Question about Video Game Consoles & Games
I updated my ps3 to 2.43 and it died the next day,no power at all,no lights ,or nothing!
  • verntjbaker Sep 20, 2008
    i have a original 60 gig backwards compatability,sd card slots and 4 usb ports,so it would really **** if they won't send my system back!!!and gave me a refurbished 1!!!!!
    i would look at upgrading the hdd but even if i replaced it,theres still no power to turn the thing on!
  • 61 Answers
People all over the world have had their ps3’s crash. FYI if you’re out of warranty you’ll have to pay $149 AND with or without a warranty they will not send you back your original ps3, they will give you a refurb.
Posted on Sep 20, 2008
  • Aladdin Minic
    Aladdin Minic Sep 20, 2008
    I would just void the warranty and install like a 250GB hard drive in the PS3. The ps3 uses an ordinary sized laptop HDD which is 2.5 inches. You can back up the files if you place the ps3 HDD into a laptop and then use yours or your friends external hard drive, plug it into your laptop and remove and replace the 250GB you are going to use for your ps3.
    If you don't care about backing it up then just open up you ps3 and install the larger HDD and install the firmware.
  • Aladdin Minic
    "250GB" was just a example of a size you can use.
2004 Nissan Altima 3.5L BATTERY LIGHT went on during 15 minute drive. Next day car "died" while idling after a 20 minute drive. BRAKE WARNING LIGHT & BATTERY LIGHT on prior to full electrical failure.
Start with checking the alternator voltage with a multimeter. With the car off check the voltage in the battery which should be holding 12v charged less if flat of course then start the car and test the battery again. If the alternator is good you should be getting a reading of 14 to 14.5 v if it's the alternator it'll A) not put any charge into the battery or B) be a very low voltage being anything under 13.5 v
Sep 30, 2016 | 2004 Nissan Altima
Zenith tv converter box stopped working
I just replaced two DSTV converters that abruptly failed so your guess probably is right on target.
Sep 12, 2016 | Zenith Dtt901 Digital Tv Tuner Converter...
2000 Dodge Status SE, runs for a bit then cuts off. Had a brake light that did not work with headlights on, changed bulb, a day out so later car shutters and dies. Get it started a couple times and manage...
I think... you have an electrical grounding problem, and it's responsible for your right-side lights failing as well as being responsible for your fuel pump (in the tank) not getting any power, which would explain the car dying.
When it stutters & dies, I'll bet you can't hear the fuel pump humming, can you? But you CAN hear the fuel pump humming on days when it starts right up.
...and it's all down to a bad connection someplace, a connection that gets shaken as the car is driven. A GROUND (negative) connection, somewhere between the battery, the engine, the firewall's sheet metal, the dashboard, and the rear of the car.
Jul 29, 2014 | Cars & Trucks
New battery In mercedes no power
I'm not a car mechanic, but, it sounds like you might want to check the fuse to the ignition switch, and, if that fails, it might be a problem with the Start Safety Switch on the transmission. Good luck.
May 02, 2017 | Mercedes-Benz S-Class Cars & Trucks
Battery light came on. same day while driving, it started to lose power. gas pedal wasn't giving power pulled over then died. wouldn't turn over replaced battery. next day took it for a drive was coming...
you alternator is no good to ceck alternator start car while running take off positive cable if it dies your alternator is no good but thats what it sounds like
Aug 20, 2010 | 2001 Volkswagen Jetta TDI
Hp pavillion dv2210us harddrive failure
sounds like it may have died try it in an external mount (on a different computer)
Aug 13, 2009 | Dell Latitude D600 Notebook
Hi, i have two benq 17'' monitors with similair faul odel number q7p3 , first one fires up half screen then dies , next has power light then nothing ,, any ideas ? phil
1st)>open the unit then find the Horizontal output then replace ( have a power but no display/off display
2nd)> same>Open then find Filter Capacitor and vertical IC then make a re-heat the parts or re-soldering then the filter capacitor make a replace...GOOD LUCK and HAVE a Nice Day
Jul 14, 2009 | Computers & Internet
Dodge ram van e250 dies while driving
try changing the coil- sometimes they get hot and break down- once they cool off vehicle will start and run until they get hot again
Jul 05, 2008 | 1992 Dodge Ram 250
Video Game Consoles & Games Logo
70 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
