Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge sis by side
Water on door will not disperse, ice maker working and dispense working.
how can i make the water come out?
  • rose71351 Sep 25, 2008
    No water will come out door; power was out for about 7-8 days; when power came back on no icemaker and no water through door
Howdy do!,,,this happened to my GE side-by-side,,,I found that the water line in the door was frozen,,,I lowered the temp in the freezer by just one number,,,then warmed up the door with a hair dryer,,,,when the water line thawed out enough to work a small piece of ice came out of the line and went in my glass. Good Luck!,,,,Pete.
Posted on Sep 23, 2008
My ice maker is working fine. My ice dispenser is working fine, There is no water from the water dispenser. When I push the button, I hear a click but no water.
I had this same issue with my GE refrigerator and figured out it is a common problem with these units. The water line freezes up near the dispenser panel. Fortunately, GE has an inexpensive solution, a water line heater, that fixes the problem with little work. Check out my blog post on my ge refrigerator water dispenser not working for complete details.
Oct 28, 2010 | GE GSH25JFR Side by Side Refrigerator
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
I have ge profile sis by side refrigator.Problem is there is ice in the ice bin but won't disperse ice onlt water.can you help
I recently had this problem and afer checking and cleaning the ice bin and making sure it was inserted correctly but still would not dispense. I called a repairman. The disenser level is triggered by a piece of plastic that is the size of a toothpick. The toothpick was broken and the entire dispenser workings had to be replaced. (can't just replace the tootpick) About $50 plus service call.
Oct 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
The water dispenser won't work, but the ice maker does on my side
try putting the hair dryer on the door where the water and ice comes out. then put it in the hole inside where the ice falls in. only took me 20 seconds for water to work
May 19, 2009 | GE Refrigerators
Ice door not working
I have the GE Profile BSS25JSRF SS and have had similar problems: fixed the water dispenser by putting a hair dryer on it for 2-3 minutes. Sometimes this will freeze up and needs to be thawed. However, I still get no ice through the door. Hope this helps.
Apr 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water, ice and crushed ice dispenser doesn't work properly
you need to replace the board in the dispenser front housing on the front of the freezer door / larry
Mar 16, 2009 | Refrigerators
Ice maker and now water dispenser does not work
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Wont dispense water
Did you check the pump at the bottom of the fridge ,and also the solenoid. valve to release the water ,does it click when you depress glass against sensor in dispersal area
Dec 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
176 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
