Question about Acer AL511 15" Flat Panel LCD Monitor
Fix my Monitor-power on. white (lighted) screen
When I applied power to my monitor, it turns white (on) for a few minutes then it goes black again. However, the power led remains on. What is wrong with my monitor and how do I fix it?
    Scholar:
  • 188 Answers
Http://www.daniweb.com/forums/thread17104.html
Try this website for answers. The forum thread is a good one. I agree with these solutions.
Posted on Sep 20, 2008
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Dell 1905FP powers up but screen goes black after a few minutes
The monitors inverter seems to be failing. If you look up close, can you see a very faint image of the desktop?
You should think about getting a new monitor it might be cheaper than repairing.
Feb 14, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
One of the two monitors will cease displaying screen image and begin rotating between a BLACK/WHITE/GRAY/Primary Color Bars every other second following a few minutes after start up. Have tried Restar
It might be the input from the graphics card. Try swapping the two monitors' feeds to see if the problem is with the monitor or the card. The monitor seems to be going into a screensaver mode since there's no signal. The flashing light could mean there's a power supply problem, or no signal.
Oct 15, 2017 | DoubleSight Displays Computers & Internet
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
SCREEN TURNS OFF AND GOES BLACK
The picture board on your monitor is faulty or bad, since it goes black after few minutes, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board or any service center because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | HP w1907 LCD Monitor
Screen turns white only
http://www.daniweb.com/forums/thread17104.html
check out his forum thread. I think there is good information posted. I hope it helps.
Sep 20, 2008 | Acer AL511 15" Flat Panel LCD Monitor
Monitor goes blank less than a second after turning on.
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Screen goes black and power light goes out after a few minutes
it would seem that one of the internal components has failed / overheated Dont open the rear of the monitor !
if pos drop it into your nearest pc repair shop and have is serviced it may just need cleaned to free it from dust build up
on the inner parts this may be causing the unit to over heat
Nov 04, 2007 | Gateway FPD1760 17" LCD Monitor
17"LCD Monitor
This problem is showing when the main PCB of the monitor failed. Contact the LG service provider in your area.Check this link to get the service center info
http://www.lgservice.com/
Oct 11, 2007 | LG L1915S 19" LCD Monitor
RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Sep 21, 2007 | Acer AL2017 20" LCD Monitor
Acer AL511 15" Flat Panel LCD Monitor Logo
127 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
