Nokia N95 Cellular Phone Logo
Posted on Sep 20, 2008
Audio failure i bought this second hand phone and at first, the audioplayer worked playing 2 songs. then it stopped and rebooted. when i tried to open the program again, it just reboots the phone automatically. i can now only play audios via file manager. :(
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Sep 21, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
261
Points
Maybe you should try updating the firmware of the product through nokia pc suite. Most latest firmware for N95 is V 21.0.016.
Try it. Most problems with the N95 as solved by updating the firmware.
Scosche fm transmitter FMTD8 not playing mp3 files on Flash drive
I bought the fmtd8 scosche transmitter. If you're like me ,you tried to play music from you're cell phone first. That worked just fine. Then I made an sd card with a few hundred songs on it. P.S. I left the audio cable plugged in the the transmitter. The sd card with mp3. songs would not play for anything. After 2 days of trying,I finally decided to unplug the audio cable.. Voila!!!!! Instant sound.
NOKIA N73 screen shows headset mode on the top right even when not connected to the headset.....so i am not able to hear anything even when i connect the headset it is not responding & i can't hear...
Hi Saik,
I think problem is caused by unplugging the jack before pausing/Stopping the music.
1) Plug in a headset into the jack
2) Open up a media player (either the MP3 player or any online music)
3) Begin to let the music play.
4) Stop the music from playing after a few seconds
5) Completely exit out of the media application.
6) With the headset still plugged in, wait about 15-30 seconds. (this is so that the media/pandora app task can "fully" stop from running)
7) Unplug the headset.
The phone should now be able to emit sound from the earpiece.
If the above does not work, other methods I have read tell you to plug in a headset & play music. While the music is playing, quickly remove & insert the headset into the jack (not too rough so if doesn't break anything) until you hear the music coming out of the speaker.
Finally, if you still have the issue, try rebooting. Turn off the Phone, Remove the battery completely and reinsert after 30 seconds. Turn on the Phone.
Hopefully that should fix the issue.
1helpful
I have a gigaware 8gb mp3 player. i went into my computer, clicked on audioplayer and deleted almost all the folder tabs for music to get rid of all the music on my mp3. Now when i try to put songs on...
MP3 players can only play music files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
3helpful
When i plug my iphone 3gs into the ilive itp100b i try to play my pandora music app and the music plays for 2 seconds and then stops. the music on the app continues to play on the phone but the ilive isnt...
I have this exact same problem... audio I loaded on through itunes play perfectly... songs, audiobooks, podcasts, etc, as well as input from my TV and the build in FM radio, but anytime you try to use any 3rd party radio app on the iphone, you get like 2 seconds of audio and then nothing, and the app usually has some text that says, "No Volume Available".
From research, it seems that the iLive company is to blame as they did not update the firmware to work correctly with iOS 4, so it is their problem and not the iPhone. I am returning my device and getting another brand that supports iOS 4
1helpful
''Pioneer DEH 1900MP 2 second gap between songs on CD''
that isn't the radio doing this...all recorders insert this 2sec gap as the default setting.  Some recorders you can adjust this.  All store bought CDs have this too.
3answers
Audio player not playing all songs
Please check teh format of teh songs downloaded, they might not be supported by teh Moto Player (*.WMA, *.RM..etc.)
How to play audio clip in java
  • Create an AudioClip object
  • Load .au sound file into AudioClip
  • Play sounds once or loop continuously
  • Stop playback
Here's how the code for these steps looks:
import java.applet.*;
AudioClip ac = getAudioClip(getCodeBase(), soundFile);
ac.play(); //play once
ac.stop(); //stop playing
ac.loop(); //play continuously
It would seem logical to use this same code to play audio clips in a Java application. Unfortunately, if you do that you will get errors from the compiler. Why? Because the AudioClip object and the getAudioClip() method are part of the java.applet package -- and are not part of applications. The good news is we can dive down and make things work ourselves.
The trick to solving this problem is to use some undocumented features that are provided by Sun in its JDK. Taking a peek inside the classes.zip file from the Sun JDK (using any of the various zipfile utilities), we find not only the standard Java packages such as java.applet but also sun.audio. (These are in the directory sun/audio.)
The sun.audio package contains everything we need to be able to play audio clips! Here's the code:
import sun.audio.*; //import the sun.audio package
import java.io.*;
//** add this into your application code as appropriate
// Open an input stream to the audio file.
InputStream in = new FileInputStream(Filename);
// Create an AudioStream object from the input stream.
AudioStream as = new AudioStream(in);
// Use the static class member "player" from class AudioPlayer to play
// clip.
AudioPlayer.player.start(as);
// Similarly, to stop the audio.
AudioPlayer.player.stop(as);
To use a URL as the audio stream source, substitute the following for the input stream and audio stream setup:
AudioStream as = new AudioStream (url.openStream());
Playing the audio stream continuously adds a bit more complexity:
// Create audio stream as discussed previously.
// Create AudioData source.
AudioData data = as.getData();
// Create ContinuousAudioDataStream.
ContinuousAudioDataStream cas = new ContinuousAudioDataStream (data);
// Play audio.
AudioPlayer.player.play (cas);
AudioPlayer.player.stop (cas);
My mp3/4 player only plays a few seconds of each song.
The new songs are in a format not recognized by the player - either DRM-encrypted WMA's or iTunes format. Download songs in mp3 format only, and you will no longer have this probelm - available from Rhapsody's Mp3-Only Service (make sure you choose the right subscription), Limewire, and a handful of others.
Graig MP3 problem
The songs are in the wrong format - use mp3 format files for best results
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
