Question about HP Office Equipment & Supplies
HP photosmart c8100 all in one printer 10x15 photo paper spits out when ever you try to print a photo from printer .new printer thanks Ray
  • fourmacs Sep 21, 2008
    not able to look at it this week son looking 27/9 thanks will get back nxt week ray
  • fourmacs Sep 27, 2008
    Thanks for the suggestions.
    The problem only happens when printing photos directly from the printer (with the photo card in). It doesn't happen if I save photos on the computer and print from there.
    What it normally does is spit out the paper, comes up with a message saying "Paper mismatch: paper size or type is incorrect. Change paper and press ok to continue job".
    Then when pressing ok it goes on to print fine. It seems like it can't automatically detect settings until the second photo paper goes in.
    It also happens no matter what paper settings are changed - ie if it is on automatic or everyday photo or any others.
    Although it prints ok eventually it shouldn't have to spit out the paper first.
    thanks, Ray
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
ok try it first try with a plane paper
then if it is ok try print in photo paper
sometimes the photo paper stock on the roler
and spit out with no print
because of glossy paper
try put the photo paper properly in the tray
when it printer print try to push the photo paper on the printer slowly
to guide the photo paper in the printer to print!!
maybe that it helps
good luck!!!
Posted on Sep 20, 2008
  • ronald suboc
    ronald suboc Sep 20, 2008
    or adjust the photo paper size in the printer menu option when you start to print
    must exactly the same size in the computer setting and with the photo paper in the printer
    Sergeant:
  • 399 Answers
Do the normal copies of microsoft worf comes out properly without any spitting.then its the setting problem in your printer .you can change the settings through printer properties --just adjust the photo settings in your printer and it will print the photos.
but if the word document are also having the same problem its the printer problem get the replacement as the printer is new.
feel free for further queries.
thanks.
  • masterexpert Sep 20, 2008
    also adjust the paper settings as what you are using ----photo paper ---- plain paper----transperency-----etc etc .just select the proper paper.
    thanks.
The printer does not print. It feeds paper and
Visit HP support for this problem (XP):
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01853840&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=443024
If you have Vista, change query to read "Printer prints blank sheets of paper" > Choose Vista instead of XP
Dec 05, 2009 | HP Photosmart 8250 InkJet Printer
My hp photosmart c6180 prints green photos on photo paper. it prints fine on regular paper. all my ink cartridges are hp and new. how can i fix this. i have tried several different types of photo paper as...
Check to make sure all of your contacts are clean. The part where the cartridge meets the printer. Also check to make sure you have it set in the printer properties for photo quality paper. If this still doesn't work, I would suggest trying a different brand of paper, it may be the problem with the paper manufacturer.
Oct 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
Prints on plain paper only.
the phot0graphic paper should be the one recommend for that printer eg it should be hp photosmart paper. if the printer came with some photo sample papers try it once again.
Aug 26, 2009 | HP PSC 750 All-In-One InkJet Printer
Photo paper is puled left and right
the bplatten may be too smooth, especially if it has some dried ink on it, lean the platten with alcohol on a lint free cloth. try to print if proble still exists get some fime emery poaper and rotate the platten while holding emer papoer to it. then try to proint again the latter is a last resort but shoulod work
Jun 19, 2009 | HP PhotoSmart 7960 InkJet Printer
Photo paper will not print
check these 2 links and go through the sites
link 1
link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Mar 17, 2009 | HP PhotoSmart 1215 InkJet Printer
HP Photosmart 7550 - Full Page Photo Printing Jams at end
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 17, 2009 | HP PhotoSmart 7550 InkJet Printer
I cannot get HP C6200 all in one printer to print on 10x15 photo paper. Just says out of paper or prints on A4 if paper in main tray. Have followed all instructions! Wendy Angus
Sorry - I didn't read this closely enough. You will not be able to print on 10x15 paper as the paper type is not supported by your printer.
This is a list from the specs of the supported paper sizes;
Supported paper sizes Letter, legal, executive, No. 10 envelopes, cards, borderless photo (4 x 6 in, 5 x 7 in, 8 x 10 in), borderless panorama (4 x 10 in, 4 x 11 in, 4 x 12 in)
Aug 09, 2008 | HP Office Equipment & Supplies
I have just purchased and set up this hP photosmart C6200 printer. I cannot get it to print on 10x15 photo paper. It asks for paper to be placed in the main tray. Can you help as Ive followed the...
HP Photosmart D7360-Won't print from photo tray
You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
Oct 29, 2007 | HP Photosmart D7360 All-In-One InkJet...
Canon Pixma MP810 Full Page Photo problem
Check your print settings and run an allignment check.
Sep 27, 2007 | Canon PIXMA MP810 All-In-One InkJet...
167 people viewed this question
Ben Johnson
