if that works, and if not, ask me the next step.
Sep 21, 2012 | Accutek AOJ-1601 Stand (Pedestal) Fan
I Have a Haier Refrigerator, not sure if it is this model it looks the same but is stainless steel. Recently the fridge has stopped cooling. Have had it for a few years and has of late it slowly began to...
It sounds as if the fan has ceased working. If it is freezing the bottom, then the refrigerant has not escaped. If it was the compressor, the motor would have become louder and begun to rattle. If you can turn it off for a day, then turn it back on. If the fan motor starts to work, it may just have been frozen up, replace your seals . If the fan motor does not start then well it will not. Try replacing the fan motor.
Oct 03, 2017 | Haier RRTG18PABB (207 cu ft) Refrigerator
I Have a hampton bay ceiling fan mod. 523 342,
if you have connected power directly to the fan motor and it doesn't turn...replace the fan.  However, also check the switches on the fan as you may have bumped them.
Mar 24, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Heat blower fan not working
it seems like u have either a bad switch or bad blower motor.
Feb 26, 2009 | 2000 Oldsmobile Intrigue
My refigerator is not getting cold the fan is working normal
Probably the coolant has leaked out. Buy a second hand one..
Nov 25, 2008 | KitchenAid KSRS25IL Side by Side...
Accutek aoj-1601 stand fan problem
Jun 23, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
Accutek stand fan just hums, won't turn
That means the bearings are dry and have locked. Simply open the motor cover by removing the screw and pull the oscillation knob by rocking it side by side gently to have free access to the motor.
MAKE SURE THE FAN IS UNPLUG FIRST. Use cream type grease on both ends of the shaft. After applying the grease rotate the blades until they're freely and you feel the blades have released.
Place the motor cover back and the oscillation knob and plug-in the fan. Leave it on HIGH for 10-minutes or more to make the rotor loose with the grease.
Jun 15, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
Accutek AOJ-1601 Stand (Pedestal) Fan Logo
57 people viewed this question
Top Accutek Dryers Experts
ray gallant
 Russ Hill
Russ Hill
Are you an Accutek Dryer Expert? Answer questions, earn points and help others
