Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Fridge/freezer not cool.
Had power outage, now freezer nott cold & fridge warmish. cleaned coils, unplugged & reset temps. older whirlpool .
  • 750 Answers
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
I believe your problem is an old thermostat or compressor !
How old is it?
My advice is do not put good money into bad!
A new fridge will pay for itself in a few years by using a lot less electricity!
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please remember to leave me a rating before you sign off!
Thank You, HUUUM
Posted on Sep 29, 2008
The fridge is at 64 degrees and the freezer is working well. Coils are clean.
In most fridges, the cooling coils are in the freezer section. The other section is cooled by air flowing from the freezer section.There should be a valve/vent/knob that allows more or less air to flow from the freezer. Adjust this to maximum cold to see it the temp changes. Or is 64 degrees too cold for you?
May 06, 2012 | Amana ABB1927DE Bottom Freezer...
Kenmore trio freezer and fridge not cooling. we used to have problems where the fridge would be perfect but the freezer was always too cold, sometimes causing the freezer door to freeze shut. but we had a...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 19, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Kenmore side byside model# 363.9565482 does not cool/freeze after 3 day power outage .lights on & fan runs .tried unplug/replug & cleaning coils still not cooling .How do I fix?
First I would check cold control. Thats where you turn it off, if your temp is not warm. it seems
to be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 30, 2011 | Kenmore Side by Side Refrigerator
5 year old whirlpool fridge/freezer uk style freezer on bottom. freezer still cold but not working? fridge part still working but temp seems reduced. no ice at back of freezer area inside?
heatman101
Jun 10, 2011 | Whirlpool Refrigerators
Temp not cooling stays at 28 for freezer and 47 for fridge. checked settings and cleaned coil. also unplugged fridge and reset.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 27, 2010 | Kitchen Ranges
Whirlpool Mod ET18LKXHWo o Fridge not freezing,
Your defrost timer located inside the control panel is bad OR the defrost thermostat located on a freezer coil is bad.
Get down low and look up at the bottom of the control panel.
You will see a small round hole. Onside the hole is the defrost timer advance knob.
Use a flat blade screwdriver and SLOWLY turh the slotted knod clockwise until the refrigerator clicks off.
Wait a few minutes then open the freezer door and listen for a sizzling sound from the freezer compartment.
If you do hear a sizzling sound that would be the defrost heater melting ice.
If you do not hear a sizzling sound,unplug the refrigerator and remove the rear freezer panel to expose the cooling coil.
Clipped to the coil will be the defrost thermostat. It will need replacing.
If you do hear the sizzling sound the defrost timer will need replacing.
Jul 20, 2010 | Whirlpool Refrigerators
We had a power outage and top half will not work
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 08, 2009 | Refrigerators
F&P E402B Active Smart Fridge Compartment not cool
You need to start with a clean totally defrosted unit. That means clean, vacuum and wipe as much as you can around the entire motor compressor area especially any coils you can reach. Then set temp around whatever normal is and see what happens. If still the same it's time to have a tech do pressure tests.
Mar 29, 2009 | Refrigerators
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Not cooling or cold
The REFRIGERATOR WAS MOVED TO ANOTHER SITE. AND IT HAS NOT GOTTEN COLD SINCE MOVE, PLUB UP 2 DAYS AGO. iT WAS UNPLUG AND CLEAN 2 DAYS BEFORE MOVE. COULD IT NEED ANTI-FREEZE?
Aug 25, 2008 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
375 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
