Question about Acer Altos G530 Server
I got problem with my 2003 server, i want to repare my os through bootable disk.
Posted on Dec 11, 2008
  • thiravia Dec 11, 2008
    i got problem with my 2003 server, i want to repare my os through bootable disk
  • 61 Answers
Reinstall OS without repairing. Sometimes people make the mistake between a choosing repair and a full reinstall. Also backup any files before doing so.
Posted on Sep 20, 2008
I am setting up a Xseries 345 server using ServerGuide 7.14 everything runs fine untill it start to copy files it than gives me a blank screen and nothing happens after that
This is probably a Server Guide issue. You may check with one step lower verion and one step higher version of server guide. It may solve issue.
If that doesn't work, you may have to manually install OS without server guide. You can use a either use a floppy drive or pen drive to load controller driver. Once installed, rest of the drivers can be downloaded from IBM site or install from server guide cd
Dec 07, 2012 | IBM xSeries 345 Server
How to create bootable cd?
The following items are required:
  • A copy of the original Windows CD/DVD or ISO.
  • A copy of the Boot Files (Downloaded Below).
  • A minimum of 1GB available hard disk space for CD's.
    A minimum of 5GB available hard disk space for DVD's.
Create a folder called OS on your hard drive (C: is used in this example).
In this folder create two sub-folder called BOOT, and ROOT.
Copy the entire Windows 2000/XP/2003 CD (or extract the ISO) into folder ROOT.
1.) Download boot file. ( ~1.34KB)
2.) Extract the BootSector file (boot.ima) from
into the folder C:\OS\BOOT
Start Nero Burning ROM.
Select File > New... from the menu.
1.) Select CD-ROM (Boot).
2.) Select Image file from Source of boot image data.
3.) Check Enable expert settings (for advanced users only!).
4.) Set Kind of emulation: to No Emulation.
5.) Set Load segment of sectors (hex!): to 0000.
6.) Set Number of loaded sectors: to 4.
7.) Set Platform identifier: to Intel x86 compatible.
8.) Press the Browse... button.
Locate the BootSector file (boot.ima) in the folder C:\OS\BOOT.
Click the Open button.
Click on the ISO tab.
- Set File name length to Max. of 31 chars (ISO Level 2).
- Set Format to Mode 1.
- Set Character Set to ISO 9660 (standard ISO CD-ROM).
- Check the Joliet check box.
- Check all Relax ISO Restrictions.
- Check Allow more than 64 characters for Joliet names.
Click on the Label tab.
Remove the check from Also use the ISO 9660 text for Joliet.
Enter the Volume Label into the ISO 9660 and Joliet text boxes.
Click the More fields button.
- View Windows 2000 CD Labels (TTID# 269)
- View Windows XP SP0 CD Labels (TTID#226)
- View Windows XP SP1 CD Labels (TTID#283)
- View Windows XP SP1a CD Labels (TTID#312)
- View Windows XP SP2 CD Labels (TTID#342)
- View Windows XP SP3 CD Labels (TTID#422)
- View Windows 2003 Server RTM CD Labels (TTID#292)
- View Windows 2003 Server SP1 CD Labels (TTID#355)
- View Windows 2003 Server R2 Disc Labels (TTID#387)
Enter in the Volume Label into the System Identifier, Volume Set, Publisher,
Data preparer, Application
text boxes under ISO 9660 and Joliet.
Click the OK button.
Click the Burn tab.
- Check Write.
- Check Finalize CD (No further writing possible!).
- Set Write Method to Disc-at-once. (We have had Track-At-Once work as well.)
- Click the New button.
- Locate the folder C:\OS\ROOT.
- Select everything in the folder and drag it to the ISO compilation panel.
Note: Some files are not show in the following image.
- Click the Write CD Dialog button.
Click the Boot tab.
- Verify the settings. Correct if needed.
- Click the Burn button.
Wait for Disc creation to finish.
Click the Done button.
Process completed. You're done.
Jun 01, 2010 | Microsoft Windows XP Home Edition
Blue screen error
I see ..either teh installation didnt complete the loading of the files..or you didnt format the Hdd proper...try to reformat it in the NTFS normal mode...and change the installation cd ..cause in the proces there might have been a file it couldn't copy ..and skip it ...keep trying cause sometimes it does that ...if the server went fine ..this means that the HDD its ok ..and the problem is the installation disk ...with xp on ...
Aug 04, 2009 | HP Pavilion zd8000 Notebook
Ibm x series 226 attempt to install os and says no harddrive
Make sure that the motherboard and/or disk controller recognize the drives during POST.
Then check and see if IBM has a server installation CD-ROM that you can use boot the server and automatically load the correct drivers to prep for the OS install. I have downloaded installation CD ISO files from HP and Dell that walked me right through the OS install.
Another important consideration is that servers frequently use disk controllers that are not included in the operating system's driver files.
For example, when installing Windows OS on a RAID controller you must press F6 immediately after the installation CD-ROM starts up.
Later in the installation you will be prompted to insert a 1.44 diskette with the driver for your RAID controller.
The only challenge is to find the correct version of the driver and get it on a diskette.
I hope this helps.
Jul 16, 2009 | IBM xSeries 226 Server
Error with operating system
unplug everything. take out Your hard drive. put Your hard drive back in plug everything back in and try again. That is what is called a hard boot. If that doesn't work then You hard drive is junk. You will need a new one. Hope that helps.
May 24, 2009 | Toshiba Satellite A300-ST6511 Notebook
Server2003 enterprize edition
Hey There,
You are getting this problem b'cause loss of ur system file i.e. "CONFIG.SYS", Which loads ur initial files and drivers needs to start ur operating System.
You must follow the steps given below to start repairing ur System:
1. Insert the Bootable OS Disk into ur CD/DVD-ROM.
2 Reboot ur System.
3. The system will prompt You to "Press any key to boot from CD".
4. Press Any key.
5. Now the system will load all initial files and hardware driver.
6. After loading driver and files, OS will ask you for acceptence with their Terms and Conditions.
7. You must Agree with terms and condition. press F8 key for accepting terms n conditions.
8. After step 7, OS will search for the partition of ur Previously installed OS. If you have two operating system then it will show two Partitions with their name and drive letters. (You must remember the drive letter where ur OS is installed that u want to repair)
9. Now Leave that option as it is. And press Escape key.
10. Now You'll be able to see all those partitions you have on ur Hard disk, with their drive letter, Name and free space.
11. Select the partition of OS that u wanted to Repair, By Scrolling Arrow Keys. (Be carefull while selecting the Partition. If you select wrong partition then You wont be able to repair ur OS)
12. And then Press "R" Key from ur Keyboard.
13. Now OS Will search for the partition you have specified.
14 It will Delete Old system files and Copy New files (Note: You won't loose any data, Previously you had saved on ur boot partition).
15. After Step 14, OS will save the configuration and Will Reboot itself.
16. Again You will be asked for "press any key to boot from CD". Don't Press Any key at this step.
17. Now follow the wizard n specify correct information you will be asked.
18. It will take about 20 to 30 minutes to Repair ur OS.
Note: These Steps are not valid if you are using Windows Vista
Jul 30, 2008 | Microsoft Windows Server Standard 2003 for...
Blue error screen when loading os
ok did u try to instal ur os from a diffenrent cd ? try it , even the problems occurs check ur system with a different RAM ur will find the difference mostly problem gets solved if solved the ultimate sollution is to change ur RAM
Apr 11, 2008 | Computers & Internet
STOP: C0000218 {Registry File Failure} The registry cannot load the hive (file):\System Root\System32\Config\SECURITY or its log or alternate. It is corrupt, absent, or not writable.
to fix the problem, you need the Installation cd, put it in, start the setup, and enter repair console when the first blue menu comes up.
In repair console, your going to have to copy the windows\repair directory to system32\config
to fix the problem.
After the files have been copyed, Well maybe might be better if you only copy the SECURITY file. so no login details get changed.
Then restart the pc and see if it worked. If not your going to have to perform a repair installation from the xp cd.
If you need more asistance, let me know. Good luck.
Mar 29, 2008 | Microsoft Windows Server Standard 2003 for...
Loading problem
try to run again the system restore cd, what OS you are using? is it old or new acer laptop?
if you have new laptop with Vista OS it should be ok.
if you have new laptop design for vista but rather installed XP maybe you will encounter difficulties loading drivers if you dont have xp driver cd (acer provided)
if you have old laptop with XP OS it should be ok.
if you have old laptop w/ lower memory and trying to install Vista it will not work or you will incounter difficulties
Mar 16, 2008 | Computers & Internet
Acer Altos G530 Server Logo
166 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
