Hoover hnf7147 doesnt heat up
In UK. Just over a year old, the washing machine runs fine but does not heat the water.  I've checked the element its ok (about 40 ohms) but never gets any supply to it. There is a temperature selector control, a controller board, and a temperature sensor.  I have tried the temp control in different positions but no difference.  People have said if it doesnt heat up the cycle will stop, but it doesnt, so I conclude the controller board thinks the water is hot or the selector is in the full cold position.  Can you give me any advice please?
2 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: washing machine doesnt heat the water
Most washing machines do not heat water, they merely let the hot water into the wash tub that comes from your house hot water heater.... when selecting warm, hot and cold water will be mixed together to get warm or when selecting cold.. only the cold water is allowed into the wash tub.. Please provide brand and model number of machine so I can tailor a reply toward your specific washer...
Posted on Sep 21, 2008
Hoover vision hd washing machine
have the heating element check out as they are normally in the base of the tub and get surrounded by gunk and burn out from lack of water around them
Aug 17, 2013 | Washing Machines
Dryer part of the washer/dryer is not getting hot anymore
hay Darren , If you have an electric dryer it may be a element or fuse , if its gas it may be bad coil or fuse . The washing machine does not heat the water rather bring it in from the boiler therefor its unrelated to the dryer .good luck APPLIANCES R EN
Mar 01, 2013 | Washing Machines
Hi we have literally just brought a Hoover dyn 7164 d and on first check-which the manual asks us to the error code e03 appears and will not drain!!!what do we do??its full of water!how can something...
What a heap of junk of a machine. The one I own died after 13 months taking the electrics in the house out with it. A faulty heating element was the cause. They leak over their electrics with predictable results. A modified element has been fitted. Avoid this and all Hoover products like the plague.
Dec 02, 2012 | Washing Machines
Hoover vision hd washing machine is not heating water?
Possible failure of the heating element. Please check the continuity of the coil and if possible the voltage to the coil , if there is voltage at the cycle then the element is open.
check this link: heating element.
Jun 26, 2012 | Hoover Washing Machines
Hoover vision hd not heating water
Please check the continuity of the element by using a multimeter, if open it must be replaced. if the element is good then the wires to the element and the mother board is a suspect.
check this link: Element
Water in washing machine doesnt get hot even on 90 degrees
Possible failure of the heating coil, check the voltage on the coil during the heating cycle.Please check this link to replace; http://www.espares.co.uk/advice/washing-machines/a/7/1393/how-to-replace-the-element-in-a-washing-machi.html
Mar 14, 2012 | Washing Machines
F-08 error message on Hotpoint Washing machine WT761? The original fault on the machine was that it was tripping out and taking out a resetable fuse in my fuse box a few seconds after turning the machine...
If it works fine with the heater off then i would say that fault appears to be element..the readings you get seem okay, put you meter onto megs and check, with wires off if you get electrical leakage between live and earth...Body....of element, it could be element is heating with no water in machine causing it to burn out..this is a problem with this machine...Wish you well
Oct 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Washing machine doesnt heat the water
Sep 21, 2008 | Washing Machines
Not heating cold water
this could be 2 possible symptoms 1 the thermostat which gets the heater element to work. 2 it is the heating element that is faulty if the element has gone then this is about £15 to buy which u get both thermostats which u might has well replace both at the same time now if its the heater element then this will be around £20-25 to replace now my best suggestion is call out an engineer that doesnt charge any call out fee this will tell u exactly which if these it is if its thermostat then do it yourself easy job which will only take u around 30 minutes to do from start to finish if its the heater element then get them to do it which should cost around £65 to do this is because it needs to be sealed properly otherwise it will leak and cause more problems in the long run
Jul 20, 2008 | Hoover AL130 Front Load Washer
HOOVER WASHING MACHINE
I have found a solution in a UK website. Machine fixed.
Jun 09, 2008 | Hoover Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
