Question about Bernina Artista 180
Speed does not stay constant
When I sew, my machine speed slows and stops. I have oiled the bobbin case but that did not help.
    Problem Solver:
  • 8 Answers
Hi, Chances are good that you need to have your foot controller repaired. The electrical contacts inside the foot control can either get dirty/dusty or worn out.
If it is not an electrical problem, like your foot control ( and I think it is) then it is a mechanical problem inside your machine. If it is mechanical and your machine is "binding up" , when it slows you would find it hard to turn the hand wheel located on the end of your 180. One other possibility is that the brushes in your machines motor are worn out and you need to have the motor replaced.
All three problems would require professional help as there are not any user serviceable parts on your machine. A good cleaning and servicing at a Bernina dealer should get you back on track.
Good luck, bushvideo
Posted on Sep 26, 2008
My Bernina 730E is varying in speed even though I am pressing foot pedal to thr floor. The speed does not stay steady, somestimes running extremely slow in full speed mode. What is wrong?
it could be pedal control or the speed control unit on the motor as it is reasonably common for that machine
take it in for a service to ensure that other factors ( thread around bobbin shaft, fluff etc is not slowing the machine
Nov 01, 2016 | Bernina Sewing Machines
When following manual directions to wind a bobbin, it starts out OK, but after several winds, the thread turns out with little loops on the bobbin. ??? Sylvia
Make sure that you are running the thread through the winder tension guide before it goes bobbin winder. Best to consult your owner's manual.
Also, it helps to slow down the winding process. Slower speed winds the bobbin more consistently and does not stretch the thread as much as a fast speed will.
Beginner Guide to Sewing Sewing Machine Parts Reference Guide
Nov 28, 2015 | Sewing Machines
Stopped sewing. can not move the balance wheel Frozen
suggest repair shop , it possibly has jumped time .
Sep 19, 2015 | Sewing Machines
My Sears Kenmore 158.14002 won't zigzag. All the setting are correct.
Have you cleaned and oiled it recently? If it is mechanical (NOT computerized), it needs to be cleaned and oiled regularly to keep it working properly. In your case, the needle bar movement is probably stuck. Consult the owner's manual in the Maintenance section, use only good quality sewing machine oil (fresh, not old stale oil), apply 1-2 drops each place indicated in the instructions. To speed things up, you can direct hot air from a handheld hairdryer into the area.
In the future, clean and oil every time you change a bobbin, every 8 hours of constant sewing, or every 6 months if not in regular use.
Sep 19, 2015 | Kenmore Sewing Machines
How do I fix the speed of stitching? When I press on the foot feed I get almost no speed from it.
unless it has been progressively getting slower, I did have a simular issue. My pedal was getting "stuck" at the 1/2 mark. (wasn't pressing all the way down). Drove me nuts. Took the machine apart, cleaned oiled, cleaned again blah blah blah...when the pedal was the last option took it apart and found a nut from a screw had gotten inside the pedal and stopping it from pressed down. There could be a burr, a nick or something it is catching on.
Sep 22, 2014 | Janome Memory Craft 4000 Sewing Machine
Rattle in the bobbin area.
make sure the bobbin is not warped or damaged
also make sure the bobbin fits securely in the bobbin case
does the bobbin case fit securely in the machine?
the bobbin case could be getting old & might need to be replaced.
Apr 12, 2012 | Sewing Machines
Sewing machine speed it won't stay the same
if you have a speed control on the machine & you set it & the stitches are not staying constant, then the machine needs to be serviced
Mar 13, 2012 | Kenmore 19365 Computerized Sewing Machine
My Janome magnolia is 3 years old. Last week I was sewing and everything jammed, needle went to side and broke. It was trying to run but couldn't. I took bobbin out and cleaned it, oiled everything, where...
Try the process of elimination. Take out the needle, take off the needle plate, take out the bobbin case. Run the machine. Does if run full speed? You might have to let the machine run for about 5 minutes. If it runs slow or you hear it slow down, you might have a bad connecting link between the needle bar and the main shaft counter weight. They seize up sometimes. (Shop Repair).
May 03, 2011 | Sewing Machines
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
199 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
