Roland CX24 Plotter has origin error message - Office Equipment & Supplies
3 Suggested Answers
SOURCE: HP 800 designjet plotter Error Message 21:10
need to replace service unit
Posted on Mar 22, 2010
hoyle_jeremy
  • 219 Answers
SOURCE: My ROLAND cx24 vinyl plotter does not start
Do a hard reboot
Posted on Jun 20, 2014
My Roland Camm1 cx24 not powwering up
I would first make sure everything is plugged up correctly.
If this doesn't work I would look into the power supply inside the computer and having it replaced. other than that I'm not sure how to help.
If you have any other questions or info feel free to respond and ill see if i can help
Jun 19, 2014 | Computers & Internet
Roland drivers
ask them ,,, i think you use the adobe software provided ,
Mar 29, 2014 | Computers & Internet
I need drivers windowS 7 for Roland VersaCAMM SP-540V
hello
i add a video explaining how to install sp540v in win7
u need to install the Intercon-NetTool (that u can download from the Roland website) to allow the comunication with the plotter. its all well explained in the video. good luck
Feb 27, 2013 | Roland VersaCAMM SP-540V
Analog test eror onroland td5
I have the same problem with my module and I can\'t find the solution anyware for the thing.Closest solution that I could find is something about Roland power adapter.Apparently module won\'t work with any adapter with the same voltage,only Roland or Boss B.R.A. adapters works.I have original Roland adapter and still shows an Analog test error.
Have you find the solution in meantime by any chance?
Sep 09, 2012 | Roland Music
I need driver for my roland camm jet cj-500 printer. Thanks
hey!
i need driver for my roland plotter cj-500 any one help me for that
Mar 24, 2011 | Computers & Internet
When i turn ON the ROLAND-CJ 500, in the little screen will appear, "TEMPERATURE IS TOO LOW"...?
could you fix your roland plotter, because appears the same in my screen temperature is too low even is not, how can you fix this problem thanks
Aug 03, 2010 | Office Equipment & Supplies
Canon iPF8100 Error message E602 401b
Our Canon iPF810 recently had the error message "E602-401B" while it was still under warranty. At that time the hard drive was replaced, but it didn't solve the problem so the original hard drive was put back in and the firmware was updated and the machine worked fine for about 9 months.
We got the same message again and the machine was not under warranty so repair would be quite expensive ($1000.00 flat rate fee). After making calls to repair places, one place gave me some valuable information.
They suggested that if I could get into "Service Mode", select "System Setup" and then "Erase HDD". They said the hard drive probably needed to be defragmented. Amazingly enough, it worked! The hardest part was figuring out how to get into "Service Mode".
With the machine switchoff OFF, hold down the "sheet or roll feed button" and the "information button". Keep these pressed and switch the machine on, keeping the buttons pressed until you see an "S" in the top right-hand corner of the display, then let go of the buttons. You should now be in "Service Mode". Then go to "System Setup" and then "Erase HDD". Your machine should work after following these procedures.
It seems like the plotter stores every plot in its memory. After a period of time, the plotter's memory gets filled up and the "E602-401B" error message occurs. To prevent this from happening, periodically erase all the old plots. The procedure for doing this is as follows:
On the plotter "Main Menu" choose: "Job Management", "Stored Job", "Common Box", "Job List". Then delete each drawing/plot.
Nov 27, 2009 | Canon imagePROGRAF® iPF8100 InkJet Printer
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
158 people viewed this question
jasbo
jasbo
