Question about Dell Dimension 3000 PC Desktop
Computer goes to blue error screen 0x000000FC
Hello there,
The computer runs to blue screen gives me an error message, "A problem has been detected and windows has been shut down to prevent damage to your computer. An attempt was made to execute non-executable memory."
The technical information is:
***STOP: 0x000000FC (0xF89148E8, 0x02F32963, 0xF8914848, 0x00000001)
When I run it in safe mode, the files load down to WindowsSysten32DriversMup.sys before stopping and going to the old blue screen of death again. My son says he recalls a Windows update just prior to the problem, not sure if this is related.
Running Windows XP
I'd be grateful for your assistance.
Regards
Rich
  • 4 more comments
  • sremmah Sep 20, 2008
    Hello there, thanks for your advice. However I cannot get to the start screen, as the blue screen keeps coming up, I cannot log into the computer at all. Is there a way around this so I can do the System Restore. Again many thanks.
    Can you advise how to fix this?
    Thanks Soumyak however as I mentioned in the problem report, I can't access in safe mode. When I do so, the files load down to WindowsSystem32DriversMup.sys before stopping and going to the old blue screen of death again. My son says he recalls a Windows update just prior to the problem, not sure if this is related.
    Hi, I ran an express check from F12 on the splash screen as suggested by Proton (sorry I appear to have lost that person - still getting my head around how to use FixYa). The test came up with an arror message of 650F:136C Msg: IDE device failed. I appear to not have the Windows XP CD unfortunately, is there anything else I can try?
    Thanks folks for all your help but is there any way I can boot the system without the (lost) Windows XP cd?
    Hello Proton, unfortunately this doesn't solve the problem of not being able to boot the computer, even in safe mode.
    Appreciating your assistance though thanks.
    Sergeant:
  • 399 Answers
The Blue Screen of Death (also known as a stop error, BSoD, bluescreen, or Blue Screen of Doom) is an error screen displayed by certain operating systems, most notably Microsoft Windows, after encountering a critical system error which can cause the system to shut down to prevent damage.
Bluescreens on NT-based Windows systems can be caused by poorly written device drivers or malfunctioning hardware. In the Win9x era, incompatible DLLs or bugs in the kernel of the operating system could also cause bluescreens.
Bluescreens can also be caused by physical faults such as faulty memory, power supply issues, overheating of components, or hardware running beyond its specification limits. Bluescreens have been present in all Windows-based operating systems since Windows 3.1; earlier, OS/2 and MS-DOS suffered the Black Screen of Death, and early builds of Windows Vista displayed the Red Screen of Death after a boot loader error.
The term "Blue Screen of Death" originated during OS/2 pre-release development activities at Lattice Inc, the makers of an early Windows and OS/2 C compiler. During porting of Lattice's other tools, developers encountered the stop screen when NULL pointers were dereferenced either in application code or when unexpectedly passed into system API calls. During reviews of progress and feedback to IBM Austin, the developers described the stop screen as the Blue Screen of Death to denote the screen and the finality of the experience.[citation needed]
what happens and what should be done.
When getting the BSoD, the screen will go black for about a second and any playing audio will start to skip, and then a dark blue screen will come up with white writing. On Windows XP and Vista, it reads as follows:
A problem has been detected and Windows has been shut down to prevent damage to your computer. The problem seems to be caused by the following file: <Insert File Name Here>
<Insert cause of BSoD here>
If this is the first time you've seen this Stop Error screen, restart your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode.
It then tells you the technical contact information.
Details Each BSoD usually displays a message such as FILE_SYSTEM, and a number like 0x00000022. The usual parameters displayed for the BSoD are these:
number of error (parameter, parameter, parameter, parameter) name of error
All of the above information is important in understanding and determining the cause of the BSOD.[11]
Depending on the value "number of error", all, some or even none of the parameters contain data pertaining to what went wrong, and/or where it happened.
for how to repair ----what went wrong while loading the software----- how to reload again without loosing any files----
and much more help click this link for step by step directions and diagrams/pictures
http://en.wikipedia.org/wiki/Blue_Screen_of_Death
feel free for further queries.
thanks.
Posted on Sep 20, 2008
  • 4,472 Answers
You will need a windows CD. If you do not have one we can not go any further with trouble shooting. You will then need to have it repaired by a qualified technician to fix this error. You can bring it to geek squad and they will do it for a fee. If you still have any questions let me know. If you have a moment to accept and rate this solution it would be appreciated.
Thanks,
Lee
    Master:
  • 505 Answers
You need to repair windows will the windows installation disc if you not have a that disc take it to a computer they will repair it for you,
    Scholar:
  • 141 Answers
Hi Rich,
This problem is most likely caused by one of your PCI cards. Open up your computer and remove them ONE AT A TIME. In other words, power down your computer and remove one of the cards, then turn your computer back on. Keep doing this until the problem goes away. Note that it may be your video card if it is not onboard.
    Genius:
  • 1,665 Answers
Observe if when power on you here a continued beep at memory checking state. If yes, switch off for a minute , and try again. if problem insists remove and refit memory cards to make sure they are well inserted in there slots.
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Sep 20, 2008
    (you here a continued beep) correct > you hear a continued beep
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!!
try to open up the tower
check the ram of your computer
try unset it and clean
and put it back properly!!!
if it is happen again!!!!
and try re-installe your video card
and if it is happen again!!
try to diagnost or surface scan of your harddisk if it has a badsector
it it is happen again try to reformat your
your operating system if you know how
to format and buck up all the files that u need
and if it is happen again in again
try to replaced your
Ram must be on the same speed or borrow from your friends
or
the hardisk may be had a bad sector try to bowrrow from your friends
try it!!!!
good luck
  • ronald suboc
    ronald suboc Sep 20, 2008
    try it might be the Ram so some to your friends
    must be at thesame speed or clock
    or roll back all the hardware device on the system in the comtrol panel
    o
    r the operating system maybe
    try run system restoration
    Sergeant:
  • 300 Answers
Http://www.aitechsolutions.net/mup-sys-resolved.html
Solutions to mup.sys
Thank you for choosing FixYa
Az.
    Scholar:
  • 163 Answers
Power on the computer.As starting press F8 and the from screen you can select "safe mode" or better "last known good configuration" and press enter.
    Brigadier General:
  • 6,966 Answers
If I understand your post correctly, you cannot even completely boot even in Safe Mode. Surprisingly, in some instances, it could be a hardware error/conflict. If you are using a USB mouse or keyboard, temporarily replace them with PS/2 versions. If you have any USB devices installed (printer, flashdriver, camera), remove connections prior to booting. You could also try to enter your CMOS/BIOS setup and set all to default.
Alternately, if it is the Mup.sys error, you can boot to your WinXP installer CD and go to recovery console. Log into C:\Windows, expand the d:\i386\mup.sy_ file to C:\Windows\System32\Drivers folder.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Sep 20, 2008
    H again,
    Hopefully, this would still be visible to you.
    To sum:
    • your Dell Dimension 3000 will not boot even into Windows XP Safe Mode;
    • you have no access to a recovery CD or a Win XP installation;
    • you suspect Mup.sys to be corrupted
    If it would appear that you have a problem with C:\Windows\Systen32\Drivers\Mup.sys and as proposed by others and some more:
    • check your memory, USB devices;
    • check the power supply connections;
    • reset the CMOS/BIOS to default;
    • Incidentally, it is significant that the error message was "IDE device failed" which could refer to a defective HD or its connector (is it an IDE?). Pls likewise check the connectors and again the power connectors.
    Other options possible:
    • remove the HD from the Dell and with the use of an IDE/SATA to USB interface external adpter, pls connect to a 2nd PC.
    • directly copy from the 2nd PC the Muyp.sys file and overwrite the one in the HD of the Dell;
    • scan for possible viruses;
    • delete temp and temporary internet files in the Dell's HD.
    Hope that this be of additional help/idea.
    President:
  • 1,952 Answers
Thermaltake 750 Watt Toughpower, Gigabyte P35 DS4, Core 2 Duo 6600, 2 x 1 GB GSKILL RAM, Creative X-Fi Extreme Music, 250 GB Western Digital, 1 DVD, 1 external DVD-RW, Windows XP Pro SP2.
My previous graphics card was a Gecube 1950 XTX. I downloaded and installed the 8.2 drivers from ATI site and the PC ran without problems.
Recently I bought a Sapphire 3870 X2, so I uninstalled the 8.2 drivers from my system, removed the 1950 XTX card, and plugged the 3870 X2 card in. When I turn on the PC, it boots normaly but when it logs on to Windows a blue screen of death appears with the following message:
" A problem has been detected and windows has been shut down to prevent damage to your computer. An attempt was made to execute non-executable memory.
If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove any new installed hardware or software. Disables BIOS memory options such as caching or shadowing. If you need to use Safe mode to remove or disable components, restart your computer, press F8 to select advanced setup options, and then select safe mode.
STOP: 0X000000FC (0XB4116C40, 0X29F95963, 0XB4116B7C, 0X00000001)
Beginning dump of physical memory. Physical memory dump complete. Contact your system administrator or technical support group for further assistance."
Every time I restarted the system the above blue screen appeared. Then I decided to remove the 3870 X2 and put the 1950 XTX back in. No blue screen appeared, so I nstalled the 8.2 drivers with no problem. Then again I switched the cards so my system had the 3870 X2 in it and turned on the PC (the only difference was that unlike the first time, this time I had the 8.2 drivers installed already). The blue screen appeared again, but after one restart I didn't see any blue screen, and the only message I got was that there was an unknown PCI device (a yellow questionmark in device manager under "Other Devices - Pci Device" ). The computer was running fine, I played a couple of games and for about a week I didn't have any blue screens (just the message for the unknown PCI device).
Recently, the 8.3 drivers were made available. I downloaded them from ATI site, I unistalled the 8.2 drivers, but when I restarted the blue screen appeared again. I resolved the situation following the same steps described in the previous paragraph.
It seems to me that every time that ati drivers will be updated, in order for me to install them, I will have to switch to my previous card, install them and then put the 3870 X2 back in again.
  • Dell Master
  • 1,183 Answers
The problem could be casued because of loose memory module. Follow the instruction given below to remove and reseat the memory on the system.
http://support.dell.com/support/edocs/systems/dim3000/en/SM/parts.htm#wp1076397
Additonaly you can run diagnostics on the computer to check if the problem is because of faulty component
1. Power on the computer
2. On the dell splash screen tap on the f12 slowly 5 times
3. select the option boot to utlity partsion
4. Select 32 bit diagnostics
5. Select express test
Post the results here if any
Thanks
proton
  • Mandeep  Singh
    Mandeep Singh Sep 20, 2008
    Follow the following wizrad to troublesoot the blue screen message .
    http://tinyurl.com/4ov3ro
    Thanks
    proton
  • Mandeep  Singh
    Hey,
    Sorry for the delayed assistance ... it was night time in my side of the world.Ok if the test failed and returned the error code you mentioned , its normal. Now you have two choices to make from here , 1 if you have critical information on the computer, you can try repairing windows xp , but for the same you would require the the windows xp cd. You might need to call dell fro the same, they would give it you free of charge.
    2. You can reset the computer to factory defaults,but the only drawback of the same procedure is you would loose everything installed and stored on the computer after you got it .
    Thanks
    Proton
    Scholar:
  • 73 Answers
To temporarily turn off DEP and get into the system, please do this: Start the system in safe mode by pressing F8. When the system starts, double-click on the system icon in the Control Panel and select the "Advanced" tab. Now click on the "Settings" button under the head "Start-up and Recovery." In the dialog box that pops up, please click on "Edit". This will open the Boot.ini file. In that, look for the word "/NoExecute=OptIn" and change it to "/NoExecute=alwayaoff", save the file, and restart. To permanently solve the issue, please update the drivers of your additional hardware such as the TV tuner cards by downloading the latest drivers from their respective sites. If the Stop Error happens to be any thing other than the error discussed above, then go to support.microsoft.com site and type in the error number in the search text and search. If you are still not able to find a solution, please mail us the exact error code and we can help you out. Please e-mail at eworld@thehindu.co.in
  • 61 Answers
You might have installed driver software that may not be compatible with you computer. Therefore, a blue screen will come up with a register code description of the certain file that can corrupt the OS.
    Master:
  • 726 Answers
Go to start then control panel and then to system maintenance then to system restore it will take you back to when your computer was good and fix al;l the errors
  • chris07551 Sep 20, 2008
    welll u need to put the windows xp disc in and press repair windows
    nothing else you can do you can get a new hard drive? or have tro download xp off someone elses pc then repair yours with it
Hello i have an HP windows 7 i turned it on and it goes to blue hp screen and freezes up
A blue screen error usually comes up on Windows 7 when there is a serious hardware or software issue that may be causing Windows to Shut Down unexpectedly. At times, a message may also come up on your screen saying "Windows has been shut down to prevent damage to your computer."
To troubleshoot this issue, you may need to try out multiple troubleshooting options to detect whether the issue is with your hardware or software and to resolve the same as per the recommended procedure.
To know more about your troubleshooting options to get rid of blue screen error, you need to refer to the following Microsoft and HP support pages:
http://windows.microsoft.com/en-in/windows7/resolving-stop-blue-screen-errors-in-windows-7
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00372711#N182
The above troubleshooting steps may also help you to resolve the freezing issue. If they don't, please let us know so that we can suggest you additional troubleshooting options for the same.
GuruAid.com
Jul 13, 2014 | Computers & Internet
I'm unable to start my computer. Everytime I do, I get this blue screen saying a problem's detected and when I click the startup repair, I still get that blue screen again. Help
Startup repair is only meant for fixing software startup issues, mainly programs blocking a startup or registry/startup config errors.
The BSOD or Blue Screen Of Death error is generally aimed at hardware errors. Specifically, it could be your RAM, Hard drive, or any other main component in your computer. The most common is RAM, try replacing your memory sticks and see if it works. Hard drives can cause this error as well when they are on their last legs.
All in all, you may have to re-install windows completely.
May 04, 2011 | Lenovo Elite ThinkPad X200
My computer is stuck in a roboot loop. i have windows xp OS. it suddenly shutted down n when i start my computer now, it shows me a blue screen with message that a problem has been detected and windows has...
a_mamatha
If you can reply back with the error message as well this will better help me see what is going on with your computer. If you look at the link below it will show you the info that I looking for.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Issken
Apr 14, 2010 | Dell Computers & Internet
Whenever I plug in a usb port device,jumprdrive or whatever, I get a blue screen telling me something it will start dumping memeor and then gives a stop message with a bunch of numbers in brackets. Here is...
run the chkdsk /f on command and prompt
Start, all programs, Accessories, COmmand and prompt on the black screen type chkdsk /f or chkdsk /r restart the computer and it will check for errors and fix them..
if that doesnt work try unintalling the usb driver and then reinstalling it. start, Control panel, system, Device Manager, on device manager , click on usb ports and uninstall it .. or click here http://search.la.dell.com/results.aspx?c=pr&l=en&s=gen&cat=sup&k=usb+driver&rpp=12&p=1&subcat=dyd%2f1000&rf=all&nk=f&sort=K&ira=False&spf=Latitude&ssysid=Latitude+D520&ssysn=D520&~srd=False&ipsys=False&advsrch=False&~ck=anav
this is the dell driver list download any of those 3 drivers and install them . restart the computer and see if the problem stops.
Feb 18, 2010 | Dell Latitude D600 Notebook
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
Page fault in nonpage area
Restart the Computer and keep tapping the F8 key for 5 to 7 seconds to display the Advanced Boot Option screen. On that screen, select "Last Known Good Configuration" option. Furthermore, if you've installed any new hardware then uninstall it.
Once the Computer is able to boot successfully, run "chkdsk /f /r" utility to detect and repair any disk errors.
Faulty hardware, a buggy system service, anti-virus software, and a corrupted NTFS volume can all generate this type of error.
Aug 29, 2009 | Computers & Internet
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
I have a Dell (about 2yrs old) I downloaded what I think was a Windows update. It took a long time. When I restarted my computer, a blue screen came up that said "A problem has been detected and...
only thing i can tell you to do is that sounds like your windows download did the samething it did to me and the only way to fix it was to reboot the system with the reboot disks anything anyone eles says i donot think will work but rebooting it will work
Jul 14, 2008 | Computers & Internet
ERROR MESSAGE READS...
Try starting it in safe mode. (Hold F8 after power on). If you get your icon screen go to start, run and type in msconfig. Click startup and disable all the items. Hit OK and try a normal restart. This error can be caused by a bad program starting up.
Aug 30, 2007 | IBM ThinkPad 600X Notebook
Dell Dimension 3000 PC Desktop Logo
4,216 people viewed this question
Alun Cox
