Question about Canon CanoScan D1230U Flatbed Scanner
Windows vista 64 bit driver
Is there a Windows Vista 64 bit driver available for the CanoScan D1230U?
The driver I download from Canon (d1230ufvst611den) is not recognized by Windows Vista.
  • 558 Answers
Hi mtrump1,
Thanks for your posting in FixYa.
The driver are available on the Canon Website, use this link to get it:
For Vista 64 Bit you can try:
But i think both should be compatible to run in any 32 or 64 bit environment.
Posted on Sep 20, 2008
Hi I bought a Canon Canoscan FS4000US used online. No driver came with product. Canon website does not offer any downloads when viewing canon website with WIndows Vista 64 Bit. It does show available...
When I go to the Canon site, I get prompted to select my OS: . On other parts of the Canon support site, I need to click on a Change OS link to get that dropdown menu or swap to the Select OS in that dropdown menu and then refresh the page. Then I can select a new OS. (Note the site uses Javascripts that do not seem compatible with all browsers. I found it worked with Firefox 6.0.2 . The exact location is hidden until you agree to the Canon Terms of Use.)
However, this driver, fs4000usvst103ben.exe, is listed as a Vista 32-bit driver released in 2007. Since the 64-bit Windows requires signed drivers, Canon doesn't make 64-bit drivers for their older scanners. (This scanner was released with compatibility with Win98.) Thus you will probably get an error message about the unsigned driver when you try to install it.
If the driver refuses to install, you may be able to run the driver installer by using the compatibility mode. Download the file and save it to your hard drive. Right click on the exe file and choose Properties. In the Compatibility Tab, select Run this Program in the Compatibility Mode and choose XP. Click Apply and then OK. Right click again on the exe and choose Run as Administrator.
I hope this helps.
Sep 10, 2011 | Canon CanoScan FS4000US Film Scanner
I need to get 64 bit driver for canoscan 4200F the file is no longer on the canon usa site and on the canon uk site it fails to download at the "accept licence" page. I also need the 64 bit canoscan...
Are you looking for the Window XP 64bit drivers? As those are not listed on Canon's support site but the Vista and Windows 7 64 bit drivers can be downloaded from the support site link below. The ScanGear software is also available on the USA site.
Robert from Blitware
Jun 16, 2010 | Canon CanoScan 4200F Flatbed Scanner
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
CanoScan N1220U Scanner Windows 7 64-bit Driver
You may use Hamrick VueScan Pro, it installs a driver that makes 1220 to work. Or, if the version of Windows 7 you use support XP Mode, install it.
It's still a good scanner, and mine is working in 7 x64 using XP Mode!
Sep 17, 2009 | Canon CanoScan N1220U Flatbed Scanner
I have an HP laptop OS Vista i tried to
Hi There,
there are no 64 bits drivers available on the cannon website(x64) and you cannot install it using the 32 bit vista driver
Sep 03, 2009 | Canon CanoScan 5000F Flatbed Scanner
Canon lide scanner vista 64 drivers
This is the link to the drivers and CanoScan Toolbox.
Click on the
Drivers & Downloads on this page then choose Vista(64) as your OS
Apr 11, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Driver for Canoscan N640P for windows vista home premium 64 bits
You may be out of luck; here is a version for XP/NT that you could try to force-feed to see if it will work;
# Model: CanoScan N340P
# Size: 3.73 Mb
# Version: 3.8.2
# Date added: 09-Jan-2007, 10:36
# Manufacturer: Canon
# Device type: Scanner
# Operation system: Windows 98/ME/2000/XP
# MD5: 582d83ae6df3ea4bd0a3465a2750c020
You can download the driver from this IP address ( within 24 hours. After 24 hours you will have to use the driver request form once again. Thank you for understanding.
Dec 15, 2008 | Canon CanoScan N340P Flatbed Scanner
Canoscan does not work on vista 64-bit
I'm not sure if this will work on the lide 20. I have an lide 35, and there are no 64 bit drivers for it. I downloaded and installed the drivers for the lide 60, told the computer to manually find the lide 60 drivers for my scanner, and installed the canoscan toolbox for vista 64 bit. Works like a champ.
Nov 07, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan 8600F
Download the Scanner Driver here for Vista
Click Windows Vista and then Download the right choice one for you.
If your don't know if your Vista is either 32-bit or or 64-bit download the second one which will work for either of the 2.
Good luck
Jun 18, 2008 | Canon CanoScan 8600F Flatbed Scanner
CanoScan Vs. Windows Vista
Tom, your solution is incorrect. I have just got my Canoscan working fine with Vista, simply using Canon's official XP drivers and unpacking them in XP compatibility mode. Is working fine with just a bit of experimentation. (You need the Canon toolbox software too, all of which is available from
Nov 02, 2007 | Canon CanoScan N656U Flatbed Scanner
Canon CanoScan D1230U Flatbed Scanner Logo
1,031 people viewed this question
old marine
old marine
