Question about IBM ThinkPad T21 Notebook
Laptop screen is barely readable, cannot not determine location of cursor.
I have a IBM think pad R51, I recently borrowed it out and it was returned with a dead battery. I plugged the battery chargeing adapter into the outlet and let charge for a day. When I turn on the laptop the screen is very dull, almost completely unreadable. The laptop appears to be functioning, but I cannot navigate because I cannot see the cursor. Is there a way for me to find out if the problem is the battery or the screen backlight? cannot determine location of cursor
    Scholar:
  • 135 Answers
Remove the battery, plug the ac adapter and try to boot up. This is to check if the battery is the cause. If the issue is still there, while you are on windows, hold down the Fn key then keep on tapping the home key. This is to increase the brightness of the LCD.
If still nothing happens, you may want to try it out on an external monitor just to check if you can seee the cursor. Plug in the external monitor then boot the unit, it should automatically display it on the external monitor, if not press and hold the Fn key then tap F7 to switch displays. Then check if your display setting is set to extended display under display properties, that's why your cursor is gone
Of course if everything fails, you may need to check the FL inverter on the laptop. This will be the bulb light. This bulb rarely busts so you may consider just reseating it to fix the Issue.
Hope this helps.
Posted on Sep 20, 2008
    Sergeant:
  • 399 Answers
Battery is for sure.replace the battery and everything will be fine.the battery is at the end of its life.
feel free for further queries.
thanks,
3 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Laptop screen is barely readable, cannot not determine location of cursor.
Screen back light or inverter gone - repair shop for this one
Posted on May 25, 2007
Maha Pappan
  • 9 Answers
The first thing to check is brightness of your IBM. May be the brightness is set very low. It may sound silly and simple, but we human can overlook simple issue.
Secondly, try using another charger. Not the battery. Recently, I had problems with one of laptop same model. I formatted and reinstalled windows etc...nothing helps. Just curios, changed the charger and surprise me...It worked alright.
Regards,
Maha
Posted on Feb 05, 2009
IBM Thinkpad R51, screen went dark. At the right screen angle, I can see some light from the windows and cursor, but very faint. At that light angle I can maneuver the mouse and click on windows, so all...
The problem
1 The LCD screen is out or
2 The invertor board behind the LCD screen is out or
3 The backlite is out
You have 2 options
1 To use an external monitor for the time or
2 get the laptop fixed by a tech shop
Nov 18, 2010 | IBM ThinkPad R51 Notebook
IBM R51 - "Registry Cannot Load"
I had the exact same problem. I basically gave up and decided to reinstall the O.S. But when I did it gave me an option to upgrade rather than install, and I found that all my programs and files were still there after. So you coulkd do that. I found out that some of the O.S. was corrupt via a virus so this was solved also.
Jun 05, 2009 | IBM ThinkPad R51 Notebook
IBM Think Pad - ''Registry Cannot Load''
Ok so what you need to do is reinstall the Opertaing System. When system 32 files are missing then the Operating System dosent work. You would need to backup any stuff you need. If you have any other questions or need directions please email me at joegoetz16@gmail.com
IBM Think Pad R51 - "Registry Cannot Load"
If you are able to: download a free program called "glary utilities" It is a registry fix and system optimizer that runs automatically.
Jun 05, 2009 | IBM ThinkPad T22 2647 Notebook
Ibm think pad r51 nodisplay 4 beeps commaing
This indicates a possible memory problem. Reseat the RAM modules and boot up, if OK then the laptop is OK.
If not then :-
If you have two RAM modules, remove both and insert one and boot up, if it is OK then repeat with the other one - this will determine which memory module is faulty.
Mar 30, 2009 | IBM ThinkPad R51 Notebook
Regards,
Maha
Feb 05, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Sound driver problam
you will find your sound driver HERE:
plz let me know if its all right.
regards /Teis
Jan 10, 2009 | IBM ThinkPad R51 Notebook
Motherbord problem
I don't work for IBM.
ibm systemboards cost from 200 to 800USD
http://www.sparepartswarehouse.com/IBM-Lenovo,ThinkPad,R50-R51,Laptop,System-Boards.aspx
Contact IBM service for repairs, I recommend you let someone else do the repairs.
Might not be worth it. You be the judge.
Mar 20, 2008 | DFI AK74-SC Motherboard
i am having the same problem, my screen apears to be pretty nuch black until i have to tilt it up to be able to slightly read the dark screen.
May 24, 2007 | IBM ThinkPad R51 Notebook
IBM ThinkPad T21 Notebook Logo
91 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
