Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
HP f1503 flat panel
I have the same problem as several others. My screen remains dark;I can
make out very little information on screen. My f1503 montor is 4 years old.
  • 2 more comments
  • riley_25188 Sep 20, 2008
    Already tried adjusting screen options, this did not work. Thanks anyway.
  • jorgela510 Oct 09, 2008
    HP f1503 flat panel monitor continuously goes black or little visibility
  • jfg14231 Jan 01, 2009
    my screen is mostly black and you can hardly see the images on my desktop
    I have tried adjusting the monitor settings but it did not work.
    Any other suggestions. Is it worth having it repaired?
  • nicknick_70 Jan 28, 2009
    darck monitor HP F1503 and 2 or 3 liners i coll the company in Canada and no have any answer is brock yes or not
I had the same problem, doing a research in the web i found that most of the causes was dry capacitors, this monitor has 6 blue capacitors in its AC/DC inverter card (you'll see these together with some kind of white grease), i tested all of them with a multimeter looking for resistence and found 3 with different readings than the other ones, so i went into the electronic shop and bought 3 new ones (same specs), i told the guy to change them for me due to i have not soldering skills. I just put back the AC / DC inverter board and boom!!!!, it works. 50 Pesos / 4 dollars fixed the problem, and i was just thinking to buy a new monitor.
How to get in to the inverter? (I know alot of expertice people know how to do it, but this process is for normal guys like me)
1. have to take out 2 screws at the back of the monitor, these are the ones holding the screen to the base arm, these screws are hiden by 2 rubber black seals. (this step might be jumped, but will give you better space to work)
2 with a flat small screwdriver and patience (the ones used to fix clocks), start taking the gray plastic frame apart, this is the one infrontwith the HP logos and the display controls logos, start from 1 corner and go down.
3 once the plastic cover is out, you will see the flat screen attached to the back black plastic cover, remove all the screws (7 or 8 do not count them).
4 pull the screen and place it in the table face down using a towel to prevent scratches, do not remove the conections from the flat screen to the boards.
5 remove the metal cover (the one is protecting the boards), it has 1 screw and you ll have to take the 2 nuts in the screen connector port (the one you use to plug the monitor cable). than push the cover down to release it from the wing locks.
6 once you remove the metal cover, you ll see 2 cards, the one at the right is the inverter, youwill se the 6 blue capacitors i am talking about. Also check the 2 varistors j22 at the front of the card.
7, if you do not have soldering skills, make somebody else with soldering skills to do it.
Hope this help, and sorry for my english.
Enjoy your repair.
ME
Posted on Jan 17, 2009
  • 61 Answers
Based on the User Manual try to adjust the brightness using these steps:
1 Press the Menu button to open On Screen Display to the OSD
Main Menu.
2 Press a Browse button to navigate the setting menus; see the
following setting menus table.
3 When the menu you want is selected, press the Select button to
open the setting screen for that option.
4 Adjust the setting by using the instructions described in the topics
that follow for each type of setting.
Posted on Sep 20, 2008
What could be wrong with HP Pavilion f1503 screen?
This is usually faulty capacitors. They are in charge of regulating the power of your monitor, with time, they will go bad. The replacements of this capacitors is usually under $10 or $15 usd.
You will need to open the screen, identify, unsolder and buy the new ones to later on solder back and BOILA!
Aug 19, 2014 | HP Pavilion F1503 15" LCD Flat Panel...
Pc entering power saver mde
This message apears when there is no input coming from your computer. There should be a bution you can puch on the monater that would cnahge it from digatail to analog this may be the problem that you are having problems with
May 21, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Mouse hanging up
is the mouse wireless?(try a new batt) optical,try another mouse.
Dec 25, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavalion F1503 15"
A quick Google search turned up a couple of sources for generic replacements:
http://www.lcdparts.net/CCFL1.aspx
and
http://www.ccflsurplus.com/laandmoba.html
Looks like they might be promising. A possible source for the original HP part might be Vance-Baldwin (www.vancebaldwin.com). I have purchased other HP parts from them.
Sep 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Power cord
the HP part number for the US power cord is
8121-0740the part number for the US power adapter is
5189-2852
Aug 07, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Computer monitor screen remains black
try giving the monitor a hot slap or spank at the back, believe me, you'll be surprise, you've got nothing to loose
Jul 20, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Flat panel hp f1503
Most likely you have degraded electrolytic capacitors in the internal power supply. If you can disassemble your monitor to liik at the power supply board you might notice bulging capacitors which if replaced will likely restore normal function.
Mike
May 29, 2008 | HP vs15 15"LCD Flat Panel Monitor
Faint screen
try resoldering the ciols on the power/inverter board.
can also check for cold solder on output transistors and coil.
pd
May 08, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Samir
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Screen So Bright I Can Barely See Anything...
The auto dimming circuit on the ccfl inverter is out.  Replace the inverter and it should cure your problem.  Seek adult supervision for this repair. Do not try it by yourself.
srich
Jan 23, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
1,215 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
