Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Philips 37pf7320a/37 picture issues.
Hello there. I have a philips flap panel LCD and when I left for workthis morning the TV worked fine, came home about 8pm and went to turnon the set and green light came on but no picture. I have cycled thruall of my connections and can hear sound from every single input,(Xbox360, PS3, Cablebox) but they all show no picture. I dont have anyblinking red lights and even tried the firmware update. Powered tv downand inserted the memorystick then powered up, sound cut off for amoment and saw green light on memory device flicker as if it werecommunicating with TV. Powered down after 10 min then powered back upand still only sound. If you have any idea what could possibly be theproblem please help me out. Thank you for taking the time to read thisand have a great day.
  • 905 Answers
Control boards on LCDs and PLASMA tvs are causing no picture , missing area , and other wierd symptoms , it will need to be tested to determine the true problem
Posted on Oct 08, 2008
The volume controls on both my remote and my Philips flat HDTV 37PF7320A 37." How do I fix it?
Read your Philips setup info that came with your tv very carefully and also if applicable read your cable box setup info very carefully then set every thing up like it says also check tv audio menu and make sure the audio is set to on
Sep 13, 2014 | Philips 37PF7320A 37 in. HD-Ready LCD...
37" Philips LCD sound but no picture
Check the inverter on the sides of the TV. This sounds like the inverter is going bad and that's the reason why you have sound but not picture.
Jun 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv turns on has sound but picture
Rest the tv by unplugging it from the wall for a hour. If the picture is still gone replace the small signal board.
May 30, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37' lcd tv 37mf231d/37
It is the low voltage power supply. I just had my set repaired and it had the same symptoms. My set is out of warranty. The repair cost is around $200.00.
May 19, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Problems with your Philips 37PF7320A 37 in remote control
If the remote has been replaced the IR receiver could be bad. Try changing the channels with by the tv. Most likely that is the problem.Beside that the small signal board could be an issue. But I would the IR receiver would be first.
May 11, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
The problem is the small signal board that is the video processor.
Mar 27, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
193 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
