Question about Frigidaire FRT15B3A Top Freezer Refrigerator
Frigidaire GLHT186JSO New refrigerator shipped to us in Jamaica WI from Miami in May 2008 has been malfunctioning since. the freezer is cold sometimes but the fridge is very hot almost all the time. the only installation we did was to plug in the appliance. There are also times when there is no sound from the refrigerator even though our power supply is good, and then the freezer starts defrosting. we are unable to contact frigidaire via the internet as the website requires a US or Canadain address. Please help us. Thanks.
  • 750 Answers
Flounce,
Don't you have any authorized Frigidaire repair services in Jamaica?
That fridge is under full warranty and will not cost you anything to be fixed by and authorized repair service there!
I'll try to find you a service in Jamaica that does the warranty work and ad the info to this post!
I was unable to find Frigidaire service in Jamaica WI.
Posted on Sep 20, 2008
Bottom freezer staying cold fridge is warm
There is a deflector to manage the cold air to each compartment. It could need to be adjusted. I would guess there is a malfunction in the refrigerator however. When you say the bottom freezer is cold, how cold? Also, clean the external coils on the refrigerator and make sure you have good air flow around them. This will help is the heat transfer and allow the unit to operate properly. If the freezer temperature is not cold enough, you may have other issues.
Sep 03, 2014 | Frigidaire Refrigerators
I bought my samsung in 2008 at Brandsmart USA, Miami and shipped it to Jamaica. It now has a whole lot of black spots that have taken up the left hand side of the television and is now spreading to all...
You are going to have to replace the DLP chip. Part# is 4719-001981 and costs $237.51 when ordered from partstore.com. You really should have a technician replace this part because it is burried in the Light Engine assembly and an un-trained person can cause serious damage to the light engine.
Jul 11, 2011 | Televison & Video
After emptying the ice bin on 2 year old side frigidaire, the freezer is OK, but the fresh food side has stopped cooling. Any ideas?
check that the fan in the freezer is running,it circulates the cold air,if it isclose freezer door,open refrig. door lookto the upper left you will see where the cold air enters the refrig compartment and should fill air coming thruough vent this is a motorized unit and they sometimes fail,also check the return air hole located at bottomof refrig.sometimes get blocked by plastic bags etc
Jan 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer cold- Fridge Not, Loud Noise
that is the damper door malfunctioning this open to allow cold air into the fridge compartment the damper needs to be replaced
Sep 20, 2009 | Frigidaire FRT17G4B Top Freezer...
Refrigerator does not get cold and the freezer does not freeze.
look on the back of the box for a hole marked defrost control timer turn the timer with a screwdriver if it then gets cold replace the timer
Apr 20, 2009 | Frigidaire FRT15B3A Top Freezer...
Frigidaire FRS23H5AS refrigerator - freezer not cold
Humming noise would be your compressor going bad. The noise from the fan is because they are over working to try and keep everything cool
Feb 12, 2009 | Frigidaire FRS23H5AS Side by Side...
Freezer Not Freezing
sounds like youll need to order and install one of these, its too cold in your garage to operate normally, this is a simple solution that should correct your issue
http://www.frigidaire.com/tip/US%202008%20Service%20Flashes%20and%20News/Refrigeration/2008/Service%20Flash%20RF083FRIG%20Garage%20Kit%20for%20Top%20Mounts.pdf
Jan 21, 2009 | Frigidaire FRT15B3A Top Freezer...
THE FREEZER IS WORKING BUT NOT THE REFRIGERATOR
your defrost system is malfunctioning un plug refrigerator for about 2 hours replug and check if it makes a difference check if fan in freezer is working , you may need atechnician .
Mar 06, 2008 | Refrigerators
Frigidaire FRT15B3A Top Freezer Refrigerator Logo
134 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
