Question about Samsung Digimax S600 Digital Camera
Lines when i take a picture and take a look at the image (in the camera or the PC display), it has interlaced dark lines across the whole image however when i take videos they look good. i've tried every combination of quality and megapixel configuration but the problem is still there. thanks in advance Peter
  • 3 more comments
  • PeterHen Sep 23, 2008
    the camera is a Samsung Digimax S600. 6 megapixels. if you send me an email address i can send you a small photo taken with the camera where you can see the problem.
    Peter
  • Anonymous Sep 25, 2008
    Horizontal dark lines, but i just figured out that it just displays on white spaces. When i take a photo the white wall behind me gets the dark lines but i dont or the people in the picture doesnt.
    Should the sensor be the problem??? i dont think so because as i said, it just happens on white spaces.
  • Anonymous Nov 03, 2008
    My camera just started doing this after 2 years. I love my camera and I want to keep it. What caused this problem?
  • Anonymous Jan 04, 2009
    Same problem after 2 years and over 15,000 pictures with this lovely camera
  • Swaminathan R
    Swaminathan R May 11, 2010
    hi peter,
    What is the camera model do you have?
    How many megapixel is it?
    Sergeant:
  • 208 Answers
Hi peter,
Video will not be able to display the dark lines becoz its samling rate is low and so it cannot display detailed image.
With your 6 MP camera , the reason for the images having dark lines is that,
The SENSOR present inside your digital camera may have been covered by dirt or it may have some lines over it. so it is obvious for the images to reflect that.
So i suggest you to check the sensor with your service center.
Else you can refer to this website for more support www.samsungcamera.com/customer/faq/cus_faq_list.asp
Hope this works...
Thanx peter.
Posted on Sep 25, 2008
Problem with my Magnavox DVD player, DP100MW8, picture dark and lines across the screen
Hi, if the lines are diagonal sounds like it is set to progressive scan mode-which means if there is not a switch on back saying P/S and interlaced then you need to connect to T.V. with component video inputs ( indicated by red,green,and blue colored R.C.A. plug inputs) and Pan and Scan capable-then in menu setting select interlaced picture output. hope this was of use, good luck prodzilla
Mar 30, 2011 | Televison & Video
Display has lines and is gray
This is known problem of ccd imager chip failure in Canon A95 and ccd imager chip will be replaced to fix the issue.
Local camera repair shop will help you because camera will take apart in detail and soldering work is also involved.
Thanks.
Jul 13, 2010 | Canon PowerShot A95 Digital Camera
The camera takes great pictures in dark areas, but once there is light sunlight or otherwise, there are lines across the pictures and the image is not shown, why?
Hi!
It's most likely a broken shutter cable inside the lens - happens to Samsung cameras all the time. You should be able to take videos in any conditions and pictures in low light conditions. The only way to fix this is to change the shutter unit with cable or whole lens unit. It should be expensive so I would recommend you getting a new camera, but this time not Samsung - they're pretty awful.
Sorry for the bad news!
Tom
Sep 27, 2009 | Samsung BL103 Digital Camera
Canon Hg 10 Vertical line on image
This camera outputs interlaced video files. That can be the lines you are talking about if you are playing it back on a PC. The camcorder itself will de-interlace the video during playback on the actual camera, but not the file. You have to either play it (60i) with a hardware or software player that de-interlaces in realtime, or export your video file into a progressive (or deinterlaced) format. Some cheap editors dont deinterlace. I use Adobe Premiere Pro and Sony Vegas.
Dec 24, 2008 | Canon MV700 Mini DV Digital Camcorder
View screen has purple lines across whole screen cant take a pic.
It is bad ccd issue in Canon A95 camera and ccd imager needs to be replaced.
Canon will repair A95 free of cost as per announced scheme.
Click Canon CCD Advisory for details.
Good luck.
Dec 21, 2008 | Canon PowerShot A95 Digital Camera
"Unusable Signal"
Ok, I stopped short of going to Best Buy to get a new TV b/c my DAD suggested I pull the DVD player on another tv.
Dang it, he was right!. Same "audio no video" problem.
After playing with multiple buttons shooting blindly I found the [ I/P ] button restored the picture immediately!
This stands for Interaced or Progressive scanning:
from wikipedia
"Progressive or noninterlaced scanning is a method for displaying, storing or transmitting moving images in which all the lines of each frame are drawn in sequence. This is in contrast to the interlacing used in traditional television systems where only the odd lines, then the even lines of each frame (each image now called a field) are drawn alternatively."
So, my Dad says that "TV s are based on the interlacing" technology. I must have picked progressive scan while I was in the dark fast forwarding last week.
Mar 27, 2008 | RCA 27V530T 27" TV
Television display
In basic terms TV images are made up of hundreds of horizontal lines, with interlaced scan it will display in order line 1, 3, 5, 7 and so on and once it reaches the end it will fill in the missing lines 2, 4, 6 and so on until it starts again.
For progressive scan it will display the lines in order 1, 2, 3, 4, 5 etc.
cheers
Jan 21, 2008 | Televison & Video
Pinkish screen and green blurred picture
Sounds like the image sensor is malfunctioning (common symptoms: distorted images with purple or green cast, completely dark images, flickering lines across the screen.)
Oct 26, 2007 | Kodak EasyShare C643 Digital Camera
Z740 Digital Camera Dark Pictures w/ lines
My CAMERA is AN MD853 i hAvE tHiS SAME PR0BLEM i didNt dR0P MiNES EitHEr..d0ES S0ME0NE kN0w wHAt'S g0iN 0N?
Aug 30, 2007 | Kodak EasyShare Z740 Digital Camera
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Samsung Digimax S600 Digital Camera Logo
161 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
