Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
New maytag bottom freezer
We moved it home by laying it on its back. 45 min trip. How long does it have to set upright before we plug it in?
  • 126 Answers
Posted on Sep 20, 2008
After moving to a new home, the freezer keeps tripping the breaker every few days
My first instinct is to ask you, are you plugging this freezer into a GFI outlet, one which has a breaker switch as part of the outlet? If so, that is the culprit and not the freezer, as refrigerators and freezers will often trip this ground fault indicator because water can on occasion reach ground, which causes the breaker to trip on the outlet.
Test this by plugging the freezer into a non GFI outlet for longer than a few days. Nothing is broken and you dont need refrigerator repair service.
Sep 29, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
How to move a whirlpool freezer on its side
You can lay the freezer on its side to move. If it is on its side for over 30 Min's though you will need to stand it up for 24 hrs before you plug it back in to the power. You need to do this so the freon settles back to the compressor.
It is always best to move them standing up.
Apr 23, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
I just set up my Frigidaire upright Freezer, only
Rule of thumb, if you lay a frig/freezer on side let sit upright at new location for 24 hours before plugging it in.
Mar 07, 2010 | Freezers
Can we lay a freezer on its side temporarily?
You can do it but be sure to let it stand upright for 24 hours before plugging it in and using it. The oil in the compressor will run out into the lines and block it. It needs time to drain back to the compressor.
Jan 01, 2010 | Freezers
I am moving and need to lay my upright freezer down for the 6 -8 drive. will it harm it?
No it will not harm it. you will just need to stand it up for 24 hrs befor you plug it back in. That way all the fluideds go back to the bottom the way it should be.
Good luck and please rate
Sep 16, 2009 | GE 203 cu. ft. General Electric Upright...
Moved fridg to new house pluged it in dosen,t get coled at all!!!
If you had to lay the fridge down to move it? Then you have to let it stand upright for at least 24 hours before you can plug it in and use it or it won't cool, as oil will get into the coolant lines and foul the works.
If you didn't have to lay it down, then check for a switch and or harness under the front grill that may have got bumped out of adjustment of knocked the plug off.
I hope this helps you, and good luck.
Sep 16, 2009 | Maytag MBB2256GES Bottom Freezer...
Is it Ok to lay a refrigerator on it's side for a short time (less than 30 min.) while moving.
Yes, you can, but allow a couple hours in the upright position before turning it back on.
Aug 15, 2009 | Amana Easy Reach Plus ABL2227FES Stainless...
Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
Jun 27, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Moving a Kenmore upright freezer
there would be a problem if you lay it down. it should be moved up right or max 45 degrees tilt only. oil in the compressor could go to the evaporator and clog it.
front handles could be remove only from the inside. you have to remove the plastic rack of the door and remove the insulation in order to see the bolt holding the handle.
tnx 4 using fixya,
Oct 08, 2008 | Kenmore Freezers
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
85 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
