Question about Lasko 5540 Ceramic Compact Heater
Iflo digistat help.my remote unit has a mind of its own. is there a online instruct , manual ? it does stop me turning the heating on manually, we just bought a house with this system. Help cheers sean 07807 194 103
Found a manual:
http://www.invensyscontrolseurope.com/InvensysControlsEurope/en/ProductsServices/Drayton/ProgrammableRoomThermostats/
Posted on Oct 08, 2008
Digistat scr
Assuming you're referring to the Digistat SCR receiver and not to a digital camera, you may download the manual here. The SCR section begins on page 6.
Feb 16, 2012 | Cameras
How to programme rc2 british gas thermostat
The British Gas RC2 is a re-badged Drayton Digistat and I managed to find installation and operating manuals for that at www.gasapplianceguide.co.uk
Go to the section 'Lost your instructions' and look for Drayton 2F & 3F Digistats (earlier type) for a downloadable copy of the manuals.
Following them got my RC2 up and running though it was a bit fiddly at times.
Hope this helps.
Oct 27, 2011 | Honeywell Programmable Thermostat Heater
I need the user instructions for the Drayton Digistat RF3 wireless system
Try here:
http://www.draytoncontrols.co.uk/supportingdocuments.aspx?id=1504#
Note that if the manual is not online the customer service contact info is so you can email them to have the manual sent to you.
Dec 17, 2009 | Garden
Drayton Digistat SCR thermostat not working.
Go online to www.cheapboilers.com who deal with this type of boiler. It would be very difficult to troubleshoot this boiler with the information supplied. I hope this will be of some help to you.
Sincerely, Shastalaker7
They should also be able to get you a manual for your thermostat.
Oct 27, 2009 | Heating & Cooling
Red alarm light on constantly and heating wont work unless over ride system
Have you tried turning one of the thermostats off.? They are both talking to the same unit and they may be arguing with each other.
May 21, 2009 | Dayton Water Heaters
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
My Drayton Digistat RF3 boiler control is not working. The thermostat module indicates it is sending a signal, but the unit beside the boiler has a red alarm LED lit. I've removed the batteries and turned...
I found that this solved the problem hope it helps you too.
come back on}
seconds.
received.
Nov 04, 2008 | Heating & Cooling
Iflo digistat+2RF remote control for combi boiler
there should be an overide button on reciever try checking if stat is still communicating with reciever when stat is turned up and down light should flash on reciever
Oct 23, 2008 | Lasko 5540 Ceramic Compact Heater
Problem with IFLO Digistat RF2 (Wireless System)
To reset the system:
1) Pull out the left & right draws from the bottom of the remote and remove the batteries. The screen will go blank after about 20 seconds.
2) Go to your control panel:
Press 1 once
Press 2 once
Press 1 & 2 together for about 5 seconds until you get a solid light (it doesn't matter which light) then release.
3) Put the right draw batteries back, then the left draw.
The system should start. If not, press 2 once.
It worked for me!
Jan 01, 2008 | Heating & Cooling
Lasko 5540 Ceramic Compact Heater Logo
1,436 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
