Question about Abit Computers & Internet
ABIT IP35V, LONG and Continues Beep when There is a Geforce GT8800 video card installed.
Hi All, I'm having a problem installing Abit IP35V motherboard, with a ESC Geforce 8800 GT video card, When the Geforce is installed I Get e long Beep that never stops. Do you know what it could be?
  • 1 more comment
  • Victor Garcia Sep 20, 2008
    Without the video card installed, I got a short beep, that means all is OK. When I put the video card, and the system is started up, I get the long beep, then stops for a second and then started the long and continues beep. The video card is new,,,,could it be related with the power
    thanks.
  • Victor Garcia Sep 21, 2008
    OK, it's a high frecuency long beep. I think if it's a motherboard problem I should get the beep whether the video card is installed or not...If the problem is caused by the video card, maybe it demands more current, the current power supply is 600 watts
    it's phoenix
  • 22 Answers
Beep by motherboard are due to hardware problems. It's either the hardware is problem or it's not properly connected. Try check your RAM or graphic card weather it is fix properly. And also try to check your jumper connector. Sometimes one of the jumper connector may be damage and create the beep sound.
Posted on Sep 20, 2008
  • 1 more comment
  • Small_I
    Small_I Sep 20, 2008
    May I know the exact specification of the beep. Weather it is high or low frequency?. How many short and long beeps? How many times of beep? But through my experiences, continous beeps means there was a problem with your power supply or the motherboard. If when you turn on the power, the fan of the heatsink is functional, it is high percentage that your motherboard was the problem.
  • Small_I
    Small_I Sep 21, 2008
    What type of bios it is? IBM, AMI, Award or Phoenix?
  • Small_I
    Ok.. try check this link : http://bioscentral.com/beepcodes/phoenix... .
    Different beeps indicate different kind of error.
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
Beeps on startup but no video and continues to have long beeps with no video
Check the the cpu, ram and video card are seated properly. If they all are, then the board is defective and will need to be replaced.
Mar 05, 2011 | Abit NF8-V Motherboard
Have an computer with ABIT AA8 motherboard When
Try to unplug and plug again the video card. As you describe it is a VGA card error.
Jan 20, 2011 | Abit AA8-DURAMAX Motherboard
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
Microphone not working
Yes the card has sound.
http://www.abit.com.tw/page/en/download/download_driver_detail.php?pFILE_TYPE=Driver&pMAIN_TYPE=Video%20Card&pTITLE_ON_SCREEN=Siluro+GeForce2+MX&pSOCKE
Jan 13, 2009 | Computers & Internet
KN8-SLI newly installed, beeps but no start-up
Sounds like a bad or wrong stick of memory
Dec 21, 2008 | Abit KN8 SLi Motherboard
Abit nf8-v keeps beeping when turned on. no video
How is the beep sounds? Long beep and three short beep or one (-...) or all long beep?
For the first, usualy the VGA connector is not correctly seated, so the motherboard can say it has no output device and beeping.
The last is usually memory problem. Try, unplug your memory board and replug it again, make sure that it is correctly seated.
Dec 10, 2008 | Abit NF8-V Pro Motherboard
Abit bd7m - no video, no keyboard, no mouse
Why does the BD7 board fail to POST with sirens? Is the mainboard faulty? A:
  1. If the CPU retention unit or heat sink wasn't installed correctly, the bad heat dissipation will cause P4 CPU over temperature and fail to boot up.
  2. Please check the black CPU retention is fully inserted into the holes in the mainboard. Below picture illustrates a bad installation- there is a gap between retention unit and mainboard.
  3. Please make sure the white nails were fully inserted and can prevent CPU retention unit from loosen.
  4. Double check the back side of mainboard. If the feet of CPU retention unit and white nails were correctly installed?
Mar 04, 2008 | Abit BD7m Motherboard
Computers & Internet Logo
576 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
