Question about Sony Xplod XM-1652Z Car Audio Amplifier
Additional speakers can i hook them to amp instead of deck,500 watt 6x9s
  • 125 Answers
Does your stereo have additional outputs? you can get around that. anwser is: depending on the amp, yes you can.
Posted on Sep 24, 2008
I got a mtx jackhammer 2400 watt amp. when i hooked it all up and turned it on i am just getting 12 volt on the speaker output wires and no sound. it is just compressing the speakers and that is it. any...
verify your amps input. hook up a portable cd player with a headphone to rca "y" adapter to the amp and try that, to make sure it isnt an issue with the reciever/cd deck oir the input circuit. if the amp works correctly with the protable cd player/ walkman.mp3 player whatever, instead of the car deck, then something is wrong with your decks audio output. if it does not work with a secondary input device then perhaps you have the power hooked wrong. there should be both a red and yellow power lead from the amp, the red should be connected directly to the battery, and the yellow to the "acc on" (any circuit that turns on only when the car or stereo is turned on, sometimes connected directly to the stereo). both can be connected directly to the battery, but the yellow would need a switch, in that case, to turn the amp off when not in use.
Mar 09, 2011 | Car Audio & Video
Wiring diagram for radio. 2004Chrysler Sebring LX Convertible. Also How to size a Amp to 4 6x9's 2channel?4channel?
you prolly want a 4 channel but it can be done with 2 channel and you would want about a 1000 watt amp for 4 6x9s that would be about 250 watts per speaker
Mar 24, 2010 | Car Audio & Video
I want to hook up subs and a amp in a 2008 saturn vue how do i do it
If you are planning on using the factory stereo you will need a line level converter. You basically connect two of your speaker channels to the line level converter. That in turn will give you a line level out (RCA cables) That line level out can be fed to a two channel amp which would be where your subs would hook up to. If you do this however you will lose two channels of mid range and highs ( your rear speakers ). Downfall to this approach is that some line level converters are susceptible to alternator noise.
If you have an aftermarket deck this will be much more simple. You simply run your RCA outputs from your deck to your external amplifier. Aftermarket decks typically have front rear and subwoofer outputs. That means you can drive a four channel amp for your front and rear and a two channel amp for your subwoofer. This is the recommended way to go.
For hookups I just suggest buying an amp kit that is comparable in power rating to your amp. If you buy a 500watt amp make sure your wiring kit can handle at least 500 watts.
Feb 12, 2010 | Jl Audio M5122.4 Diamond Audio 12" Car...
How to hook it up to system with two 10s 400 watts per sub and two 6x9s at 200 watts each?,subs behind seats, 6x9s in doors. IF i need another amp i have one,to help push. But either way i need your help...
Hello www_mitzjohn,
I'd definitely use another amp.
The 2-channel Sony is well suited for powering the 6X9's but a monoblock would be better for the subs. The different types of speakers running from the same channel will not sound very good and likely it'll be impossible to get the impedances to match.
You'll want to set the Sony to send higher frequencies to the 6X9's, but not to the subs. You can't adjust the channels individually. So, just connect each 6X9 to one channel of the Sony and use a monoblock subwoofer amp for the subs.
Hope this helps.
Oct 31, 2009 | Sony XM-2150GSX Car Audio Amplifier
I need help on sound built in
u may be able to custom fir the 6x9 into the rear of the vehicle, if you don't want to do that, you may be able to fit them into the spots in the doors, but that still may be a custom job. u could always go with boxes, individual boxes that you could put on the floor on maybe on the back deck where usually the 6x9s would be located. if you dont like that idea, you might try a body shop or electronics retailer because there is definitely a way to fit those speakers in the doors or on the rear deck, it just won't be an easy job for a beginner, you have to cut holes
Aug 09, 2009 | Car Audio & Video
Can a rf 201s amp push 4-6x9s and 4-104s door speakers
Hello jon_jonmay,
Wiring 4 speakers to each of 2 channels, you will need to wire them series-parallel and run them at 4 ohms. If you wire all 4 parallel, the load will be 1 ohm and the amp is only stable down to 2 ohms.
According to your manual, the 201s will deliver 50 watts into each channel at 4 ohms . So it will be supplying about 12.5 watts per speaker which is about what you get with the average factory radio. They will work OK, but they're not going to be very loud.
Hope this helps.
Apr 21, 2009 | Rockford Fosgate Punch 201S Car Audio...
Need to hook up to a 4000 watt amp
Why would you hook up 4000 watt amp to a speaker that has only 1000 watts. Try a 800 watt amp instead unless you just dont want the spealers.
Apr 13, 2009 | Theater Research TR-9500 Car Subwoofer Box...
I have a memphis amp that puts out 250 watts @ 4ohms and 500 watts @ 2 ohms. I want to hook up 3 sony 12'' explods @ 4 ohms a piece. How do I wire them to the amp to get the maximum output of 500 watts?...
well to be honest your amp probly cant handel 3 speakers because of the impedance levels so just hook up 2 bridges out to + to - on one Speaker then from that same speaker run + and - to the next one
A= amp
S= speakers
Mar 22, 2009 | Car Audio & Video
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
