Question about Sony CLIE PEG-TJ37 Handheld
I am unable to HotSync and cannot load HotSync manager
I am unable to choose a USB connection, HotSync or load HotSync Manager. The Palm desktop organizer program is installed and loads properly. Also, I am networked with the company intranet. I loaded the software from the Palm website since I forgot my CD with the software. Any help would be appreciated. My palm z22 handheld hotsync manager will not let me update my handheld to the computer. it always says "the connection between your device and the desktop could not be established. please check your setup and try again", but i have already checked my setup and tried again for like 5 hours. HotSync Manager won't start, either from the handheld or from the Programs Manager....
I reinstaled the Palm Desktop again it worked....
Posted on Sep 21, 2008
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
IQ3600
Is it connected to the pc via usb? Try other usb port like the usb port on the back of your computer if your are using a desktop computer.
Aug 04, 2008 | Garmin iQue 3600 GPS Receiver
Unable to connect with desktop through usb cable
Jan 24, 2011
1 post
Oct 19, 2004
Mar 16, 2004
Dec 18, 2002
Palm Desktop 6.2 & Hotsync manager (windows) cannot ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
Jan 03, 2016 | Palm TX Handheld
Reinstall Hotsync manager and make sure selected port is correct. Use alternate method to sync like Infrared
May 29, 2009 | Sony CLIE PEG-TJ37 Handheld
Palm will not sync
Make sure hotsync manager is running. reboot the Palm device. connect to the USB cable and press the button. Also use hotsync manager to ensure you have enabled USB option.
Jul 23, 2008 | LG KU990 Viewty
Unable to hotsync treo 600 with my computer
What is happening with the Sync? Does your PC and the Palm Desktop Manager recognize your TREO 600? If not, the issue may be that somehow the driver for your device was removed. I would suggest upgrading to the latest version of the Palm Desktop Manager and try plugging in your TREO 600 again and try synching.
Here is the location for the free software from Palm. http://www.palm.com/us/software/palmsoftware.html
You also have to make sure that the setting on the Palm Desktop Manager is the same as the type of cable you are using. If it is a USB cable, have that setting on your PC's Palm Desktop Manager Hotsync settings.
Jan 27, 2008 | Palm Treo 600 Handheld
Garmin IQUE 3600 unable to HotSync, Windows XP
I think I have solved this problem.
Try this:
Go to my computer, right click -> Properties -> Hardware -> Device Manager.
Locate your IQUE 3600, or Palm.
Now, if your palm has a Yellow Exclamation mark on it, that means that your computer is not recognizing the Palm. Select
Driver details. Re-install the driver off the "Setup CD" that came with your IQUE 3600.
This worked for me.
Sep 21, 2007 | Garmin iQue 3600 GPS Receiver
Hotsync disconnects my LD
I've had this problem getting these set up in the past for customers.
What you want to do is go to your device manager and sync the palm while the window is open.
Look for a yellow triangle with an ! in the middle of it down towards the bottom by USB controllers.
If it pops up, double click on it and go to the drivers and try to reinstall your driver.
Sep 03, 2007 | Palm LifeDrive Handheld
USB Connection
Do you have the USB option turned on in the HotSync Manager? Have you checked the item called Local USB in the HotSync Manager menu. This check mark ensures that HotSync Manager is listening to the USB ports on your PC for a HotSync request.
Sep 12, 2005 | Palm m130 Handheld
Vx to Outlook 2002 failed - no connection Established
hi, on ur palm tap on home , u would see hotsync icon tap on that , on the hotsync page , u would see ur name on top or just welcome , make sure u see direct serial on the same page , tap on the top left corner where it says hotsync in words , in the drop down , tap on lan sync prefs , make sure local hotsync is darker in shade. on the pc make sure u see the hotsync manager at the bottom right corner , if not , click on start , click on all programs , choose palm desktop , inside that u would see hotsync manager , left double click on that , if it doesnt appear at the bottom right corner , try 4times , then if it still persists , restart the pc and try again. Once u see the hotsync manager at the bottom right corner , right click on that , left click on setup , left click on local , choose a different com port , reduce the speed to 9600 , click on ok restart ur pc and try hotsyncin , if it doesnt work try the previous step again and do not forget to restart ur pc , and then perform a hs , it will work .... Regards
Sep 11, 2005 | Palm Vx Handheld
Sony CLIE PEG-TJ37 Handheld Logo
474 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
