The viewsonic monitor I have is not showing anything on the screen . It is only two years old. The "on" light is flashing. Please advise
    Brigadier General:
  • 6,966 Answers
Your posted problem could indicate:
  • a faulty video card (or memory) in your PC (most likely);
  • a defective cable (least likely); and/or
  • a defective monitor.
Course of diagnosis which is at fault would involve:
  • trying the ViewSonic monitor on another PC;
  • trying another monitor in your PC;
  • checking/cleaning/replacing video card, memory or cable.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 20, 2008
ViewSonic LCD monitor displays "No Signal Digital" message
There is something wrong with the main logic board. The firmware thinks that there is a DVI connector installed. Such problems with other devices are fixed by reflashing the firmware. But I don't see any connector on the board for that purpose.The faulty flash memory chip is marked with "A", meaning there is flashed the "A" firmwre version of all possible versions - probably this with only VGA connector. My suggestions are: try to find similar working logic board. I didn't find any on ebay, but you may find somewhere else. The other option is hard one - to try installing DVI connector on this board. Unfortunatelly we don't know the parameters of the parts needed. There have to be several diods, some capacitors and a transistor, all SMD. There is also a missing 8-legged IC probably connected somehow with the DVI. :(
Just for case carefully inspect the cpu legs for bad solder.
Apr 07, 2012 | ViewSonic Graphic VG2021m LCD Monitor
Hi! My Viewsonic VA721 LCD Color Monitor's screen is getting darker over time. I've had it for about 5 years. Is it just getting "old" and worn out or is there something I can do to correct...
It can be that the power supply is dying due to bad caps (or worn out backlight lamps) as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
It is old monitor so it may not be worth spending on it.
Please leave rating if it helps.
Feb 02, 2011 | ViewSonic VA721 17" LCD Monitor
Have had the nx1932w for 4 years. turned on this morning and it only shows a blue screen with message stating no signal. have digital cable and all other tv's in the house work. please advise.. thank you
If the ViewSonic logo first comes on followed with no signal the monitor is okay, check the video cable connection between the monitor and the computer, if okay the video graphic's card may be the problem,or the motherboard, but this is speculation you will need somebody to check the system for exact cause.
Jan 01, 2011 | ViewSonic NX1932W LCD Monitor
ViewSonic VA1930wm Screen stays on for about 2 seconds, and then goes off. 1) If no computer is connected you get a "no signal" message which stays for about 1 seconds and then goes off; blue...
Very typical of View Sonic. Sounds like a back backlight or inverter. I would go to www.viewsonic.com and open up a RMA. Most view sonic screens have a 3 year warranty. They will repair at no cost ..(if it is within that period) There is a date code on the back of the screen that will help you validate the above information.
Nov 07, 2010 | ViewSonic VA1930WM LCD Monitor
Monitor flashes on then off power light stays on whats wrong?? shows screen for about 3 seconds then goes black
Some 22" Viewsonics will have worn out bulging capacitors in the power supply that causes this symptom.
Monitor Mike
Apr 14, 2010 | ViewSonic 22" FLAT SCREEN CRT BLACK...
Viewsonic sreen isn't displaying the picture
More likely to have bad caps, see example here: http://s807.photobucket.com/home/budm/allalbums
Common problems to ALL brands, they all failed after a couple of years.
Jan 17, 2010 | ViewSonic VX2235WM Monitor
The screen is black even though the green light is on
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Viewsonic E70 - Menu Popup
This is a builti n feature on the monitor of course- not PC driven
A repair is not likely
Buy a nice new Flat screen
Oct 25, 2007 | ViewSonic E70 17" CRT Monitor
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
