Question about Toshiba Satellite P35-S611 Notebook
Always running on batteries
The problem I'm having with my toshiba, it is always running on batteries.
The power pack is plugged in but for some reason it trips off the power supply and starts running on batteries until it just dies. Eventually I can plug the PS back in and it will charge until it switches over to battery again.
Please help ..
Once the batteries runs out it shuts down but the blue power button stays on. So i take the power out and replugs it and i notice that the battery starts charging again so I wait till it's full and I use the laptop.
thanks
nadia
  • 4 more comments
  • Anonymous Oct 14, 2008
    I have the same problem but my unit will not run on AC alone. Once the battery has a charge it will run until battery is exhaused.
    If I try to boot from AC only it gets to the point where the hard drive is accessed and it shuts down abruptly.
  • froggyziffle Nov 16, 2008
    In my case this is certainly related to the power connector being broken where it connects to the motherboard. I have done several things to verify this. Whether or not it is repairable I don't know as I can't figure out how to take the case apart. Removing all the (many) screws from the bottom doesn't do it.
  • bitringer Jan 06, 2009
    I have the same problem on a client's P35-S605. It runs on battery alone. When AC is plugged in the charge (orange light far right if 3) blinks on for about 2-3 seconds and turns off switches to battery power and if low battery shuts down. I found if I plug into AC and remove the battery it will run on AC. Battery only charges when powered off not while running and w/AC & battery. It is not the PSU as I've tried another PSU AC adapter.
  • Anonymous Jan 22, 2009
    I aswell have the same problem. If bat. removed pc will shut-off. I felt it was the power supply, but it checks out ok. Then it was a connection, sometimes it comes back by moving the connection around. Now I feel it is in deed the motherboard issue. I have been looking for these over the net, I cant find one. Repair place is charging $60 for the connection part and $300+ for new motherboard. I love my laptop but not this badly. I need help finding parts for DIY.
  • JTrickey Jan 22, 2009
    I have the same issue. It bat. is removed the pc will completly shut-down. My fix was put in hibernation mode take bat out then plug back in this will last a couple min. on full power. I took it to my local repair, they tested the power supply it check out ok. At first I thought it was the connection, sometimes moving the connection it will help. Now I do indeed feel its a motherboard issue. I have searched for motherboards but do not have a part #. The repair shop wants $60 for the connection & $300+ to replace the motherboard. I love my laptop, but not this bad. I need to find a motherboard so I can DIY.
  • cjcarlos Jan 25, 2009
    I have the same problem. It will not run on AC alone but switches to batteries when battery is in. Indicator shows AC is plugged in but runs on battery till empty. Found suggestions in laptoprepair101.com. but have not tried them. The problem is supposed to emanate from a weakened joint between the motherboard and power jack.
    Cecil
Relevant solution welcome to: http://www.uk-power-battery.co.uk/
http://www.all-good-batteries.com understanding.
Posted on Nov 18, 2011
    Scholar:
  • 67 Answers
You can still use your laptop even if you take out the battery and run on ac alone. You can also leave your battery in with the ac plugged in for 4 hours to charge it even if the laptop is off. Hope this helps. Thank you.
Posted on Oct 04, 2008
Plug in charging.When charging the laptop,the amber light blink on and off indicating battery is charging.But the pile does not rise up.The power level always reads 0%.
Try removing the Battery and running the Toshiba on the mains charger alone.
I suspect the Toshiba will start up and run fine. If so, it appears that you need to buy a new Battery,
Batteries do not last a very long time and all sorts of things can shorten their lifespan.
Sep 10, 2014 | Toshiba Satellite C50D-AST2NX1 Black 15.6"...
Have a toshiba satellite a305-s6853 and it wont power up is thier an internal fuse
Remove your battery plug in your a/c power - you should get a power led light on your unit - if not power led try your power pack on someone elses toshiba or try there power pack on yours - if a good power pack starts your unit then refitted the battery whilst its running and left it charge - that means you have a dead power supply - if it doesn't respond with and alternative power pack your d/c input cct has failed. new m/board.
Jul 10, 2011 | Computers & Internet
Battery runs out after 15 minutes, need to keep plugged into outlet to work.
Hi
It mean that you have to consider replacing battery because it drain fast your battery due to wear tear.
Jan 12, 2011 | Toshiba Satellite M35X-S161 Notebook
How can i charge my onboard battery offboard? ineed to take the batter off and charge it indoors
Keith You have to remove the seat from the scooter and then lift the battery pack out of the frame. On the front of the battery pack there should be a charger port where you can plug in the charger into the battery pack when you are inside. Plug your charger into the battery pack first then plug it into the receptacle. When fully charged unplug from the receptacle first then unplug it from the battery pack. In other words always have the charger unplugged from the power when plugging and unplugging it from the battery pack. Velcro is holding the pack down so you might have to give it a good yank to get it off the frame. Hope this helps
Oct 20, 2010 | Pride Mobility Products Go-Go Elite...
DS-2000 (90) series with #497 Autostar. Won't turn on. Replaced battery pack (8 AAs) with 9v battery and tried that and it still won't turn on. The indicator light remains dark as does the autostar...
There is a small spring inside that sometimes gets STRUCK DOWN-- this automatically turns off the internal batteries, as the scope things a separate 12volt power pack is plugged in.
Get an external 12 volt power pack and the correct 12 volt cable, and power it up.
If the light comes on and it works the switch is broken. Not really a problem as you should always run a goto scope on a separate power pack.
Aug 27, 2010 | Meade Optics
Battery problem
all laptops are capable of running strictly on ac power. if your battery is not charging it sounds like time to get a new one.
you can get one here:
http://www.atbatt.com/laptop-batteries/b/toshiba/m/satellite-m35x-s161.asp
Sep 14, 2009 | Toshiba Satellite M35X-S161 Notebook
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Regards.
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
About my batteries
When Plug the AC power cord, what the power indicator light want turns on, indicating that charging has begin.? The battery pack has a limited lifespan. Battery pack duration will decrease with repeated usage and age. If the battery pack duration declines greatly, it may be time to replace the battery pack. Hope this helps
Oct 30, 2007 | Sony VAIO FRV28 Notebook
Toshiba Satellite P35-S611 Notebook Logo
198 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
