Question about LG 15LW1R 15 in. LCD Television
Wireless transmitter blue light does not come on to refect that transmitter is connecting with the tv
Conection issue wireless tv and transmitter
  • 1 more comment
  • okilph3 Mar 31, 2009
    Same Problem. Power to transmitter, but blue light no longer comes on. Worked one day and not the next.
  • Anonymous Apr 04, 2009
    Wireless transmittor is not transmitting. Blue light does not come on.
  • sunsarge May 07, 2009
    I have the same problem, there is no connectivity. There is power to both units but no blue light on the transmitter.
    Kim
2 Suggested Answers
dave1645
  • 834 Answers
SOURCE: says out of range. blue light is on from
are you in the VGA computer monitor mode if so you need to lower your resolution on the PC
Posted on Dec 02, 2009
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
Where do I find the model number
The words "red and blue lights", "paired", "connect" and "beeps" make me believe that your headphones are Bluetooth-enabled. However, I never heard of a TV that is Bluetooth-enabled. Therefore, I do not think that you will be able to pair, nor connect your headphones to your TV. If you want to listen to your TV wirelessly, you will have to use regular (not Bluetooth) wireless headphones, which consist of two pieces: the headphones and a transmitter that connects to the audio output(s) of your TV and transmits the sound from your TV to the headphones wirelessly.
Dec 06, 2014 | iHip Audio Players & Recorders
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Sharper image indoor/outdoor wireless speakers and transmitter has no audio.
First, determine if the TV device is putting out sound by plugging in a headphone into the audio out of the TV. If audio is there then the
transmitter and wireless speakers system may be at fault.
You can also plug in a CD player playing a disc into the transmitter to see if that source then transmits the audio.
Aug 21, 2012 | Audio Players & Recorders
Not conecting to computer
When you install a wireless mouse, first make sure your USB transmitter is plugged into a functioning USB port.
Then make sure the mouse batteries are fresh and installed correctly.
Once you are set, turn the mouse over and push the "connect" button on the bottom. Note: if your transmitter/receiver has a "connect" button, push that first.
Feb 22, 2011 | HP Wireless Optical Mouse
I'm unable to connect to my push2tv netgear box. I could connect fine with my Toshiba Sattelite (Best Buy Blue model). However, I'm unable to connect with a Toshiba Sattelite M645-S4070. It has Win 7...
Sounds like you have a firewall problem either with the Windows 7 built-in firewall or an anti-virus application firewall. Do you have an Anti Virus program installed?
Nov 24, 2010 | NetGear Push2TV TV Adapter for Intel...
How do I conect external radio/speakers to my lg 42lh40-ua
There are many options here. Most HDTVs today have analog audio and digital audio output jacks. You can use RCA audio cables or a 3.5mm connector, whichever your HDTV has to connect the analog stereo output of the TV to any number of devices such as a stereo/amp which has speakers attached. You could also connect an FM transmitter to the TV and send the audio wirelessly to a nearby FM radio, boombox, portable etc. Most HDTVs today have a digital audio output, typically optical, which uses a digital audio cable ($15) to connect to a surround sound receiver. You can also connect the stereo analog output jack on the TV to a 2.4GHz transmitter and receiver speaker combo to get wireless audio outside, in a swimming pool and so forth, all around the house using wireless speakers. These setups usually cost around $150 or so. Look for the jack on the TV labeled AUDIO OUT and see if it is the white and red 2 jack ports or the smaller 3.5mm single jack port. Adapter cables are available at Radio Shack for around $10 should you need them. So you see the options are almost endless.
Aug 17, 2010 | LG 42LH40 LCD TV
Sharper image wireless speakers, model CT 413, were working fine. today, the blue transmitter light isn't on and nothing can seem to make it transmit. suggestions?
My speakers were working fine on my TV, I disconntect them, then when I re-connected the transmitter no signal is received and nothing is heard via the spearkers either.
Nov 25, 2009 | Audio Players & Recorders
My headphones connect with the adapter, the blue light is on on both but nothing comes from the ipod. I have performed the factory reset but it still doesn't work. The headphones had worked fine and then...
I have same issue....just took my transmitter apart - the wires connecting the male jack to the silicon board are frayed, disconnected.....you might check that...it's only 2 small screws holding the outercase together....be careful though
Jul 07, 2009 | Logitech Bluetooth Wireless Headphones
Wireless speakers not communicating to Receiver
Speakers have a unique RF frequency that needs to pair with the receiver (kind of like a blue tooth headset with a cell phone). At times, the signal may reset, so, you may have to go through the initial pairing sequence. Try this:
1. Unplug rear speakers
2. Make sure the sound signal connector is plugged in to the back of the system properly.
3. Press and hold the ID button for 3 seconds until the blue LED light flickers.
4. Connect the power chord to the rear speakers.
May 03, 2009 | NexxTech DP3222 DVD Player
LG 15LW1R 15 in. LCD Television Logo
332 people viewed this question
Computer Repairing
Computer Repairing
