Question about Pioneer Televison & Video
I have a PDP-505HDG plasma display. Have problem with HDMI when using Freeview Zinwell TV, I get audio, but no video (just blue screen). It did work correctly for 1 week. The display works fine with Xbox 360. The Zinwell works correctly with composite video output, and with HDMI into other HDMI TVs. Have also changed HDMI cable, but still u/s.
    Problem Solver:
Hi this problem is with a plasma- I made no mention of a projection TV.
Yes I still have the problem.
Posted on Sep 21, 2008
Does a 12 yr old technika 17-510 have hdmi port
It appears to have one HDMI input port.
https://www.gumtree.com/p/televisions-plasma-lcd-tvs/tv-dvd-17-technika-lcd-freeview/1289188649
It is said to require the use of the remote control to operate, so be sure that the remote control works if you are purchasing it.
TV DVD 17 Technika LCD Freeview in Chippenham Wiltshire Gumtree
Apr 10, 2018 | Televison & Video
Hi , i just purchased a blue ray dmp bd30. i wish to use it as to play cds. It is connected to my 2 channel amplifier from the audio outlets, it is connected through the HDMI connection to a Pioneer...
If the audio is going to the tv / speakers with hdmi, then no the screen has to be turned off.
Unless you setup a external sound system.
Jul 09, 2008 | GPS
I lost picture and Audio,I just replaced the Y sustain board and still doesn't work, what else should I do?
If you get a blue screen when it's on, try feeding in an external audio and video source, like a camcorder or VCR, and see if it displays. Check setup or input selection. If it's set to video or HDMI source and nothing is plugged in, you'd get a blue screen.
Oct 20, 2014 | Zenith Z50P3 50 in. Plasma TV
My tv is a PDP427XD. When i switch it on. it has lines across the screen which is the picture but distorted. if football is on then picture would be green. if i switch it 4:3 i can see the picture at the...
Having worked with Pioneer for many years, I would say you have a video fault. It is not likely, in my view, to be the plasma display itself as they go like a dull light bulb as they age, not into lines. I would check the video processing after the 135 volt ramp supply fom the power supply.
Hope this helps.
Dec 13, 2010 | Pioneer PDP-427XD 42 in. Plasma Television
(Pioneer PDP-4340HD Plasma with PDP-R04U Receiver) My HDMI input works, however having a computer or Xbox connected via HDMI I do not have the optical output signal thus I can not hear audio through my...
I don't have a direct solution but I am having the same problem when connecting (1) my Apple TV (2) my Blu-Ray player, etc. via HDMI. I also have a digital camera that puts out HDMI, and when I hook it up, I get the same story -- video only, no sound through the optical digital output of the TV receiver.
I am guessing that the HDMI inputs were an afterthought on this model, especially since the printed manual doesn't even show or mention the HDMI inputs at all! So my guess is that the TV's receiver does not convert the sound from the HDMI to the optical digital output. It does, however, send the amplified HDMI sound to the stereo speaker outputs on the monitor. It appears that only the digital tuner's 5.1 sound comes out on the optical digital output.
This is what I have observed, for what it's worth.
Nov 04, 2010 | Televison & Video
What am supposed to do if my t dosen't have HDMI
Either HDMI to DVI adapter cable if TV has DVI in. Or component video cable (Green,Blue,Red jacks, plus White,Red for audio. Both will do HD.
May 01, 2010 | Vizio L30WGU 30 in. HD-Ready LCD...
Viore pdp42v18ha problem - no audio
Take it back to the dealer from which you purchased, receipt in hand and raise a stink.
Mar 04, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
Help
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Aug 09, 2008 | Computers & Internet
1050P setting on existing plasma
You will need to go to the set-up menu and activate the hdmi imput on the plasma side.These units have the ability to de-activate the hdmi imput to use the regular video imput.
Mar 15, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Televison & Video Logo
213 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
