Question about Whirlpool Washing Machines
Flashing lights and beeps
I removed a few coins from the pump duct but the machine keeps on beeping and flashing its lights. Any ideas ?
  • desfen Sep 22, 2008
    Thanks for your answer SearsTechToo.
    I think the pump is working fine because I have seen the machine drain water properly. Not for long though. In fact, no single stage of the entire program seems to be able to go on for longer than thirty seconds. After that it starts beeping and flashing again. The machine even beeps at me half a minute into a 30° C "delicate" washing program when no pumping or "high-speed rotating" (don't know the proper English word) is taking place.
    I'm having a repair guy take a look at it today.
  • desfen Sep 23, 2008
    For future reference for anyone else who sees the flashing lights and the beeps, it was the carbon brushes that were worn out. The service guy replaced them and all is well.
    Novelist:
    Champion:
  • 261 Answers
Check your drain hose for a proper air gap to prevent siphoning and back pressure on the pump and did you check the pump impeller for damage or separation? Is this a Cabrio or ?
Posted on Sep 20, 2008
  • John Robbins
    John Robbins Sep 23, 2008
    Ok then the tech will probably find the user interface is malfunctioning:)
  • John Robbins
    John Robbins Sep 24, 2008
    Yeh that is the interface
My Whirpool Duet front loader will begin a wash cycle, but stops when cycle switches to rinse with water in the drum. Door remains locked & light by the 'wash' flashes 9 times...
when the machine is stopped can you empty the residue water that remains by the programme selector? if not check for blockage in the pump(coin), the hose internal blockage ,or at the outlet under sink. I hope this help
Jan 15, 2015 | Whirlpool duet Washing Machines
Anti crease light flashing, keeps stopping and beeping
Check the dryer vent to see if it is free and clear.
Jan 26, 2014 | Miele Dryers
Gw612 won't agitate
Fantastic that's great news you got it going.
Oct 04, 2013 | Fisher and Paykel GWL11 Top Load Washer
The light keeps flashing an going beep beep dishwasher isnt doing it's job not washing
On my dishwasher if I hold down the start button for a few seconds it resets the cycle could you do that with yours as mine is a different make?
Feb 02, 2013 | Dishwashers
Simpson encore 605 fault code are as follows during wash process stop suddenly, strat to beep and all lights are gone except the Maxi light . It flashs while beeps
Hi, my Simpson encore 605 wash machine wash on the half way keeps beeping, and the maxi is keep flashing. What kind problem it is?
Cheers!
Feb 12, 2012 | Washing Machines
Washing machine flashing FH and beeping
This should take 30 minutes: Remove the panel that is located below the front door, there are 3 small screws located at the bottom that hold this... you will see the water pump, which has a access screw plug. Unscrew this, its like a filter, you may see stuff, like coins, socks, etc, remove and clean out, then put
everything back... this should fix the issue.
May 31, 2010 | Kenmore Washing Machines
Beeping noise
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 20, 2009 | Washing Machines
XP 2070 Won't Stop Beeping
Okay, I had the same problem, started beeping and lights flashing one day, unplugged it and it was okay for a few days then this started happening more often until the machine just beeped and blinked all the time and would not make espresso. When I called Krups customer service I was told it sound like a circuit board problem and to send it in, yes its under warranty but I have to pay shipping both ways, so I decided to check it out myself. So here is the bottom line and what worked for me, I removed the espresso screen (above coffee grounds holder, 1 phillips screw) and ran 4 tank fulls of descaler thru the machine. the hard part was getting it to pump thru the machine. I found if I ran water thru the hot water/steam nozzle first I could get it to run 1 or 2 cycles, I also found that by removing the water tank and turning the system on for a few seconds and running pump dry (not recommended) I could get it to cycle without blinking for a few turns. Ran the 4 tanks of descaler thru, then ran 4-5 tanks of water thru into a bowl until it ran thru clean. The machine is 4 months old and I was shocked at the amount of crud that came out. It now runs fine and no more blinking, If indeed this is the fix for this you would think someone at Krups would have a clue, but I guess there a useless a the owners manual for the xp2070.
Thanks and I hope this helps.
John
Apr 24, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Washer beeps Ld a few minutes into each wash
LD means = Long Drain
Problaby samething inside the pump
Is your machine calypso
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
prem mathew
