Router Problem I can not figure out my router connection with Shareaza. " Connection TCP refused and no answer from lap-top... Thank you
Lap top wireless connection to internet router
you need to turn on the wifi button on router
Feb 16, 2014 | HP Compaq nx6110 PC Laptop
How do I configure my router (Netgear) to receive Shareaza connections?
model number of router please? and what is Shareaza connection? some sort of wireless service?
Apr 28, 2008 | Computers & Internet
Although cable to desktop connects to internet, my router from desktop to laptop via router won't connect.
Desk top to internet is OK.
How about Destop through Router connection to Internet OK?
Assuming you want to connect wireless from Lap top to Network, need to configure correctly for wireless in Router.
If you connect Lap top to router by wire and it didn't work that mean your router is bad.
Jul 03, 2009 | Linksys WRT160N Wireless Router
No Internet connection
First of all I am interested to see the output of this on both machines:
Start->Run->CMD [Enter]
In the Black box type:
ipconfig [Enter]
I would like to see this information if you could be so kind.
You need to check your TCP/IP Settings to make sure they are both set to DHCP which will make it receive a Dynamic IP Address. Also it should set the gateway address for you but you may need to specify the correct addresses for IP, Subnet, Gateway and DNS to ensure immediate access to the internet. Most likely you are in this range but I could be wrong:
192.168.*.* IP
255.255.255.0 Sub
192.168.*.* Gateway
DNS Depends on your ISP but you can find out the information by logging into your router for instance:
http://192.168.1.1 will get you to your router if
your IP one of your clients is 192.168.1.*
Dec 10, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Cannot install D-Link router
1. check your wireless adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 just check the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
Hope this will help
Nov 24, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
My laptop suddenly cannot connect to the router.
It comes down to a few things with routers and wireless connections:
1. If you have been dropping the signal over the past few weeks try doing a test on the wireless network connection via the diagnostic tool within the specific wireless connection.
2. You may have gotten a bad update to the wireless card. Try uninstalling it and then reinstalling it.
3. Try deleting the wireless connection for your router and then make 'a new' wireless connection.
Oct 15, 2008 | Belkin (F5D7230-4) Router (587009)
Set up problem
First make sure you have the blue cable connected from your modem to the wan port on your router. This is the port closest to the power connection. Make sure all of your computers tcp/ip settings are set to obtain ip address automatically. If this still doesn't work unplug your modem and router at the same time for about 60 seconds. Plug in your modem and after all lights come on except the activity light, plug in your router. You should have have the power light, wan light and however many pcs are connected and on lit up. This should solve your problem. If not, add a comment and I'll be glad to come back and help.
Mar 21, 2008 | Linksys Wireless-G Broadband Router
D link Router & my laptop
Debugging the issue -- this is not a solution.
Have you plugged a computer into the router if possible using an ethernet connection? Did it successfully access the internet?
If not the ISP (modem?) side of your router is probably configured incorrectly for your ISP
If that works wireless routers and adapters operate different bands I know of A, B, G and N. Do both your router and adapter card have at least one of those bands in common?
At any time have you attempted on the laptop to connect with the router? When connecting do you see your router by name? has your router been set to a unique name so you aren't confused seeing one of your neighbor's routers?
Did you enable encryption (WEP or WPA) in either the router or the wireless adapter and not enable it in the other?
Do you have MAC filtering on in you router and forgot to enter the wireless cards MAC accress?
Please reply with as many answers as you know and we can step through the process to attempt to complete the connection.
Also please provide the manufacturer and model for each of the following
Your router, your laptop and your network adapter
Please provide the operating system installed on your laptop,
If the wired connection to the internet does not work please provide the name of your internet service provider.
Dec 18, 2007 | Computers & Internet
Was connected but now I'm Not!
I think this is a setup error.
What kind of router do you have? Also can you connect to the router with a wired connection?
After you answer those questions I will give you some troubleshooting steps.
Oct 22, 2007 | Dell Wireless 2350 Router
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
